[Plugin] Shape Bender Beta
So install progressbar.rb as indicated in the 6th line of the original post.
And, for future reference, it is worthwhile reading all of the original post in an thread before downloading plugins. They usually full of useful information.
IF you report the original error message in the first place we could help you more promptly
Please read the tool's instructions, follow them and then report errors after that [if any]
Im sorry man Im just new to sketchup and Im trying to figure everything out..
So did installing progressbar.rb fix your problem?
Please report if the suggested fix resolves your issue...
Without feedback we are unsure if what we suggest works.........
thanks so much! i tried, very easy and very useful!
HI everyone
I really appreciate all the work done for those amazing plugins , but i have some problems using Shape bender :
installation went fine but when it comes to ebnding and object it doesn t work , explanation :
I select a group (ok ) BUT THEN when it comes to select a line i have drawn on the side of that object , a window appears telling me [please select a straight line ] or [ select a line on the red axis ] .... and my line is straight And on the red axis !
could anyone help me out?
John,
Is the line you are selecting part of the group? If so, that would explain the message. The line must be outside the group for it to work.
@N08/5126930295/" target="_blank" rel="noopener noreferrer nofollow ugc">
In this image the line is being selected. The component to be bent is above it. -
the line is outside the group .
Mostly sketchup tells me [ please select a line that is on the red axis ]
what may i do ??
and it does not work even if my line is on the red axis ...
You need three things to use the tool
A Group or Component-instance.
A Line drawn along the red-axis to determine the extent of the actions.
A Curve [e.g. an Arc] - this is often drawn to have similar extents as the Line [but not necessarily].Preselect the Group/Component.
Run the tool and follow the prompts.
Pick the Line.
Pick the Curve.
Toggle the 'Ends' using the Arrow-Keys etc as prompted etc... -
TIG beat me to it. Can you post a screen shot of what you're trying to do?
Pick the Line.
Pick the Curve.
Toggle the 'Ends' using the Arrow-Keys etc as prompted etc...[attachment=0:rnii52fu]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:rnii52fu]I EXACTLY DO AS YOU SHOW ... but Can t select the "lone line on the red axis" , as sketchup does not notice it .. always the same error message
I might try to re instal the plug in ...
The Lone Line on the Red Axis must be exactly that.
It cannot be connected to other things ???
The cursor changes to a ___ to show it needs a line... -
Also, it only works on the original red axis. So if you have changed your world axis, you will need to reset it. To do this, right click on one of the axis lines and choose "Reset". That should re-align it to the world axis. Perhaps that is cause of the problems. Let us know how it goes. Also, if none of this works, you can also upload your model, or a small portion of it here so we can test it. Thanks!
I think the best is to use this plugin in and "empty" file. f you make a component of what you want to bend then align the component axes according how the plugin should work then you can right click > save as... and open the new file, you can experiment without any risk then when done, in the original model, right click again and "reload".
I have a question about installing shape bender on my computer. I copied the .rb and the folder into my plugin folder. Now that I start sketch up it gives me the error: Error Loading File clf_shape_bender_loader.rb
No such file to load -- progressbar.rbhow can I fix that?
cheers
cheers
The download page explains that you need to get that separately - ~6 lines down http://forums.sketchucation.com/viewtopic.php?p=147395#p147395
It's free from Smustard.com.
Put it into Plugins and restart...
YEP it works .... in fact , just needed an empty file ... @ Chris F. : i think the axis were changed , that was my problem !
Thanks for your help dudes!!!
Hi Guys typical that a first post is a question
Can anyone tell me in simple terms how to install Shape Bender on a Mac.
I have previously installed make faces 1.4 and that seemed easy although I cant find where it is installed now either
Andy
