    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
    • CadFatherC Offline
      CadFather
      try with these: toggle_units.zip
      • EdsonE Offline
        Edson
        max, what problems is this new version supposed to solve? the copy I have installed works fine but for one thing: the buttons stay depressed even when you press a different one. by the way, I am on mac running the latest snow leopard.
        http://www.mahfuz.arq.br
          CadFather
          EDIT: if using SU 7.1, install the 2 files inside the zip (thanks to Jim)
          toggle_units.zip
          Matt, Thank you for this! 😄
          one question.. how can i assign a keyboard shortcut to one of them? or is it not possible?
          also, the units redraw only when i click on the screen or (press the esc key) - is that to do with screen refresh? if so is there any way to make it refresh automatically?
            CadFather
            unfortunately i have no knowledge of macs so i'm not able to test - on my pc once the 'dec' is enabled the icons stray pressed when selected..
            • kenK Offline
              ken
              @cadfather said:
              try with these: [attachment=0:xryojohw]<!-- ia0 -->toggle_units.zip<!-- ia0 -->[/attachment:xryojohw]
              CadFather
              Somehow I missed this post. So today I tried this post. I now have a toolbar with no icons showing. It seems the icon should now be in another directory. I haven't moved the icons until I know this is what is at fault.
              Also, after selecting Fract in the plugin menu, the plugin stop working until I select to top selection.
              So was the attachment you had posted, was that for my problem or a MAC issue.
              And what happen to Matt666?
              Would like some help, I find this a very valuable plugin.
              Thanks in advance.
              Ken
                Matt666
                Hi all.
                Sorry for the problems, and I don't have any time to search a solution... My work takes me a lot of time.
                I will try to see what does not work with this new SU update.
                Be patient please...
                Frenglish at its best !
                My scripts
                • simon le bonS Offline
                  simon le bon
                  Dear Matt,
                  So glad to see you back on the block 👍 👍 😉
                  *s
                    blajnov
                    Is there anyone else that is having trouble with this plugin with Sketchup 7.1.6860. It will change the precision but not the units.
                    Thanks in advance.
                    Ken
                    Here's the working version. 👍
                    SketchUp Pro 7.1.6860
                    OS Windows 7 PC
                    toggle_units.zip
                    • kenK Offline
                      ken
                      @matt666 said:
                      Hi all.
                      Matt
                      I know work. Was busy until recently. So now I was presented with some down time and in the process of trying to take care of some problems I had let slip. Food and shelter is always first on my list. So Matt666, let me thanks you for the script again.
                      blajnov, thank you for the updated. Not sure why I couldn't find this update on the site, but I couldn't. The scrip now works just like it did before. Not my plugin or my site, but maybe this update should go to the front of the topic. Anyway, again, thanks to all that helped.
                      Now lets hope the new cap works and work can start again.
                      Ken
                      • Z Offline
                        Zante
                        Please make your original post clearer (if editing is allowed on this forum).
                        2 files, same file name, no version control = confusion
                          RootlessAgrarian
                          @matt666 said:
                          Here is the script.
                          Toolbar to change drawing units quickly.
                          Hi -- I may not be understanding what this tool does, or how units work in Sketchup; I am frustrated because I can't do what seems to me a simple thing.
                          Here is the deal. I am working on a model in non-metric units (feet and inches). But I have paper sketches from a colleague in Norway who has annotated his drawings in decimal meters. I'd like to reproduce his hand drawing directly into my model by copying it exactly, so I'd like to work on a set of components in meters or mm. To my surprise I could find nothing in Preferences for toggling from metric to inch and back. So I thought that Toggle Units plugin might enable me to switch the whole model from inch to mm or cm.
                          I installed it. But it seems to toggle units only between different representations of inches (the first 4 buttons); the other buttons (mm, cm, mt) are grayed out and inactive. I really want to toggle between metric and inch -- is there no way to do this? it seems such an obvious thing to want to do 😄 argh. would rather not have to use a unit converter and manually convert all the dims on my colleague's drawing!
                          btw I am aware that I can draw in any units I like, i.e. enter dimensions in notation like "3.0m". what I cannot do is use the Ruler tool to verify those dimensions after drawing, because the ruler is apparently hard-wired to inch units. if I could just toggle the Ruler between inch and metric that would be great!
                          any ideas would be gratefully received as this has got me bogged down right at the start of the project.
                          Nothing is 'mere'. -- Richard Feynman
                            RootlessAgrarian
                            @rootlessagrarian said:
                            @matt666 said:
                            Here is the script.
                            I read backwards in this thread and found that others have had some trouble with Leopard (OSX) and this plugin. I grabbed a more recent version edited by Jim Foltz Oct 2009 and installed that.
                            The Foltz version works except that the icons do not display: this I thought was because the icon paths were all set to CD_ICONS/TWEAK, but I substituted the correct path "toggle_units_icons" and I still get no icons in the toolbar. So I have to memorise the button sequence or wait for the balloon help to pop up 😄 but the tool now does exactly what I was hoping for: my ruler can be toggled to work in inches or meters, hooray.
                            If anyone can tell me why these lines of code
                            cmd.small_icon = "toggle_units_icons/tudec16.png"
                            cmd.large_icon = "toggle_units_icons/tudec24.png"
                            do not correctly association the png files with the button, I'd like to know (I don't speak Ruby obviously). meanwhile I'll happily use the version with anonymous blank buttons -- project no longer stalled!
                              CadFather
                              the lines make sense if you have the corresponding folder (toggle_units_icons) in the plugins menu..
                              • CAntonisC Offline
                                CAntonis
                                Matt this is great!!!
                                Very nice plugin!
                                ThankU
                                CAntonis
                                  RootlessAgrarian
                                  plugins menu? or plugins directory (folder)?
                                  that subdir does exist in the plugins directory (as do other subdirs of small images used successfully by other Ruby extensions). can't figure out why the images are not getting associated with the buttons. but hey, the unit switching function works and that's what I needed. I can fool around with the icons later.
                                    CadFather
                                    sorry.. 😳 i meant plugins folder of course..
                                    if the path is right the icons should show up
                                      RootlessAgrarian
                                      as I say I do not speak Ruby, but I used to be extremely literate in Tcl/Tk and the syntax is not completely alien. I have tried various things, even using the full pathname. other .rb scripts are correctly finding their icons w/rel pathname starting at 'plugins', but this one for some reason is not. mysterious! I've looked for some initialisation that might set the default path, etc -- no luck so far. must be a very silly coding error that I can't see because I'm so unfamiliar with Ruby apps.
                                      checked the obvious like protection bits on subdir and images, checked that they really are .pngs, checked that they are not empty files, etc. baffled.
                                      oh well. something to fool with when I've nothing more urgent to do 😄
                                      • V Offline
                                        vidy
                                        Have the same problem here also, the function was working perfectly, but the icon are invisible.. need some advice, please...
                                        thanks,
                                        still so much to learn..
                                          chrisjk
                                          What versions of Mac OSX are you running? I have Snow Leopard and the icons do show up for me. You might need to check View>Tool Palettes>Toggle Units to see them.
                                          • V Offline
                                            vidy
                                            im using xp sp2, and su 7.1, the tool actually already perfectly functional, just the icon not showed up..
                                            already try to change the address on the script, but it still not working. 😒
                                            • 4 / 8
