    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.1m Views 329 Watching
      recepkum
      i have a problem with the tool. the bar was loaded, but it doesn't work selecting the first line and the second arc!! when selecting the group, then i click the shape bender tool but there must be a line appear under the arrow. but not.
      what is the problem?
      the error in ruby console
      Error: #<TypeError: no implicit conversion from nil to integer>
      C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:168:in set_cursor' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:168:in onSetCursor'
      C:/Program Files/Google/Google SketchUp 8/Plugins/clf_shape_bender.rb:176:in `onMouseMove'
        mc3ledonia
        I am just having a small problem. I only looked back a few pages, but I didn't see anybody else with the same issue. Basically, after selecting the line and curve, shapebender doesn't do anything. It puts the start/end on both ends of the line and curve, but wont bend the shape. The shape is a basic rectangular prism and is a component. Hopefully I am not overlooking a basic step!
        • Chris FullmerC Offline
          After it places the start and end tags, you need to press enter. That might be all it is. Hope that solves it, if not, let me know!
            mc3ledonia
            Oh wow, after double checking I had forgotten I am on a different PC without Progress Bar. That was the reason πŸ˜’ Thanks for the quick response Chris!
              diacovoni
              I have downloaded bender and have used it a couple of times, however it does not curve the ends of the box as it shows on your video tutorial. I am actually bending text, but have used it on a rectangular box as well. Both curve but keep all of the vertical ends at 90 degrees to the original line and do not curve. Are there settings for this that I am not aware of? Also if it matters my straight text was already rotated vertically to be placed on a building facade. Does this matter?
              diacovoni
                diacovoni
                I tried to post this earlier, but couldn't find it so sorry it it is in here twice. I have downloaded Shape bender and I have successfully used it on a rectangular box and text, however in both cases the ends of the box and text stay perfectly vertical and do not have a radial curve as shown in the video tutorial. Is there a setting that adjusts this?
                diacovoni
                  Hi there, sorry your post took so long to get approved. I think we (the moderators) are on vacation mode a little. We try to get them approved quickly, but today it is taking a quite a few hours.
                  Well, I am not exactly sure what the problem is. Do you have an image to describe it? My guess is that you are experienceing a known fault with the plugin. It does not bend the first and last segments the same amount as the rest of the segments in the curve. It does this for a few technical reasons - sometiems it is the correct bending solution. But sometimes it is not. So if you post a picture of what you are experiencing, I'll look at it and I'll tell you if it is this same problem. IF it is, there is a bit of a workaround you can try that includes adding an extra segment to the arc in the beginning and the end.
                  PS I'm on vacation until Jan 3rd, so I might be slow-ish to respond.
                    diacovoni
                    I think I figured it out. My text was already rotated vertically on the wall. I read some previous posts where it indicated the script was based on the horizontal red green axis. I placed my text flat on the ground and then had no problem with the curve. All I needed to do after that was rotate it vertically to place on the wall.
                    Thanks for the response. Hope this helps others in the same situation.
                    diacovoni πŸ˜„
                    • X Offline
                      xtr3mx7
                      Hello, I am a new user and while running the script, I am not able to select any line, be it single straight or curve.
                      Pls find below the ruby console output:
                      Error; #<TypeError; can't convert nil into String>
                      C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;161;in `create_cursor'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;161;in `make_cursors'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;131;in `activate'
                      C;/Program Files (x86)/Google/Google SketchUp 8/Tools/clf_shape_bender/clf_shape_bender.rb;1017;in `select_tool'
                      Thanks in advance.
                        Thanks in advance.
                        It seems it's not finding ../Plugins/clf_shape_bender/curve_pointer.png - you should have these files in the 'clf_shape_bender' subfolder inside Plugins...Capture.PNG
                          arjunmax09
                          Hello everyone..
                          I'm using Google SketchUp Pro 8 . I am unable to make a ramp using shape bender that is 34 metres long and has 1:10 slope. The Shape Bender doesn't bend the ramp as expected. I've attached a video and a model of the ramp.
                          Ramp problem.rar
                          when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          • numbthumbN Offline
                            numbthumb
                            How about this?
                            Comfortably numb...
                              Arjun,
                              I think the problem comes in that there needs to be some distortion in the top surface which shape Bender doesn't do. I think NumbThumb's suggestion is a good one. I did it manually because I wanted to see how the shape develops but I think the plugin would be much faster.
                              http://farm6.static.flickr.com/5045/5290313722_16e1a20be2.jpg
                              http://farm6.static.flickr.com/5130/5290313788_1952597cc1.jpg
                              Is this what you want as a result?
                                arjunmax09
                                yes i want a ramp like this only..is the edge on the end coming out to be 3.4 metres in height??
                                  Yes, it is the same height as the straight ramp you had drawn in the file.
                                  It's on my computer at home and I'm not there at the moment. I could send it to you or post it when I get back.
                                    arjunmax09
                                    but isn't there an effective way to make the ramp i'm making using shapebender?? πŸ˜’
                                    • X Offline
                                      xtr3mx7
                                      Thank you TIG for providing the solution. The plugin now works perfectly πŸ˜„
                                      This is indeed a very great script. Big cheers to Chris πŸ˜„
                                      • U Offline
                                        unclex
                                        thanx this wonderful Plugin
                                        but it can not work with TIG's [HolePunchTool] Plugin, if punch was loaded, run Bender, SU would Crashed...
                                          I am working on it... πŸ˜• πŸ˜’
                                          • U Offline
                                            unclex
                                            ThanX
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 63
                                            • 64
                                            • 33 / 64
