    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 21.3k Views 15 Watching
      Ben Ritter
      Thank you Jim.
        Jim
        Sure; although there seems to be some problems with the creation of the geometry in some cases. I haven't looked at that part.
          Jim
          I also noticed that you use the onKeyDown method to get 'TAB'... this usually fails on a MAC as TAB is screwed on key-down... the recommended way is to use
          def onKeyUp(key, repeat, flags, view)
              if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ?
          Note how I also have some other keys mapped as in some locales/MacOSs it seems that '9' isn't Tab ๐Ÿ˜•
            Is there no VK_* constant for tab that would be correct for the platform it runs on?
              No. There should be but it's missing...
              It's a simple matter to always check for 'key-up' if using 'Tab' though ๐Ÿ˜‰
                Don't work on the V6 (pc) ๐Ÿ˜ฎ
                Drawing lines are good but
                Walls are not drawn when Enter pressed ๐Ÿ˜ž
                Error; #<ArgumentError; wrong number of arguments(2 for 1)>
                C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
                C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
                  This is the same problem I mentioned with DrawHelix and model.start_operation taking a second argument after v6.
                  Unfortunately in this tool it is NOT coded to allow use in v6 at all... BUT here is the fix...
                  In a copy of the script in the v6 folder find the two lines reading [one might be in French ๐Ÿ˜’ ]
                  Sketchup.active_model.start_operation("Double Line", true)
                  and edit the text so there is no 'true' thus
                  Sketchup.active_model.start_operation("Double Line")
                  Now it will work in v6 [this will also work in v7/8 but is less efficient in refresh of display terms]
                  I think a relatively idiot proof way of doing a start_operation that is optimized for all versions is
                  begin
                  rescue
                  That is, it tries to start an operation with a second argument flag set [best for most v7/8 uses] BUT if it fails then it does one without the flag - e.g. v6..........
                    Jim
                    No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
                    404 Not Found
                    (forums.sketchucation.com)
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
                      Great minds think alike... fools never differ...
                      I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
                        Jim
                        I can't get my Mac to print out the key code for a Tab?
                        using this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=205
                          For onKeyDown it won't as Tab on Mac doesn't fire onKeyDown ๐Ÿ˜’
                          But with onKeyUp it should return 9
                          BUT note that some locales/MacOSs can return 15 or even 48 for Tab... ๐Ÿ˜ฒ
                          I use this
                          ### Type 'keycode' in the Ruby Console...
                          class TIG_KeyCode
                            def activate
                              @key=""
                              puts "TIG's Non-Shortcut Keycode Reporter.\n"
                              puts "Click in the Main Window outside of the"
                              puts "Ruby Console then Press Non-Shortcut Keys..."
                            def onKeyDown(key, repeat, flags, view)
                              @key=key.to_s
                              puts "You Pressed Keycode = "+@key
                              @key=key.to_s
                              puts "You Released Keycode = "+@key
                            def deactivate(view)
                              puts "You have pressed a Shortcut Key...\nExiting."
                              return nil
                          end#class
                          def keycode()
                            Sketchup.active_model.select_tool(TIG_KeyCode.new)
                            puts ""
                          end#if
                            Jim
                            Well, that's rather a pain, not to mention bug-ish.
                              Is it reported?
                                @thomthom said:
                                Is it reported?
                                I have seen it discussed in various places - I've added it to the Tool's API notes...
                                  Jim
                                  Link?
                                    @jim said:
                                    Link?
                                    Error 404 (Not Found)!!1
                                    (code.google.com)
                                      Jim
                                      I don't see any note.
                                        Jim
                                        Updated to fix Tab issue and correct start_operation for version 6+
                                        404 Not Found
                                          @jim said:
                                          Link?
                                          Y'know... I don't recall... BUT I have been avoiding using onKeyDown for TAB-key for MAC compatibility for ages by using onKeyUp key==9 etc... I even teach it to my students ๐Ÿ˜’
                                          I've search my usual haunts... and not found a link but there must be something somewhere as I can't have dreamed up the problem alone...
                                          It seems to have been raised around here http://forums.sketchucation.com/viewtopic.php?p=273542#p273542 Jeff was also involved and Fredo? ...
                                            It's currently the first item in the User Notes list [~5 hours ago] - are your pages cached ? Try refreshing them...
                                            • 1 / 3
