    New PC tower design
    38 Posts 15 Posters 2.1k Views 15 Watching
    • RichardR Offline
      Richard
      Ordering a new PC this month and looking for cases have found it is hard to find a case that becomes a furniture piece so I decided to start designing one! (until the next export crashed SU before I saved the model) so to start again.
      I looked at so many cases to find a nice one and they just don't exist excepting maybe the level 10 or the new level 10 GT.
      This one I might spend the time to see through to a full design - not to be built but at least fun. I've already put a deal of thought into the functionality which see the feet, handle and main A frame as a sandwich of two pressed sheets. By providing the dual sheets enough rigidity to the frame would allow the cantilever of MB, PSU and Drive bay rack as hander plates. This would allow for the whole unit to be built and handled prior to the fixing of modular covers.
      The front lower panel is a washable filter as the vertical centre panel on the left with a cable routing cover on the right side. The rear end is recessed with a full grill / filter / cover with cable outlets at base - this to filter and cover rear connectors on route to ground or side.
      I've looked at the Level 10 for some time and think they were so close but still see it as an over engineered dust collector. And one with so called airflow designed in yet it seems to want for bucket loads more!
      I'm going to try and create a very light feel and reality by introducing more "wearing of structure” to the panels - as if it proudly wears it's light weight pressed metal construction. Also to get rid of the 40,000 drive bays normal with large cases and max out airflow. The light base I hope also helping sound reduction by limiting noise transfer to the floor with a normal solid footing. HD Drive bay and media bays still x 7 as 3 SSD bays within the front lower (placed sideways) whilst keeping that large void for flow or if it could be configured 1 or 2 vertical rack mounted Micro ATX MB’s as render nodes.
      The PSU is located top rear so the CPU is lower to take advantage of this increased flow. Still some work to do on the feet / support.
      In the end I'd just love one! We can dream!
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
        liam887
        Looks nice, maybe sketchup 20 will come with a 'Print' plugin sends your designs straight to a factory and then back to you. Speaking of interesting towers while not a PC I love this design:
        http://www.boxee.tv/
        VISIT MY ONLINE GALLERY
          d12dozr
          Neat design, Richard...you could get it 3D printed in titanium or even gold in the near future...if you had Donald Trump's salary 😄
          ~$124 USD/cubic cm for titanium! 😮
          http://goo.gl/f7ooYh
          • RichardR Offline
            Richard
            PER CUBIC CM?? WTF?
            My god mate. yep donald trump! May be i should change the size!
            • jeff hammondJ Offline
              plus, since there's no tower, it frees up space for an actual piece of furniture..
                KarinaGM
                Well you don't need to print it. You can take the images and prints to someone who works metal...
                I'm sure, that way could be affordable. Not cheap, but payable at least LOL
                Nice design 👍
                Is the feet stable enough? you don't want to accidentally kick it or bend it.
                **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                -Benjamín Franklin.**
                • RichardR Offline
                  Richard
                  It still would be very expensive I think to knock out a one off. So to dream for now! And then their are the plastic items and clips etc that one would need.
                  Here is a workstation size unit with a bit more an industrial look. Thinking of a way to lock / lift the right side feet to expose wheels to assist transport.
                  • RichardR Offline
                    Richard
                    Nice design 👍
                    Mate I still haven't completely determined the feet! I need to consider how they are pressed to get the rigidity needed.
                    • Bryan KB Offline
                      Looking good.
                      • soloS Offline
                        Cool looking rigs mate.
                        I'd suggest the legs be in a material that non conductive, just incase someone wants it on a carpet (learned that expensive lesson once, static electricity fries chips)
                          wait, grounding wouldn't prevent problems?
                          my tower is all metal and though i don't place it on the carpet, i don't think apple would sell them if carpet&static electricity would cause issues.
                          • PixeroP Offline
                            Pixero
                            Just a question, wouldn't the "waist" make it hard to fit the motherboard and fan for the processor?
                            Also I believe it might reduce airflow inside.
                              Richard, assuming that you've sorted out Jan's question about fitting the motherboard, I'm thinking you could find someone locally to bend that out of some sheet metal for not an awful lot of money. Have it done in aluminum or stainless steel and skip the paint. Or look around for someone who does powder coating to paint it. Standard paint colors like white or black would be inexpensive.
                              What if you combine some wood with the metal case? Black case and maybe maple for the feet and the handle at the top?
                                mac1
                                Built my own computer few years ago. Much more important than the outside look is the inside.. You have the power supply, the cabling and the PIN outs, most have the EMI shields and the foot print holes for the industry spec mother boards, drive rails, all the cooling tunnels etc.and the all the mounting hardware( 100's of parts). I bought an ANTEC SonataII and think it has a nice look when the door is closed. This can be a huge design under taking
                                • RichardR Offline
                                  Richard
                                  Mate the actual box is BIG! The tummy band is the same width as a normal box! The drive bays arn't in proportion! This overcomes a lot of Mac1's concerns too! Ample room is allowed for all!
                                  Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case.
                                  The WS case (second version posted) I consider I'd love to house s cheap simple sandybridge render node/s later - all in the one case - hence the size!
                                  • RichardR Offline
                                    Richard
                                    Dave R, mate I did on the weekend play further to simplify the whole legs and outer case setup and also to consider how simply it could be made from really simple sheet work and much of the internals modded from another case. I like the timber idea - though has it's issues. I like the idea of such a case sitting next to a RedBull F1 car in the pits hence a little it's case design.
                                      mac1
                                      Are you building a computer or furniture??
                                      IMO designing then building the computer is the first effort. You can then jazz it up with a fancy enclosure if you so desire with fans, ups retractable tops etc, etc. I made my design big to start with for several reasons. PC junction temp is the driver for life so good cooling to keep the delta T down is most important. Second I wanted to be able to modify easily so when our MS, Intel friends make changes and OEM guys want us to buy a new PC mine is just an upgrade. It is getting old now, about 5 years, but had a 3.2GHZ CPU for that time. No PCI express so that maybe the next step or wait for next major step which will probably be to get rid of all the cables and have one optical interface=> not external cable races etc. HEY!!! Flexibility should be the name of the game.
                                      • RichardR Offline
                                        Richard
                                        Mate I understand all you are saying!!
                                        Here is a bit of an evolution on the design, with slide out dust filters and slide out cable store.
                                        Also a crap rendered version with the cover in plastic to see the interior layout 1366 socket board left / 1155 socket right (render node) - Radiators centre.AutoSave_NEW-PC1.jpgCASE-explode.jpg
                                          I like it. SO it is almost the size of four PC cases? Lots of room for expansion and cooling.
                                          • W Offline
                                            watkins
                                            Dear Richard,
                                            Don't forget to look here for bits and pieces:
                                            http://scc.jezmckean.com/home
                                            Regards,
                                            Bob
