    SU upgrade to 8.0.4811 (Maintenance 1)
    108 Posts 42 Posters 40.2k Views 42 Watching
      @andrews said:
      Those who brought the /LARGEADDRESSAWARE flag to our attention touted it as a magical cure-all. Indeed, we had high hopes that it would make a marked impact for those folks who really want to work with much larger files; we invested quite a lot of work in turning that flag on, ensuring we had done it correctly and consistently throughout SketchUp, and testing the results. Unfortunately, in the specific case of compiling and linking it into SketchUp, Style Builder and LayOut, that flag is more snake oil than miracle cure.
      The people who will benefit the most from this are probably render engine users, like me. Some render engines run inside the SU process. Previously you'd be in trouble if you rendered large files as things would crash when memory usage creeped up to 1.8GB. I had found a utility to change the LAA flag in SU8M0 and that had saved me a few times when I had to squeeze out some larger renders. I'm glad it's not LAA out of the box and I don't have to use hacks to enable it. The extra 2GB availible has helped greatly.
      • PixeroP
        Pixero
        Wow, I'm impressed. Shadow bug fixed and toolbars and large adress aware too...finally I will consider upgrading to v8.
        • G
          geomp
          I'm impressed! A proper release that appears to solve real problems, I can't wait to try it out!
          Thanks,
          Paul
            rv1974
            For me this point release have more pleasant stuff than v.8 itself.
            Thank you google team. I just wonder is it (partly?) a reaction to the cold wave of criticism toward v8?
            • P
              Panga
              I have some issues with this update :
              I reduced my Sketchup Window in order to test the toolbars, then maximised the window, go to View > Toolbars > Restore position of toolbars : the position of toolbars is right, but there's many icons which disapeared !! For example, my Sandbox toolbar only show the tow first icons !! And the same thing on many other toolbars.
              Anyone encountered the same issue ??
              Regards.
                I have experience that. Not sure when/why that happens. Doesn't happen all the time.
                  alpro
                  Good job Google, I downloaded the 8 demo when it was first released, didn't see much reason to upgrade, till now. Now if only we could get some better texturing tools........poor Google, it's never enough.
                  Mike
                    AlexMozg
                    The bugs noted by me:
                    SketchUp 8 Bugs: http://forums.sketchucation.com/viewtopic.php?f=180&t=30583
                    • O
                      otb designworks
                      Shadow bug fixed?! Are you kidding me? Is it Christmas all over again?
                      Seems like a really nice and comprehensive update and that brings joy to my heart.
                      Thanks to the developers for all their hard work!
                      Cheers, Chuck
                      OTB Designworks is on Youtube
                      • V
                        valerostudio
                        Do you need to uninstall and reinstall if you are using 64bit Windows? The older 8.0 is installed in the x86 Program Files. Will this prevent SU from using 64 bit?
                          Your completely safe to install without uninstalling your current version. No plugins, components, materials etc. will be messed around.
                          Happy Sketching πŸ‘
                          • V
                            Vicspa
                            I just updated, luckily I saved a copy of the plugins folder because it replaced it with the basic one. So all is back to normal.
                              ...that is kind of worrying, I didn't experience this but if you've doubts follow Vicspa's advice
                              • V
                                Vicspa
                                If in doubt,....always have a backup ready. It would take me quite some time to replace all the plugins.
                                Time I'd rather spend practicing SU.
                                  SketchUp is not 64bit. It's LargeAddressWare, but it is still 32bit.
                                  • bmikeB
                                    bmike
                                    It shouldn't have...
                                    Updated just fine here and my Plugins were intact...
                                      I've never had it replace it.
                                      Did you update from SU7? In which case I created a brand new folder, leaving the old SU7 alone.
                                      • V
                                        Vicspa
                                        bmike, I'm always amazed how an installation like this can differ between people. I'm on a PC by the way.
                                        But now that I'm thinking about it, I placed the plugins folder on the desktop, and copied it back after the new installation,
                                        that's why it remade a new plugin folder. Sorry I wasn't so clear before. (senior Moment. ) 😳
                                        • jujuJ
                                          juju
                                          TBH, I didn't have much hope for SU with the original version 8 introduction. I have to say that attitude has changed with the release of maintenance 1. I will gladly give my $95 for the upgrade from SU7 to SU8 now. Thanks to the team at Google that made this work.
                                          • boofredlayB
                                            boofredlay
                                            Holy crap, is that you Julian... really? πŸ˜„
                                            • 2 / 6
