    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 62.9k Views 28 Watching
      dburdick
      @bob james said:
      Great news, Dave, but...
      I've gone to my C3D account, but see no obvious way to download the update.
      I did a search for SU to Vue and it led me to your post: the link on the post sent me to a page to buy it.
      Edit: My SU2Vue came as a part of the Vue 9 Complete Bundle - I didn't buy it separately: is that the problem?
      Hi Bob,
      There's a new update of Vue 9 complete coming out next week which should have the updated plugin as well. In the meantime, drop me an e-mail and I'll send you a copy of the plugin:
      dburdick@e-onsoftware.com
      • T
        thecravatman
        Hi Dave are we still on for the update this week?
        • T
          thecravatman
          Many thanks Dave, the new build works really well. I have something I actually want for Christmas now!
          • Bob JamesB
            Bob James
            What about the update to SU2Vue?
            Where do I download that in the future?
              Starlex
              Does this bug solved in SU2Vue Exporter? Using via .3ds or .obj export method it is impossible to use texture displacement on sketchup surfaces
              Single-sided, inverted normals reduce high freq noise, but still bad
                dburdick
                It looks like your base model is too low poly for such high frequency displacement. Have you tried just using bump?
                  d12dozr
                  Vladimir from Geekatplay has posted some excellent SU2Vue tutorials. I found the "Working with textures" tut very helpful 👍
                  http://goo.gl/f7ooYh
                  • N
                    notareal
                    In general (don't have much experience with vue) displacement does require a good mesh topology. Something like this if triangulated (quad faces are even better). Perhaps need more sub divs.
                      Why are quad-faces better than triangles?
                        What Solso asked there - turning a mesh into quads - I recently replied to a similar thread where I mentioned that Quad faces in other applications are often different in that they are not limited to being co-linear. Internally they are triangulated, it's just the application that treats two triangles as a quad and simplifies the presentation tot he user so you get a more predictable mesh.
                          Ah - that post was also from Solo... http://forums.sketchucation.com/viewtopic.php?f=323&t=33895&p=297883#p297883
                          • N
                            notareal
                            It's later more demanding to go from tris to quads, if you happen to export mesh to a program that uses quads.
                            For rendering quads are not particular critical as most render engines do use triangulated meshes. But even then if mesh is triangulated and is not dense enough and render engine have some issue with geometry smoothing, smoothing artifacts may appear when "poles" or "spikes" are present. Using quads for modelling should prevent this, even if mesh is later triangulated. This topic might be good to look http://forums.sketchucation.com/viewtopic.php?f=18&t=33894
                            I do believe that if Starlex where modelling with quads in the beginning, he would not had those displacement issues.
                            • N
                              notareal
                              Requirements for displacement are similar than in Subdivision Modeling (Displacement essentially needs to subdivide the original mesh). Considering SU limitations with quads, it might be best to model quad-like manner, like you suggest in the other topic, and then avoid need for co-planar quads. Anyhow, basic issue in earlier displacement problem is in the poor mesh topology.
                                Starlex
                                this is it, but I can't imagine how it will be with arcs...
                                • N
                                  notareal
                                  If you know that you are going to use displacement, use some lofting tool like in this tutorial http://forums.sketchucation.com/viewtopic.php?f=18&t=34018 You will automatically get reasonable good topology.
                                    JT Artifex
                                    I've got a question about syncing objects between SU and Vue.
                                    Is there a way to set things up so that the models exported from SU to Vue would update if the original SketchUp model was modified. I don't believe there is a way to link the sketchup file, but I have read that there is a synchronizing feature that should allow you to update modified objects.
                                    So far I have been opening the .vob file created from the exporter and then saving the model as an object into my Vue library. Then I have access to it in Vue for any of my scenes. This is were the question came up... if I use it in a scene and then decide to modify it a bit, do I need to reopen it in Vue, overwrite it in the library and reload/replace it in the scene. Is there not a way for this to update itself... I even tried to just overwrite the object in the library and see if it would update once the scene was reopened but that did not seem to work either.
                                    So when does the synchronizing of objects apply... is that only for certain file types of programs?
                                    Thanks for any thoughts.
                                      JT Artifex
                                      So I managed to get the links feature to work...
                                      If I save it as a obj. file and then import it to Vue it shows up in the Links tab. I can then save it to my library as a .vob file. After going back and updating it in SU and re-saving the obj. file Vue informs me the file has changed and asks me if I want to update it.
                                      So shouldn't this also work with the .vob file that is created with the SU to Vue exporter?
                                      • KrisidiousK
                                        Krisidious
                                        how do you get the cameras in sketchup to import to Vue?
                                        By: Kristoff Rand
                                          d12dozr
                                          Only the camera active when you export from SU is imported into Vue.
                                          • KrisidiousK
                                            Krisidious
                                            so you can't export an animation? that sux.
                                            By: Kristoff Rand
                                            • 7 / 9
