    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 19.1k Views 15 Watching
      Jim
      No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
        Great minds think alike... fools never differ...
        I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
          Jim
          I can't get my Mac to print out the key code for a Tab?
          using this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=205
            For onKeyDown it won't as Tab on Mac doesn't fire onKeyDown πŸ˜’
            But with onKeyUp it should return 9
            BUT note that some locales/MacOSs can return 15 or even 48 for Tab... 😲
            I use this
            ### Type 'keycode' in the Ruby Console...
            class TIG_KeyCode
              def activate
                @key=""
                puts "TIG's Non-Shortcut Keycode Reporter.\n"
                puts "Click in the Main Window outside of the"
                puts "Ruby Console then Press Non-Shortcut Keys..."
              def onKeyDown(key, repeat, flags, view)
                @key=key.to_s
                puts "You Pressed Keycode = "+@key
              def onKeyUp(key, repeat, flags, view)
                @key=key.to_s
                puts "You Released Keycode = "+@key
              def deactivate(view)
                puts "You have pressed a Shortcut Key...\nExiting."
                return nil
            end#class
            def keycode()
              Sketchup.active_model.select_tool(TIG_KeyCode.new)
              puts ""
            end#if
              Jim
              Well, that's rather a pain, not to mention bug-ish.
                Is it reported?
                  @thomthom said:
                  Is it reported?
                  I have seen it discussed in various places - I've added it to the Tool's API notes...
                    Jim
                    Link?
                      @jim said:
                      Link?
                      http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#commentWidgetTitle
                        Jim
                        I don't see any note.
                          Jim
                          Updated to fix Tab issue and correct start_operation for version 6+
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=33875
                            @jim said:
                            Link?
                            Y'know... I don't recall... BUT I have been avoiding using onKeyDown for TAB-key for MAC compatibility for ages by using onKeyUp key==9 etc... I even teach it to my students πŸ˜’
                            I've search my usual haunts... and not found a link but there must be something somewhere as I can't have dreamed up the problem alone...
                            It seems to have been raised around here http://forums.sketchucation.com/viewtopic.php?p=273542#p273542 Jeff was also involved and Fredo? ...
                              It's currently the first item in the User Notes list [~5 hours ago] - are your pages cached ? Try refreshing them...
                                Jim
                                When you link back to something you need to get the link from the 'small-file-square' below the post's title Capture.PNG that way you link to the very page, not the thread itself... http://forums.sketchucation.com/viewtopic.php?p=297720#p297720 works
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=33875 does not.
                                  Jim
                                  Of course it works. I'm not sure what problem you are having.
                                    No - these link to different posts...
                                    Click on the two I gave to see the difference.
                                    If you have your posts sorted in chronological order it looks the same [at least initially] because the first post is at/near the top BUT if you sort in reverse order, like I do, so that the most recent posts are shown first then the initial download thread is not accessed by the click as it's by now on another page... πŸ˜•
                                    In passing... I not that you latest version of dline2 missed a 'start_operation' around line #287 so it's still not v6 compatible... πŸ˜’
                                    It's effectively defining 'double-click' to be taken as 'enter' - I note that ones 'Double ligne' and the others 'Double line' are also probably typos left over from Didier...
                                      Jim
                                      Well, that different than "not working." I see your point.
                                        It 'wasn't working' because it wasn't 'linking to the post' but rather linking directly to the thread itself which was somewhat redundant as you were linking from within it already - not the desired result I must assume... πŸ˜‰
                                          Jim
                                          I only intended to add some user-interface niceties such as persistent options for selfish reasons, and didn't look too closely at the other parts of the script. I did add version checking to the other start_operation, thanks.
                                          Download link in first post. http://forums.sketchucation.com/viewtopic.php?f=323&t=33875#p297720
                                            Your download link isn't working for me again [ http://forums.sketchucation.com/viewtopic.php?f=323&t=33875#p297720 viewtopic.php?f=323&t=33875#p297720 ]
                                            It should be http://forums.sketchucation.com/viewtopic.php?p=297720#p297720 viewtopic.php?p=297720#p297720 ???
                                            What do you get if you copy the link from the 'square' as I suggested earlier ?
                                            • 1 / 3
