    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.0m Views 329 Watching
      I didn't have any trouble with the GTO mat. See here: http://forums.sketchucation.com/viewtopic.php?f=15&t=33033&p=291297#p291297
      http://farm5.static.flickr.com/4085/5223519926_1d4e3b2b5a.jpg
        jorge.cubells
        @chris fullmer said:
        @jorge, looking at your model, I think I got a good result from it. Please download my model and look at it. I flipped the component up, and then moved the line to be directly under it. Shape bender will offset the final shape from the bending shape by the same distance that the component is offset from the straight line. So since you want to bend exactly to the shape of the bent shape, then the component needs to be directly on top of the straight line.
        I can make a video that explains it better if the model came out right.
        Hope it helped,
        Thank you, Dave and Chris.
        It works when the curve is parallel to the green-red plane (see snapshot).
        But, why the curve on the left (parallel to the blue-red plane) did work?
        The second and third pictures might give you a clue:
        if the curve has angles > 90 degrees it bends ok.
        Ignores if angles = 90 deg.
        And changes directions if < 90.
        My problem is solved. I will flip up the entire model (as it should have always been). Thanks again.
        • Chris FullmerC Offline
          Hi Jorge, I hope yougot it all sorted out (sorry I forgot to upload my model!). Yes, flipping up on its end is the solution. It is all in the way Shape bender works. You have to realize shape bender is only the 3rd or 4th piece of code I've ever really written. So it is pretty good, but it is not as smart as it could be. There are certain things it was designed to do a certain way. I wrote it to wrap text onto the face of a curved wall. So it always expects the curve to lie flat on the ground. Even if you're curve is should stand up, you need to rotate it to lie flat on the ground. Lots of the logic behind how shape bender bends things is actually based on a 2d groundplane. It can handle 3dpaths sometimes, but it really is meant for 2d bending.
          Maybe the Pro version someday will be a bit more intelligent on how to follow any given bending path.
            recepkum
            i have a problem with the tool. the bar was loaded, but it doesn't work selecting the first line and the second arc!! when selecting the group, then i click the shape bender tool but there must be a line appear under the arrow. but not.
            what is the problem?
            the error in ruby console
            Error: #<TypeError: no implicit conversion from nil to integer>
            C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:168:in set_cursor' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:168:in onSetCursor'
            C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:176:in `onMouseMove'
              mc3ledonia
              I am just having a small problem. I only looked back a few pages, but I didn't see anybody else with the same issue. Basically, after selecting the line and curve, shapebender doesn't do anything. It puts the start/end on both ends of the line and curve, but wont bend the shape. The shape is a basic rectangular prism and is a component. Hopefully I am not overlooking a basic step!
                After it places the start and end tags, you need to press enter. That might be all it is. Hope that solves it, if not, let me know!
                  mc3ledonia
                  Oh wow, after double checking I had forgotten I am on a different PC without Progress Bar. That was the reason πŸ˜’ Thanks for the quick response Chris!
                    diacovoni
                    I have downloaded bender and have used it a couple of times, however it does not curve the ends of the box as it shows on your video tutorial. I am actually bending text, but have used it on a rectangular box as well. Both curve but keep all of the vertical ends at 90 degrees to the original line and do not curve. Are there settings for this that I am not aware of? Also if it matters my straight text was already rotated vertically to be placed on a building facade. Does this matter?
                    diacovoni
                      diacovoni
                      I tried to post this earlier, but couldn't find it so sorry it it is in here twice. I have downloaded Shape bender and I have successfully used it on a rectangular box and text, however in both cases the ends of the box and text stay perfectly vertical and do not have a radial curve as shown in the video tutorial. Is there a setting that adjusts this?
                      diacovoni
                        Hi there, sorry your post took so long to get approved. I think we (the moderators) are on vacation mode a little. We try to get them approved quickly, but today it is taking a quite a few hours.
                        Well, I am not exactly sure what the problem is. Do you have an image to describe it? My guess is that you are experienceing a known fault with the plugin. It does not bend the first and last segments the same amount as the rest of the segments in the curve. It does this for a few technical reasons - sometiems it is the correct bending solution. But sometimes it is not. So if you post a picture of what you are experiencing, I'll look at it and I'll tell you if it is this same problem. IF it is, there is a bit of a workaround you can try that includes adding an extra segment to the arc in the beginning and the end.
                        PS I'm on vacation until Jan 3rd, so I might be slow-ish to respond.
                          diacovoni
                          I think I figured it out. My text was already rotated vertically on the wall. I read some previous posts where it indicated the script was based on the horizontal red green axis. I placed my text flat on the ground and then had no problem with the curve. All I needed to do after that was rotate it vertically to place on the wall.
                          Thanks for the response. Hope this helps others in the same situation.
                          diacovoni πŸ˜„
                          • X Offline
                            xtr3mx7
                            Hello, I am a new user and while running the script, I am not able to select any line, be it single straight or curve.
                            Pls find below the ruby console output:
                            Error; #<TypeError; can't convert nil into String>
                            C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;161;in `create_cursor'
                            C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;161;in `make_cursors'
                            C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;131;in `activate'
                            C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;1017;in `select_tool'
                            Thanks in advance.
                              Thanks in advance.
                              It seems it's not finding ../Plugins/clf_shape_bender/curve_pointer.png - you should have these files in the 'clf_shape_bender' subfolder inside Plugins...Capture.PNG
                                arjunmax09
                                Hello everyone..
                                I'm using Google SketchUp Pro 8 . I am unable to make a ramp using shape bender that is 34 metres long and has 1:10 slope. The Shape Bender doesn't bend the ramp as expected. I've attached a video and a model of the ramp.
                                Ramp problem.rar
                                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                • numbthumbN Offline
                                  numbthumb
                                  How about this?
                                  Comfortably numb...
                                    Arjun,
                                    I think the problem comes in that there needs to be some distortion in the top surface which shape Bender doesn't do. I think NumbThumb's suggestion is a good one. I did it manually because I wanted to see how the shape develops but I think the plugin would be much faster.
                                    http://farm6.static.flickr.com/5045/5290313722_16e1a20be2.jpg
                                    http://farm6.static.flickr.com/5130/5290313788_1952597cc1.jpg
                                    Is this what you want as a result?
                                      arjunmax09
                                      yes i want a ramp like this only..is the edge on the end coming out to be 3.4 metres in height??
                                        Yes, it is the same height as the straight ramp you had drawn in the file.
                                        It's on my computer at home and I'm not there at the moment. I could send it to you or post it when I get back.
                                          arjunmax09
                                          but isn't there an effective way to make the ramp i'm making using shapebender?? πŸ˜’
                                          • X Offline
                                            xtr3mx7
                                            Thank you TIG for providing the solution. The plugin now works perfectly πŸ˜„
                                            This is indeed a very great script. Big cheers to Chris πŸ˜„
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 63
                                            • 64
                                            • 33 / 64
