    Is it possible? To use plugins from USB stick
    16 Posts 9 Posters 6.8k Views 9 Watching
      @Jim: did you have some code already to detect the installation path of various SU versions?
      I was thinking - for Windows:
      Make an HTA application that finds the various SU installations on the system and presents a list which the user can choose from.
      Then it launches the one the user picks with the command to load the external loader.
      OSX users:
      Any ideas of a quick and easy way to detect SketchUp, present a list and then launch the application with an argument?
        When you say you have YOUR plugins on DropBox. Does this mean only the ones you developed or all plugins?
        And if this loader was available would it take such to setup?
          As it is now, the one I've developed. But that's merely because I have needs for different plugins at home vs work - so third-party plugins is something I install per machine. But there is no limitation in the loader script-
          As it is now you manually edit the loader with where it should load them.
            Jim
            Yes, the Extension Manager .hta I posted has all of the code for locating SketchUp's Installation Location.
            Part of the idea of the Extension Manager was to allow the selection of sets of plugins before starting SU in order to give the user finer control over what's loaded.
            Just create a shared folder somewhere - network, portable device - it doesn't really matter where. Then put a loader file in THE Plugins folder:
            require 'sketchup' require_all("G:\Plugins")
            Just use the full path to the shared folder.
            If you don't have permission to install the loader file, you can just type it in the Ruby Console to load them.
              That's why I was thinking you start SketchUp with that argument that let you specify a plugin it should load. You would not have to install anything at all.
              Would be real nice to have such a thing - I often help people at the office and I often wish I could quickly run their SketchUp with the plugins I use.
              • brodieB
                brodie
                I've developed (or rather discovered I suppose) a method along these lines that I think is a bit more universal.
                1. Get Dropbox ( http://db.tt/v711uYO )
                2. Copy your SU Plugins folder into your Dropbox account.
                Personally, I have a folder called Program Files and in that I have folders for SketchUp, Maxwell Render, and Photoshop. Within my SU folder I've copied my Exporters, Materials, and Plugins folders
                1. Delete your Plugins folder from your 😄 drive
                Personally, I just change the name so it's still there as a just-in-case but SU doesn't recognize it as anything
                1. Download the appropriate files for your OS from http://schinagl.priv.at/nt/hardlinkshellext/hardlinkshellext.html#contact
                The site is blocked here at work for some reason so I can't see it, but as I recall at the very bottom are a series of links for 32bit and 64bit. I think you end up downloading/running 2 files. This gives you a new option to your right click menu when you select a file.
                1. Right-Click the Plugins folder in Dropbox, select Pick Link Source, go back to where that folder was on your 😄 drive, Right-Click and select Drop As -> Junction
                The End.
                Basically what this does is creates, what I think of as, a super-shortcut. It works just like creating a shortcut on your desktop where you click the shortcut and it navigates you to the actual folder. But SU won't recognize a regular shortcut as the Plugins folder, so this method creates a 'super-shortcut' that SU will recognize, but whenever you go into the folder it basically navigates you to the contents of the folder it's linked to.
                I originally discovered this in order to sync up all my firefox accounts and it worked great.
                As for using this method with a thumb drive, I'm not sure it would work, and even if it did, without your thumb drive in, you'd have no plugins at all.
                -Brodie
                • dereiD
                  derei
                  -Brodie
                  The reason I want to run plugins from thumb drive is because I have some paid plugins and I don't want to let them on a PC at office. (ok, there is an option: password on my account, but is not possible, as each employee must have access to any station)
                  DESIGNER AND ARTIST DEREI.UK
                  • C
                    chrisjk
                    Alex Schreyer's plugin loader works for me - at least for plugins on my hard disk
                    404 Not Found
                    (www.alexschreyer.net)
                      Jim
                      Or this in the Ruby Console:
                      load(UI.openpanel)
                      • dereiD
                        derei
                        load(UI.openpanel)
                        Well, for 1-2 plugins this can be an option, but after a while it becomes annoying. I was thinking to some way to "tell" sketchup to look in a specific place for plugins.
                        In the meantime I found this piece of software that can customize a usb drive (letter, hidden or not, and so on). So, the drive issue is solved. I can map my USB with Z:, for example, to be sure that it will not be taken by other drive.
                        The only problem that remains is to load in SU automatically. (no load(UI.openpanel) ). ❓
                        • B
                          binouze23
                          I don't know anything in the "ruby world" and all those stuff, but when I was a student and use to download a lot of "free" programs 😳 😡 , I found a portable version of Sketchup that was made to run on flashdrive and this version included a lot of plugin (even vray).
                          So I don't know if you can do it just for the plugin part but I know it is possible to create a portable version of the program with all your plugin inside...
                          The version I downloaded at that time was completely illegal but maybe you can make this kind of work legally if you own all the license ?
                          Sorry to talk about "dirty" stuff here, I know it's not the Sketchucation style but I didn't share anything and I thought it could be a good solution. Anyway, feel free to delete this message and you have all my apologize if I did wrong.
                          (I'm also sorry for my English but it was kinda hard for me to explain this)
                          Binouze
                          • dereiD
                            derei
                            I don't know what are the terms of use for SketchUp, but for normal use, its license is freeware. I guess that tweaking it to run from portable device wouldn't be illegal.
                            On the other hand, I have no idea how this can be done.
                            Thanks for the tip, anyway. Maybe we will see more ideas here.
                            • B
                              Builder Boy
                              Type this into the ruby console:
                              just make sure all of you're plugins are in "G:\Plugins"
                              You're flash drive might not be named "G", in which case, you would need to type the letter of you're flash drive. require_all("F:\Plugins") Or, require_all("H:\Plugins")
                              All my plugins
