    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 21.3k Views 15 Watching
      @thomthom said:
      Is there no VK_* constant for tab that would be correct for the platform it runs on?
      No. There should be but it's missing...
      It's a simple matter to always check for 'key-up' if using 'Tab' though ๐Ÿ˜‰
        Don't work on the V6 (pc) ๐Ÿ˜ฎ
        Drawing lines are good but
        Walls are not drawn when Enter pressed ๐Ÿ˜ž
        Error; #<ArgumentError; wrong number of arguments(2 for 1)>
        C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
        C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
          This is the same problem I mentioned with DrawHelix and model.start_operation taking a second argument after v6.
          Unfortunately in this tool it is NOT coded to allow use in v6 at all... BUT here is the fix...
          In a copy of the script in the v6 folder find the two lines reading [one might be in French ๐Ÿ˜’ ]
          Sketchup.active_model.start_operation("Double Line", true)
          and edit the text so there is no 'true' thus
          Sketchup.active_model.start_operation("Double Line")
          Now it will work in v6 [this will also work in v7/8 but is less efficient in refresh of display terms]
          I think a relatively idiot proof way of doing a start_operation that is optimized for all versions is
          begin
          rescue
          That is, it tries to start an operation with a second argument flag set [best for most v7/8 uses] BUT if it fails then it does one without the flag - e.g. v6..........
            Jim
            No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
            404 Not Found
            (forums.sketchucation.com)
              http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
              Great minds think alike... fools never differ...
              I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
                Jim
                I can't get my Mac to print out the key code for a Tab?
                using this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=205
                  For onKeyDown it won't as Tab on Mac doesn't fire onKeyDown ๐Ÿ˜’
                  But with onKeyUp it should return 9
                  BUT note that some locales/MacOSs can return 15 or even 48 for Tab... ๐Ÿ˜ฒ
                  I use this
                  ### Type 'keycode' in the Ruby Console...
                  class TIG_KeyCode
                    def activate
                      @key=""
                      puts "TIG's Non-Shortcut Keycode Reporter.\n"
                      puts "Click in the Main Window outside of the"
                      puts "Ruby Console then Press Non-Shortcut Keys..."
                    def onKeyDown(key, repeat, flags, view)
                      @key=key.to_s
                      puts "You Pressed Keycode = "+@key
                    def onKeyUp(key, repeat, flags, view)
                      @key=key.to_s
                      puts "You Released Keycode = "+@key
                    def deactivate(view)
                      puts "You have pressed a Shortcut Key...\nExiting."
                      return nil
                  end#class
                  def keycode()
                    Sketchup.active_model.select_tool(TIG_KeyCode.new)
                    puts ""
                  end#if
                    Jim
                    Well, that's rather a pain, not to mention bug-ish.
                      Is it reported?
                        @thomthom said:
                        Is it reported?
                        I have seen it discussed in various places - I've added it to the Tool's API notes...
                          Jim
                          Link?
                            @jim said:
                            Link?
                            Error 404 (Not Found)!!1
                            (code.google.com)
                              Jim
                              I don't see any note.
                                Jim
                                Updated to fix Tab issue and correct start_operation for version 6+
                                404 Not Found
                                  @jim said:
                                  Link?
                                  Y'know... I don't recall... BUT I have been avoiding using onKeyDown for TAB-key for MAC compatibility for ages by using onKeyUp key==9 etc... I even teach it to my students ๐Ÿ˜’
                                  I've search my usual haunts... and not found a link but there must be something somewhere as I can't have dreamed up the problem alone...
                                  It seems to have been raised around here http://forums.sketchucation.com/viewtopic.php?p=273542#p273542 Jeff was also involved and Fredo? ...
                                    It's currently the first item in the User Notes list [~5 hours ago] - are your pages cached ? Try refreshing them...
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=33875
                                      Jim
                                      When you link back to something you need to get the link from the 'small-file-square' below the post's title Capture.PNG that way you link to the very page, not the thread itself... http://forums.sketchucation.com/viewtopic.php?p=297720#p297720 works
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=33875 does not.
                                        Jim
                                        Of course it works. I'm not sure what problem you are having.
                                          No - these link to different posts...
                                          Click on the two I gave to see the difference.
                                          If you have your posts sorted in chronological order it looks the same [at least initially] because the first post is at/near the top BUT if you sort in reverse order, like I do, so that the most recent posts are shown first then the initial download thread is not accessed by the click as it's by now on another page... ๐Ÿ˜•
                                          In passing... I not that you latest version of dline2 missed a 'start_operation' around line #287 so it's still not v6 compatible... ๐Ÿ˜’
                                          It's effectively defining 'double-click' to be taken as 'enter' - I note that ones 'Double ligne' and the others 'Double line' are also probably typos left over from Didier...
                                            Jim
                                            Well, that different than "not working." I see your point.
                                            • 1 / 3
