    New PC tower design
    38 Posts 15 Posters 3.6k Views 15 Watching
    • PixeroP Offline
      Pixero
      Just a question, wouldn't the "waist" make it hard to fit the motherboard and fan for the processor?
      Also I believe it might reduce airflow inside.
        Richard, assuming that you've sorted out Jan's question about fitting the motherboard, I'm thinking you could find someone locally to bend that out of some sheet metal for not an awful lot of money. Have it done in aluminum or stainless steel and skip the paint. Or look around for someone who does powder coating to paint it. Standard paint colors like white or black would be inexpensive.
        What if you combine some wood with the metal case? Black case and maybe maple for the feet and the handle at the top?
          mac1
          Built my own computer few years ago. Much more important than the outside look is the inside.. You have the power supply, the cabling and the PIN outs, most have the EMI shields and the foot print holes for the industry spec mother boards, drive rails, all the cooling tunnels etc.and the all the mounting hardware( 100's of parts). I bought an ANTEC SonataII and think it has a nice look when the door is closed. This can be a huge design under taking
          • RichardR Offline
            Richard
            Mate the actual box is BIG! The tummy band is the same width as a normal box! The drive bays arn't in proportion! This overcomes a lot of Mac1's concerns too! Ample room is allowed for all!
            Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case.
            The WS case (second version posted) I consider I'd love to house s cheap simple sandybridge render node/s later - all in the one case - hence the size!
            BUILTBRAND.COM.AU
            • RichardR Offline
              Richard
              Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case. I like the timber idea - though has it's issues. I like the idea of such a case sitting next to a RedBull F1 car in the pits hence a little it's case design.
              BUILTBRAND.COM.AU
                mac1
                Are you building a computer or furniture??
                IMO designing then building the computer is the first effort. You can then jazz it up with a fancy enclosure if you so desire with fans, ups retractable tops etc, etc. I made my design big to start with for several reasons. PC junction temp is the driver for life so good cooling to keep the delta T down is most important. Second I wanted to be able to modify easily so when our MS, Intel friends make changes and OEM guys want us to buy a new PC mine is just an upgrade. It is getting old now, about 5 years, but had a 3.2GHZ CPU for that time. No PCI express so that maybe the next step or wait for next major step which will probably be to get rid of all the cables and have one optical interface=> not external cable races etc. HEY!!! Flexibility should be the name of the game.
                • RichardR Offline
                  Richard
                  Mate I understand all you are saying!!
                  Here is a bit of an evolution on the design, with slide out dust filters and slide out cable store.
                  Also a crap rendered version with the cover in plastic to see the interior layout 1366 socket board left / 1155 socket right (render node) - Radiators centre.AutoSave_NEW-PC1.jpgCASE-explode.jpg
                  BUILTBRAND.COM.AU
                    I like it. SO it is almost the size of four PC cases? Lots of room for expansion and cooling.
                    • W Offline
                      watkins
                      Dear Richard,
                      Don't forget to look here for bits and pieces:
                      http://scc.jezmckean.com/home
                      Regards,
                      Bob
                      • RichardR Offline
                        Richard
                        Yes Dave it is BIG - not quite as big as 4 mids but not that far off!
                        BUILTBRAND.COM.AU
                        • RichardR Offline
                          Richard
                          @watkins said:
                          Dear Richard,
                          Regards,
                          Bob
                          Wow thanks Bob! That's a great resource! Rich
                          BUILTBRAND.COM.AU
                            Why not perforations for the venting? So much easier to fabricate, thus reducing cost, and a cleaner look.
                            Looks good though πŸ‘
                              Roger
                              Also a crap rendered version with the cover in plastic to see the interior layout 1366 socket board left / 1155 socket right (render node) - Radiators centre.[attachment=1:wq8lzf6s]<!-- ia1 -->AutoSave_NEW-PC1.jpg<!-- ia1 -->[/attachment:wq8lzf6s][attachment=0:wq8lzf6s]<!-- ia0 -->CASE-explode.jpg<!-- ia0 -->[/attachment:wq8lzf6s]
                              Love your work, but just a suggestion raise or lower your view point to keep the horizon line from aligning with strong edges in your design. It really messes up the perception by "pulling" said elements bact to the horizon.
                              http://www.azcreative.com
                              • RichardR Offline
                                Richard
                                Thanks mate! The vents are actually cheaper funnily enough, as they are both commonly done and the tooling permits them to be pressed in easy!
                                Perforating would required the drilling of each hole!
                                There are two reasons for going this way - one to get just that bit of industrial look to it and second to aim the vents in the direction of air flow dragging in cold from low and pushing out air from high with some added noise reduction effect in theory!
                                BUILTBRAND.COM.AU
                                • RichardR Offline
                                  Richard
                                  Your spot on mate! Not such an exercise at producing a nice picture at this stage, just lazy - I should have set up a studio scene though couldn't be buggered really at this stage! Dam that lazy!
                                  BUILTBRAND.COM.AU
                                  • RichardR Offline
                                    Richard
                                    Here is that case a little more developed!
                                    The concept is generally to maximise air flow, cooling and functionality of modular spaces to maximise opportunity for upgradeability! Also given each space is same sized, the option (with some clever considerations) to reorganise the layout or change use configurations might exist.
                                    BUILTBRAND.COM.AU
                                    • arail1A Offline
                                      arail1
                                      I ordered a new computer recently and while doing research I came across this case which might offer some ideas about arranging components:
                                      http://www.slashgear.com/thermaltake-level-10-pc-case-with-bmw-designworks-0636768/
                                        arail1. That's a cool looking tower but I see a lot of time spent dusting.
                                        • RichardR Offline
                                          Richard
                                          Yeah I've always thought that of the level 10 dave! Plus I just dont see how it can be so designed for airflow and cooling, sure it has some features though those features themselves create these limits!
                                          BUILTBRAND.COM.AU
                                          • arail1A Offline
                                            arail1
                                            I don't understand cooling with the Level 10 either. It shows up on acousticpc.com - a site dedicated to quiet PC components - so maybe it just gets hot! You'd almost have to have a fan sitting next to it, blowing at it from the side, to keep it cool.
                                            Your overall design is much sleeker and way cooler. I only posted the Level 10 assuming it might be worth looking at for the arrangement of the components. But your base, the symmetry of your design, the upgrade ablility - all blow the 10 out of the liquid cooling water.
                                            • 2 / 2
