    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 37.4k Views 28 Watching
    • N Offline
      notareal
      In general (don't have much experience with vue) displacement does require a good mesh topology. Something like this if triangulated (quad faces are even better). Perhaps need more sub divs.
      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
        Why are quad-faces better than triangles?
          What Solso asked there - turning a mesh into quads - I recently replied to a similar thread where I mentioned that Quad faces in other applications are often different in that they are not limited to being co-linear. Internally they are triangulated, it's just the application that treats two triangles as a quad and simplifies the presentation tot he user so you get a more predictable mesh.
            Ah - that post was also from Solo... http://forums.sketchucation.com/viewtopic.php?f=323&t=33895&p=297883#p297883
            • N Offline
              notareal
              It's later more demanding to go from tris to quads, if you happen to export mesh to a program that uses quads.
              For rendering quads are not particular critical as most render engines do use triangulated meshes. But even then if mesh is triangulated and is not dense enough and render engine have some issue with geometry smoothing, smoothing artifacts may appear when "poles" or "spikes" are present. Using quads for modelling should prevent this, even if mesh is later triangulated. This topic might be good to look http://forums.sketchucation.com/viewtopic.php?f=18&t=33894
              I do believe that if Starlex where modelling with quads in the beginning, he would not had those displacement issues.
              • N Offline
                notareal
                Requirements for displacement are similar than in Subdivision Modeling (Displacement essentially needs to subdivide the original mesh). Considering SU limitations with quads, it might be best to model quad-like manner, like you suggest in the other topic, and then avoid need for co-planar quads. Anyhow, basic issue in earlier displacement problem is in the poor mesh topology.
                  Starlex
                  this is it, but I can't imagine how it will be with arcs...
                  • N Offline
                    notareal
                    If you know that you are going to use displacement, use some lofting tool like in this tutorial http://forums.sketchucation.com/viewtopic.php?f=18&t=34018 You will automatically get reasonable good topology.
                      JT Artifex
                      I've got a question about syncing objects between SU and Vue.
                      Is there a way to set things up so that the models exported from SU to Vue would update if the original SketchUp model was modified. I don't believe there is a way to link the sketchup file, but I have read that there is a synchronizing feature that should allow you to update modified objects.
                      So far I have been opening the .vob file created from the exporter and then saving the model as an object into my Vue library. Then I have access to it in Vue for any of my scenes. This is were the question came up... if I use it in a scene and then decide to modify it a bit, do I need to reopen it in Vue, overwrite it in the library and reload/replace it in the scene. Is there not a way for this to update itself... I even tried to just overwrite the object in the library and see if it would update once the scene was reopened but that did not seem to work either.
                      So when does the synchronizing of objects apply... is that only for certain file types of programs?
                      Thanks for any thoughts.
                        JT Artifex
                        So I managed to get the links feature to work...
                        If I save it as a obj. file and then import it to Vue it shows up in the Links tab. I can then save it to my library as a .vob file. After going back and updating it in SU and re-saving the obj. file Vue informs me the file has changed and asks me if I want to update it.
                        So shouldn't this also work with the .vob file that is created with the SU to Vue exporter?
                        • KrisidiousK Offline
                          Krisidious
                          how do you get the cameras in sketchup to import to Vue?
                          By: Kristoff Rand
                            d12dozr
                            Only the camera active when you export from SU is imported into Vue.
                            http://goo.gl/f7ooYh
                              Krisidious
                              so you can't export an animation? that sux.
                              By: Kristoff Rand
                                d12dozr
                                I remember Dave saying that it should be in the next version, but not yet
                                  Krisidious
                                  thanks Dozr
                                  By: Kristoff Rand
                                    Krisidious
                                    does anyone know how to make the buttons or toolbars smaller in Vue?
                                    By: Kristoff Rand
                                      d12dozr
                                      You can drag the right pane left/right to change its size, but the toolbars aren't adjustable. Alt+Enter will toggle full-screen if that helps...
                                      • Chris FullmerC Offline
                                        Hey, I finally made something in Vue that I thought was worth showing. I've finally got approval (after nearly 2 years of false starts) to buy VUE for the office, but for now I am still just playing with the PLE. So please forgive my watermarks.
                                        When I made the ecosystem and added the little rocks, I couldn't figure out a way to make them stick to the overhangs of the cliff. Any ideas how to make that work?
                                        • soloS Offline
                                          Chris, there are many ways to do it, the easiest would be to use the material brush in the terrain editor and define the areas where you want the various materials, see image.
                                          You can also control this using a mixed material and setting the influence and conditions in the material editor.
                                          Alternatively you can do it the slow but accurate way and use the 'paint ecosystem' option found in edit menu to hand paint where you want your grass and stones.
                                            Well, what I did was made that cliff as a matablob. And then I applied an eco system material to it that I made. But in making the material and adding the rock element to the ecosystem, I couldn't get the rock to adhere to an overhang. It seems that the material ecosystem forces objects to contraint to a slope somewherre between flat and perfectly vertical, and does not allow ecosystems to populate objects on slopes that are overhangs.
                                            I know I could just paint it on the overhang, but I really wanted it to be an automated population process because I clear it and re-populate it so many times through my process. I didn't want to have to keep repainting the overhang. Plus I was atempting to use a map to vary the density, so that the rocks would add themselves in seems throughout the mud, but I never could tell if it was working since they refused to populate ontot he overhangs. Oh well, unless you have a cure, I'm not that worried about it I suppose.
                                            • 7 / 9
