    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] Toggle Units
    159 Posts 47 Posters 116.5k Views 47 Watching
    • kenK Offline
      ken
      @matt666 said:
      Hi all.
      Sorry for the problems, and I don't have any time to search a solution... My work takes me a lot of time.
      I will try to see what does not work with this new SU update.
      Be patient please...
      Matt
      I know work. Was busy until recently. So now I was presented with some down time and in the process of trying to take care of some problems I had let slip. Food and shelter is always first on my list. So Matt666, let me thanks you for the script again.
      blajnov, thank you for the updated. Not sure why I couldn't find this update on the site, but I couldn't. The scrip now works just like it did before. Not my plugin or my site, but maybe this update should go to the front of the topic. Anyway, again, thanks to all that helped.
      Now lets hope the new cap works and work can start again.
      Ken
      • Z Offline
        Zante
        Please make your original post clearer (if editing is allowed on this forum).
        2 files, same file name, no version control = confusion
          RootlessAgrarian
          @matt666 said:
          Here is the script.
          Toolbar to change drawing units quickly.
          Hi -- I may not be understanding what this tool does, or how units work in Sketchup; I am frustrated because I can't do what seems to me a simple thing.
          Here is the deal. I am working on a model in non-metric units (feet and inches). But I have paper sketches from a colleague in Norway who has annotated his drawings in decimal meters. I'd like to reproduce his hand drawing directly into my model by copying it exactly, so I'd like to work on a set of components in meters or mm. To my surprise I could find nothing in Preferences for toggling from metric to inch and back. So I thought that Toggle Units plugin might enable me to switch the whole model from inch to mm or cm.
          I installed it. But it seems to toggle units only between different representations of inches (the first 4 buttons); the other buttons (mm, cm, mt) are grayed out and inactive. I really want to toggle between metric and inch -- is there no way to do this? it seems such an obvious thing to want to do ๐Ÿ˜„ argh. would rather not have to use a unit converter and manually convert all the dims on my colleague's drawing!
          btw I am aware that I can draw in any units I like, i.e. enter dimensions in notation like "3.0m". what I cannot do is use the Ruler tool to verify those dimensions after drawing, because the ruler is apparently hard-wired to inch units. if I could just toggle the Ruler between inch and metric that would be great!
          any ideas would be gratefully received as this has got me bogged down right at the start of the project.
          Nothing is 'mere'. -- Richard Feynman
            RootlessAgrarian
            @rootlessagrarian said:
            @matt666 said:
            Here is the script.
            I read backwards in this thread and found that others have had some trouble with Leopard (OSX) and this plugin. I grabbed a more recent version edited by Jim Foltz Oct 2009 and installed that.
            The Foltz version works except that the icons do not display: this I thought was because the icon paths were all set to CD_ICONS/TWEAK, but I substituted the correct path "toggle_units_icons" and I still get no icons in the toolbar. So I have to memorise the button sequence or wait for the balloon help to pop up ๐Ÿ˜„ but the tool now does exactly what I was hoping for: my ruler can be toggled to work in inches or meters, hooray.
            If anyone can tell me why these lines of code
            cmd.small_icon = "toggle_units_icons/tudec16.png"
            cmd.large_icon = "toggle_units_icons/tudec24.png"
            do not correctly association the png files with the button, I'd like to know (I don't speak Ruby obviously). meanwhile I'll happily use the version with anonymous blank buttons -- project no longer stalled!
            • CadFatherC Offline
              CadFather
              the lines make sense if you have the corresponding folder (toggle_units_icons) in the plugins menu..
              • CAntonisC Offline
                CAntonis
                Matt this is great!!!
                Very nice plugin!
                ThankU
                CAntonis
                  RootlessAgrarian
                  plugins menu? or plugins directory (folder)?
                  that subdir does exist in the plugins directory (as do other subdirs of small images used successfully by other Ruby extensions). can't figure out why the images are not getting associated with the buttons. but hey, the unit switching function works and that's what I needed. I can fool around with the icons later.
                    CadFather
                    sorry.. ๐Ÿ˜ณ i meant plugins folder of course..
                    if the path is right the icons should show up
                      RootlessAgrarian
                      as I say I do not speak Ruby, but I used to be extremely literate in Tcl/Tk and the syntax is not completely alien. I have tried various things, even using the full pathname. other .rb scripts are correctly finding their icons w/rel pathname starting at 'plugins', but this one for some reason is not. mysterious! I've looked for some initialisation that might set the default path, etc -- no luck so far. must be a very silly coding error that I can't see because I'm so unfamiliar with Ruby apps.
                      checked the obvious like protection bits on subdir and images, checked that they really are .pngs, checked that they are not empty files, etc. baffled.
                      oh well. something to fool with when I've nothing more urgent to do ๐Ÿ˜„
                      • V Offline
                        vidy
                        Have the same problem here also, the function was working perfectly, but the icon are invisible.. need some advice, please...
                        thanks,
                        still so much to learn..
                          chrisjk
                          What versions of Mac OSX are you running? I have Snow Leopard and the icons do show up for me. You might need to check View>Tool Palettes>Toggle Units to see them.
                          • V Offline
                            vidy
                            im using xp sp2, and su 7.1, the tool actually already perfectly functional, just the icon not showed up..
                            already try to change the address on the script, but it still not working. ๐Ÿ˜’
                            • W Offline
                              watkins
                              Just tried installing Toggle Units into my SU8 plugin folder, and found that the icons won't show up. Is this a known problem for SU8? If so, does anyone have a fix?
                              Kind regards,
                              Bob
                                When you extracted the contents of the zip file you should have got a file called toggle_units.rb and a folder called toggle_units_icons which contains 24 png files to make the various buttons.
                                The file and the folder both go into your Plugins folder.
                                If you have copied the rb file from v7 into v8 you must also copy the whole folder and its files too... ๐Ÿ˜•
                                • W Offline
                                  watkins
                                  Dear All,
                                  Okay, Toggle Units is now working in V8, but only after installing the version posted by 'blajnov' (page 6 of this thread, and near the top).
                                  Kind regards,
                                  Bob
                                    davidlouis
                                    Not wanting to discourage the development of great tools such as this, I can't help wonder why, so far down the line in sketchup development, you can't have one preference for modelling units and a different one for the value readout of say... areas, dimensions etc etc... CAD software has been doing this since day one...
                                    At the moment I model in millimeters and require dimensions and areas in meters... I've used this tool since it pretty much came but why don't the skp developers integrate this into the preferences / model info units interface...???
                                    Either way thanks for a great tool! ๐Ÿ‘
                                    Dave
                                    • V Offline
                                      vidy
                                      @watkins said:
                                      Dear All,
                                      Kind regards,
                                      Bob
                                      dear bob,
                                      do you have the icon showed up on v.8?
                                      • W Offline
                                        watkins
                                        Dear Vidy,
                                        Yes I do, and I have checked all the functions and they work. It would be very useful if someone could update the first posting with the V8 compatible plugin.
                                        Regards,
                                        Bob
                                          I have updated the first post in the thread http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                                          Please use the new 'bold' version which is v6/7/8... friendly - I left the old one BUT I don't recommend that version at all...
                                          • V Offline
                                            vidy
                                            thanks bob and tig, now it works perfectly
                                            • 7 / 8
