    ๐Ÿซ› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 17.0k Views 15 Watching
      Jim
      I made some (hopefully) improvements to Didier's dline.rb double-line & wall tool. Mostly the changes are to improve user interaction with the tool.
      • Tab key brings up the options dialog, otherwise the previous values are in effect.
      • Values are saved between uses, and between sessions.
      • Options dialog and Measurements display/accept Model Units.
      • Can enter the Width in the Measurements (VCB) upon activation.
      • Right-Click empty space to finish the line. (Same as Enter key.)
      • Fixed line color wrt inferences, and fixed inference locking.
      • Add a ConstructionPoint to start of line for later inferencing (deleted upon completion.)
      • Fixed clipping.
      • Wrapped code in module namespace.
      • Renamed menu to Double Line 2
      This file is meant to replace dline.rb file if installed, but can co-exist alongside dline.rb.
      Download dline2.rb
        Ben Ritter
        Thank you Jim.
          Jim
          Sure; although there seems to be some problems with the creation of the geometry in some cases. I haven't looked at that part.
            Jim
            I also noticed that you use the onKeyDown method to get 'TAB'... this usually fails on a MAC as TAB is screwed on key-down... the recommended way is to use
            def onKeyUp(key, repeat, flags, view)
                if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ?
            Note how I also have some other keys mapped as in some locales/MacOSs it seems that '9' isn't Tab ๐Ÿ˜•
              Is there no VK_* constant for tab that would be correct for the platform it runs on?
                No. There should be but it's missing...
                It's a simple matter to always check for 'key-up' if using 'Tab' though ๐Ÿ˜‰
                  Don't work on the V6 (pc) ๐Ÿ˜ฎ
                  Drawing lines are good but
                  Walls are not drawn when Enter pressed ๐Ÿ˜ž
                  Error; #<ArgumentError; wrong number of arguments(2 for 1)>
                  C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
                  C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
                    This is the same problem I mentioned with DrawHelix and model.start_operation taking a second argument after v6.
                    Unfortunately in this tool it is NOT coded to allow use in v6 at all... BUT here is the fix...
                    In a copy of the script in the v6 folder find the two lines reading [one might be in French ๐Ÿ˜’ ]
                    Sketchup.active_model.start_operation("Double Line", true)
                    and edit the text so there is no 'true' thus
                    Sketchup.active_model.start_operation("Double Line")
                    Now it will work in v6 [this will also work in v7/8 but is less efficient in refresh of display terms]
                    I think a relatively idiot proof way of doing a start_operation that is optimized for all versions is
                    begin
                    rescue
                    That is, it tries to start an operation with a second argument flag set [best for most v7/8 uses] BUT if it fails then it does one without the flag - e.g. v6..........
                      Jim
                      No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
                        Great minds think alike... fools never differ...
                        I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
                          Jim
                          I can't get my Mac to print out the key code for a Tab?
                          using this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=205
                            For onKeyDown it won't as Tab on Mac doesn't fire onKeyDown ๐Ÿ˜’
                            But with onKeyUp it should return 9
                            BUT note that some locales/MacOSs can return 15 or even 48 for Tab... ๐Ÿ˜ฒ
                            I use this
                            ### Type 'keycode' in the Ruby Console...
                            class TIG_KeyCode
                              def activate
                                @key=""
                                puts "TIG's Non-Shortcut Keycode Reporter.\n"
                                puts "Click in the Main Window outside of the"
                                puts "Ruby Console then Press Non-Shortcut Keys..."
                              def onKeyDown(key, repeat, flags, view)
                                @key=key.to_s
                                puts "You Pressed Keycode = "+@key
                                @key=key.to_s
                                puts "You Released Keycode = "+@key
                              def deactivate(view)
                                puts "You have pressed a Shortcut Key...\nExiting."
                                return nil
                            end#class
                            def keycode()
                              Sketchup.active_model.select_tool(TIG_KeyCode.new)
                              puts ""
                            end#if
                              Jim
                              Well, that's rather a pain, not to mention bug-ish.
                                Is it reported?
                                  @thomthom said:
                                  Is it reported?
                                  I have seen it discussed in various places - I've added it to the Tool's API notes...
                                    Jim
                                    Link?
                                      @jim said:
                                      Link?
                                      http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#commentWidgetTitle
                                        Jim
                                        I don't see any note.
                                          Jim
                                          Updated to fix Tab issue and correct start_operation for version 6+
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=33875
                                            @jim said:
                                            Link?
                                            Y'know... I don't recall... BUT I have been avoiding using onKeyDown for TAB-key for MAC compatibility for ages by using onKeyUp key==9 etc... I even teach it to my students ๐Ÿ˜’
                                            I've search my usual haunts... and not found a link but there must be something somewhere as I can't have dreamed up the problem alone...
                                            It seems to have been raised around here http://forums.sketchucation.com/viewtopic.php?p=273542#p273542 Jeff was also involved and Fredo? ...
                                            • 1 / 3
