    [Plugin] DrawHelix14
    44 Posts 20 Posters 56.1k Views 20 Watching
      Small is beautiful ๐Ÿ˜‰
        PeterCharles
        @jim said:
        This is a enhanced version of Peter Brown's DrawHelix13 script.
        Main improvements are:
        • Input box now uses the current model units.
        • Previous values are saved between each use.
        It is meant to replace the drawhelix13.rb file, but both can be installed without conflict.
        Download (right-click, select Save As)
        drawhelix14.rb
        There must be life in my old dog yet if someone thought to improve it. ๐Ÿ˜„
          Jim
          Hi Peter,
          Sure, it has plenty of life - I just made it a bit more friendly. Hope you don't mind the update.
          • mitcorbM Offline
            mitcorb
            Thanks, Jim.
              PeterCharles
              @jim said:
              Hi Peter,
              You have my blessing to improve it in what ever way you can. ๐Ÿ˜„
              • simon le bonS Offline
                simon le bon
                Excellent!
                Thank you Jim (and also for your revisited Didier's Double Line ๐Ÿ‘ )
                ๐Ÿ‘ simon
                  ATYRAUTONY
                  Hi nice tool but is it possible to draw a helix that is not a whole number of turns for example 1.5 I have tried and nothing is drawn.
                    Yes you must enter an "Integer" number ๐Ÿ˜„
                    So cut your volume at the end of the process ๐Ÿ˜‰
                    Make 3 turns and cut at the middle ๐Ÿ˜‰
                      It's easily fixed by adjusting the code in the .rb file... on line #23 [edit with Notepad.exe or equivalent plain-text editor - NOT a wrodprocessor]
                      change
                      values = [300.mm, 300.mm, 100.mm, 5, 24]
                      into
                      values = [300.mm, 300.mm, 100.mm, 5.0, 24]
                      then save.
                      Now you can enter decimal values like 1.5 ...
                      The original code froze it as an 'integer' [default=5] and therefore prevented 'partial turn' values being entered... BUT since the rest of the code doesn't rely on it being an 'integer' there's no problems with making it a 'float'...
                      I already had that tweaked in the previous version in my installation...
                        Better and more generalist indeed ๐Ÿ˜Ž
                        And always amazing as just 2 signs can change something! โ˜€
                        We are few things in the univers, all is inside decimals ๐Ÿ’š
                        By Francesco de Comitรฉ ๐Ÿ‘
                          @ TIG
                          I am in V6
                          Curious
                          I have an old version Draw Helix 13
                          make your 5.0 changment inside : works fine ๐Ÿ˜Ž
                          I load the new DrawHelix14
                          nothing is drawing ๐Ÿ˜ฎ (same result with your changment) ๐Ÿ˜ฎ
                          I have this in the Ruby console
                          Error; #<ArgumentError; wrong number of arguments(2 for 1)>
                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
                            simon le bon
                            change
                            into
                            then save.
                            I'm very proud to annouce that this
                            .0
                            added, is my very first rubby scripting ๐Ÿ˜† (and may be also the last ๐Ÿ˜Ž )
                            And then Oh! the problems begin ๐Ÿคฃ
                            1)With or without this new code, I discover that DrawHelix14 doesn't work with my Su6
                            2)DrawHelix14 works fine with my Su7 but the new code (
                            .0
                            ) doesn't work! (if a decimal value is entered, no helix is drawn_ if an Integer value is entered: works fine)
                            3)If I come back in Su6 to DawHelix13_fr and add the (
                            .0
                            )code, this time the helix is drawn.
                            4.5 rotations
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DrawHelix001.jpg
                            Ouf! Hard time for new developper ๐Ÿ˜Ž
                            simon
                            • dereiD Offline
                              derei
                              can't you filter that ? the script to catch the vcb value and remove the leading zero in incompatible version of SU ?
                                @ TIG
                                I am in V6
                                Curious
                                Line #65
                                if Sketchup.version_number.to_i < 7
                                changed to
                                if Sketchup.version.to_i < 7
                                will work in SUp v6 too !
                                Simple typo by Jim meant that you always got a version number in the tens of thousands and not a simple 6, 7 or 8 etc so it would always be > 7 and then try to start_operation with an extra argument and break the tool ๐Ÿ˜’
                                  Cool to see that is the same problem ๐Ÿ’š
                                  PS It's the same for the New Double Line!
                                  Don't work inside the V6 ๐Ÿ˜ฎ
                                  When press Enter walls are not drawn !
                                  same error message in the Ruby console
                                  C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
                                  C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
                                    Works now for the Draw Helix 14 in the V6 โ˜€
                                    but now it's your modification 5.0 who don't works in the Draw Helix 14 ! (V6) ๐Ÿ’š
                                    I have that
                                    Error; #<ArgumentError; invalid value for Integer; "5.5">
                                    C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `inputbox'
                                    C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `drawhelix'
                                      OK looks like float and string clash ?
                                      I assume the edited line #23 is clearly values = [300.mm, 300.mm, 100.mm, 5.0, 24] with no string delimter "" or '' around anything...
                                      Perhaps your JLF::DrawHelix Registry entry is screwed or locked on the last used 'intger' values?
                                      You could delete it...
                                      BUT unless you are confident about messing around within a PC's Registry and risking disaster... then I suggest this safer fix...
                                      Temporarily disable reading the Registry - go to line #24
                                      v = Sketchup.read_default(reg_key, "values")
                                      and add a leading # so it doesn't load at all
                                      #v = Sketchup.read_default(reg_key, "values")
                                      If you get an error also add a temporary line after it
                                      v=nil
                                      Run the tool once and close SUp, then remove that # etc from the .rb and retry - it should now be using the last entered values you used which are 'float'...
                                      Also - in passing I now note that in line #36 there is
                                      angle = 2*3.14159/sections
                                      it would be better as
                                      angle = 360.degrees/sections
                                      as the over approximated value of 'pi' could produce minor inaccuracies otherwise...
                                        Jim
                                        Thanks. I've made the changes and updated the download. The version works on SketchUp 6, 7, and 8 for me.
                                          Thinking about the earlier registry entry potentially messing integer and float, to be on the safe side you could add this
                                                  unless v.nil?
                                                      values = eval(v)
                                                      values[0] = values[0].to_l
                                                      values[1] = values[1].to_l
                                                      values[2] = values[2].to_l
                                                      values[3] = values[3].to_f
                                                      values[4] = values[4].to_i
                                          so that older values' classes are always correctly set?
                                            Jim
                                            Had the same thought... thanks.
                                            • 1 / 3
