    New PC tower design
    38 Posts 15 Posters 3.6k Views 15 Watching
      liam887
      Looks nice, maybe sketchup 20 will come with a 'Print' plugin sends your designs straight to a factory and then back to you. Speaking of interesting towers while not a PC I love this design:
      http://www.boxee.tv/
      VISIT MY ONLINE GALLERY
        d12dozr
        Neat design, Richard...you could get it 3D printed in titanium or even gold in the near future...if you had Donald Trump's salary 😄
        ~$124 USD/cubic cm for titanium! 😮
        http://goo.gl/f7ooYh
        • RichardR Offline
          Richard
          PER CUBIC CM?? WTF?
          My god mate. yep donald trump! May be i should change the size!
          BUILTBRAND.COM.AU
          • jeff hammondJ Offline
            @richard said:
            Ordering a new PC this month and looking for cases have found it is hard to find a case that becomes a furniture piece
            plus, since there's no tower, it frees up space for an actual piece of furniture..
              KarinaGM
              Well you don't need to print it. You can take the images and prints to someone who works metal...
              I'm sure, that way could be affordable. Not cheap, but payable at least LOL
              Nice design 👍
              Is the feet stable enough? you don't want to accidentally kick it or bend it.
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
              -Benjamín Franklin.**
              • RichardR Offline
                Richard
                It still would be very expensive I think to knock out a one off. So to dream for now! And then their are the plastic items and clips etc that one would need.
                Here is a workstation size unit with a bit more an industrial look. Thinking of a way to lock / lift the right side feet to expose wheels to assist transport.
                BUILTBRAND.COM.AU
                • RichardR Offline
                  Richard
                  Nice design 👍
                  Mate I still haven't completely determined the feet! I need to consider how they are pressed to get the rigidity needed.
                  BUILTBRAND.COM.AU
                  • Bryan KB Offline
                    Looking good.
                    • soloS Offline
                      Cool looking rigs mate.
                      I'd suggest the legs be in a material that non conductive, just incase someone wants it on a carpet (learned that expensive lesson once, static electricity fries chips)
                        wait, grounding wouldn't prevent problems?
                        my tower is all metal and though i don't place it on the carpet, i don't think apple would sell them if carpet&static electricity would cause issues.
                        • PixeroP Offline
                          Pixero
                          Just a question, wouldn't the "waist" make it hard to fit the motherboard and fan for the processor?
                          Also I believe it might reduce airflow inside.
                            Richard, assuming that you've sorted out Jan's question about fitting the motherboard, I'm thinking you could find someone locally to bend that out of some sheet metal for not an awful lot of money. Have it done in aluminum or stainless steel and skip the paint. Or look around for someone who does powder coating to paint it. Standard paint colors like white or black would be inexpensive.
                            What if you combine some wood with the metal case? Black case and maybe maple for the feet and the handle at the top?
                              mac1
                              Built my own computer few years ago. Much more important than the outside look is the inside.. You have the power supply, the cabling and the PIN outs, most have the EMI shields and the foot print holes for the industry spec mother boards, drive rails, all the cooling tunnels etc.and the all the mounting hardware( 100's of parts). I bought an ANTEC SonataII and think it has a nice look when the door is closed. This can be a huge design under taking
                              • RichardR Offline
                                Richard
                                Mate the actual box is BIG! The tummy band is the same width as a normal box! The drive bays arn't in proportion! This overcomes a lot of Mac1's concerns too! Ample room is allowed for all!
                                Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case.
                                The WS case (second version posted) I consider I'd love to house s cheap simple sandybridge render node/s later - all in the one case - hence the size!
                                BUILTBRAND.COM.AU
                                • RichardR Offline
                                  Richard
                                  Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case. I like the timber idea - though has it's issues. I like the idea of such a case sitting next to a RedBull F1 car in the pits hence a little it's case design.
                                  BUILTBRAND.COM.AU
                                    mac1
                                    Are you building a computer or furniture??
                                    IMO designing then building the computer is the first effort. You can then jazz it up with a fancy enclosure if you so desire with fans, ups retractable tops etc, etc. I made my design big to start with for several reasons. PC junction temp is the driver for life so good cooling to keep the delta T down is most important. Second I wanted to be able to modify easily so when our MS, Intel friends make changes and OEM guys want us to buy a new PC mine is just an upgrade. It is getting old now, about 5 years, but had a 3.2GHZ CPU for that time. No PCI express so that maybe the next step or wait for next major step which will probably be to get rid of all the cables and have one optical interface=> not external cable races etc. HEY!!! Flexibility should be the name of the game.
                                    • RichardR Offline
                                      Richard
                                      Mate I understand all you are saying!!
                                      Here is a bit of an evolution on the design, with slide out dust filters and slide out cable store.
                                      Also a crap rendered version with the cover in plastic to see the interior layout 1366 socket board left / 1155 socket right (render node) - Radiators centre.AutoSave_NEW-PC1.jpgCASE-explode.jpg
                                      BUILTBRAND.COM.AU
                                        I like it. SO it is almost the size of four PC cases? Lots of room for expansion and cooling.
                                        • W Offline
                                          watkins
                                          Dear Richard,
                                          Don't forget to look here for bits and pieces:
                                          http://scc.jezmckean.com/home
                                          Regards,
                                          Bob
                                          • RichardR Offline
                                            Richard
                                            Yes Dave it is BIG - not quite as big as 4 mids but not that far off!
                                            BUILTBRAND.COM.AU
