    SU upgrade to 8.0.4811 (Maintenance 1)
    108 Posts 42 Posters 35.5k Views 42 Watching
    • jeff hammondJ Offline
      it addressed at least two bugs..
      the follow-me icon is fixed as well as a tool-tip pop up error on mac (views were named with numbers instead of left,right, etc.)
      probably a bunch of little things like that.
      • F Offline
        fountainhead
        I've tried downloading the file twice, both times 'file corrupt'. Also tried running directly from download site, 'file corrupt'. This is for Pro version Windows download. Could be a problem with massive downloading of the update maybe?
          Quite possibly.
            Thanks Google πŸ‘
            • FrederikF Offline
              Frederik
              Installing as I write this... πŸ‘
              Cheers
              Kim Frederik
                No official announcement yet. Although there are exciting things!
                πŸ˜‰
                • boofredlayB Offline
                  boofredlay
                  Well there you go, the release notes were just posted up.
                  http://sketchup.google.com/support/bin/static.py?page=release_notes.cs
                  Many new fixes but most notably the Shadow Bug is fixed
                    chrisjk
                    Looks like a pretty big bunch of stuff has been fixed or improved.
                    • kenK Offline
                      ken
                      Just a question to the Sketchup team. Would it be possible to have the upgrade not upgrade the materials, components or plugins? Or at least give someone the choice of upgrading these three directories.
                      Other than that small quibble, thanks
                      Ken
                        • fixed shadow bug
                        • LAA aware (on 64 bit OS)
                        • bigger image export
                        • codecs fixed
                        • unicode character enhancements in LO-2-dxf/dwg (this affected me big time)
                        • and a lot more...
                        I do not understand this, Ken...
                        • kenK Offline
                          ken
                          Well, when you upgrade if you don't rename the plugin, components or material folders, you loose all you plugins, materials and components. So every time I have to rename these three folders and than re-name them back to the use able names after the install. I was just thinking, if the upgrade did not install/re-install these three folders without asking first, it would save me the worry I may overwrite these three folders.
                          Now, I just have a feeling I may be doing something wrong.
                          Ken
                            I have never had this issue on my PC. In fact, I have upgraded like 6 times for the last couple of weeks/months now without any problem and losing anything. It only overwrites the default, native SU content 8that comes with the install), nothing else.
                              wow, ended up being a nicer update than i initially thought
                              πŸ‘ πŸ‘
                              i found an issue with the shadow string fix though.. it fixes the strings but introduces another problem..
                              i'll post an example a little later.
                              • kenK Offline
                                ken
                                I believe when I upgraded from 4 to 5 I lost all my plugins, materials and components. Never had the courage to try again. So, next upgrade I will save a copy of these three directory in another directory, and try your method to install over.
                                So, make this a duh!! moment for me.
                                Thanks Gaieus.
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  Gai,
                                  Shadow bug fixed! .animation (codecs fixed)? Wow!
                                  Maybe my office machine will create animations now.
                                  Per Google: "/Largeaddressaware". Does this mean that 64 bit computers can now address bigger files, while 32 bit machines retain the benefit of speed?
                                  I hope the api fixes will not cause problems for "workarounds".:-)
                                    Ken; yes, testing it won't harm (just in case)
                                    πŸ˜„
                                    HDT: LAA, I believe, will only be useful on 64 bit. However you can also "hack" a 32 bit OS to be able to assign more RAM than 2 Gb to a single program.
                                      d12dozr
                                      A comprehensive release! Toolbar fix fixed πŸ’š LAA πŸ‘
                                      Thanks Sketchup Team!
                                      http://goo.gl/f7ooYh
                                        kwalkerman
                                        model.raytest fixed!! with the optional boolean attribute as well. THANKS!
                                        And the shadow bug fixed. That's a nice surprise.
                                        karen
                                          Yes - Under 64bit Windows, SU can now address up to 4GB RAM. (I have tried it with a huge render.) πŸ˜„
                                          • AndrewSA Offline
                                            AndrewS
                                            Ken,
                                            My colleague, Steve, and I were responsible for creating the SketchUp installers for Mac and Windows. I have only been on the SU team for just over three years, so I can't speak to what technologies were in place back in the 4 and 5 days. However, on Windows, for SketchUp 7 and 8, which were built as MSI-based installers using Wix, if you're just installing a minor release (anything where the major version number stays the same, like 7.0 -> 7.1 or 8.0 -> 8.0 maintenance release 1), you should be perfectly safe to run the upgrade in-place. The Windows Installer technology is supposed to be smart enough to replace just the files that differ in your current installation vs. the new installation, without removing extraneous files or replacing directories wholesale.
                                            This does highlight the point that if you've made any modifications to files we provide, those modifications could be lost in an upgrade. However, you should never (99.999% of the time) need to overwrite any of the files we provide for you with your own modifications anyway. If you need to modify something like a LayOut template, copy the file and make a differently named version with your modifications so they can be preserved separate from what we've provided. And, in the cases when it is possible (such as with LayOut templates), store your own files outside of the SketchUp directory structure, just to be on the safe side.
                                            Obviously, with things like plugins, you have no choice but to put the files inside the SketchUp directory, so if it worries you, make a quick backup of the SketchUp directory before proceeding with the upgrade, but do know that we expect it should work without such intervention.
                                            Andrew
                                            Andrew S.
                                            SketchUp Release Engineer
                                            • 1 / 6
