    [Plugin] DrawHelix14
    44 Posts 20 Posters 57.8k Views 20 Watching
      dedmin
      ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
      Works fine - thanks, Jim!
        Thanks Jim!
        • shuraS Offline
          shura
          Thank you Jim, useful improvement!
          • Bob JamesB Offline
            Bob James
            Thanks for the improvement!
            • utilerU Offline
              utiler
              +1 Jim... simple is best!!!!!!
              Just Curious...
                Jim
                You're welcome. The small things can make all the difference.
                  True. Thanks Jim! ๐Ÿ‘
                    Small is beautiful ๐Ÿ˜‰
                      PeterCharles
                      @jim said:
                      This is a enhanced version of Peter Brown's DrawHelix13 script.
                      Main improvements are:
                      • Input box now uses the current model units.
                      • Previous values are saved between each use.
                      It is meant to replace the drawhelix13.rb file, but both can be installed without conflict.
                      Download (right-click, select Save As)
                      drawhelix14.rb
                      There must be life in my old dog yet if someone thought to improve it. ๐Ÿ˜„
                        Jim
                        Hi Peter,
                        Sure, it has plenty of life - I just made it a bit more friendly. Hope you don't mind the update.
                        • mitcorbM Offline
                          mitcorb
                          Thanks, Jim.
                            PeterCharles
                            @jim said:
                            Hi Peter,
                            You have my blessing to improve it in what ever way you can. ๐Ÿ˜„
                            • simon le bonS Offline
                              simon le bon
                              Excellent!
                              Thank you Jim (and also for your revisited Didier's Double Line ๐Ÿ‘ )
                              ๐Ÿ‘ simon
                                ATYRAUTONY
                                Hi nice tool but is it possible to draw a helix that is not a whole number of turns for example 1.5 I have tried and nothing is drawn.
                                  Yes you must enter an "Integer" number ๐Ÿ˜„
                                  So cut your volume at the end of the process ๐Ÿ˜‰
                                  Make 3 turns and cut at the middle ๐Ÿ˜‰
                                    It's easily fixed by adjusting the code in the .rb file... on line #23 [edit with Notepad.exe or equivalent plain-text editor - NOT a wrodprocessor]
                                    change
                                    values = [300.mm, 300.mm, 100.mm, 5, 24]
                                    into
                                    values = [300.mm, 300.mm, 100.mm, 5.0, 24]
                                    then save.
                                    Now you can enter decimal values like 1.5 ...
                                    The original code froze it as an 'integer' [default=5] and therefore prevented 'partial turn' values being entered... BUT since the rest of the code doesn't rely on it being an 'integer' there's no problems with making it a 'float'...
                                    I already had that tweaked in the previous version in my installation...
                                      Better and more generalist indeed ๐Ÿ˜Ž
                                      And always amazing as just 2 signs can change something! โ˜€
                                      We are few things in the univers, all is inside decimals ๐Ÿ’š
                                      By Francesco de Comitรฉ ๐Ÿ‘
                                        @ TIG
                                        I am in V6
                                        Curious
                                        I have an old version Draw Helix 13
                                        make your 5.0 changment inside : works fine ๐Ÿ˜Ž
                                        I load the new DrawHelix14
                                        nothing is drawing ๐Ÿ˜ฎ (same result with your changment) ๐Ÿ˜ฎ
                                        I have this in the Ruby console
                                        Error; #<ArgumentError; wrong number of arguments(2 for 1)>
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
                                          simon le bon
                                          change
                                          into
                                          then save.
                                          I'm very proud to annouce that this
                                          .0
                                          added, is my very first rubby scripting ๐Ÿ˜† (and may be also the last ๐Ÿ˜Ž )
                                          And then Oh! the problems begin ๐Ÿคฃ
                                          1)With or without this new code, I discover that DrawHelix14 doesn't work with my Su6
                                          2)DrawHelix14 works fine with my Su7 but the new code (
                                          .0
                                          ) doesn't work! (if a decimal value is entered, no helix is drawn_ if an Integer value is entered: works fine)
                                          3)If I come back in Su6 to DawHelix13_fr and add the (
                                          .0
                                          )code, this time the helix is drawn.
                                          4.5 rotations
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DrawHelix001.jpg
                                          Ouf! Hard time for new developper ๐Ÿ˜Ž
                                          simon
                                          • dereiD Offline
                                            derei
                                            can't you filter that ? the script to catch the vcb value and remove the leading zero in incompatible version of SU ?
                                            DESIGNER AND ARTIST DEREI.UK
                                            • 1 / 3
