    [Plugin] DrawHelix14
    44 Posts 20 Posters 49.6k Views 20 Watching
      Jim
      This is a enhanced version of Peter Brown's DrawHelix13 script.
      Main improvements are:
      • Input box now uses the current model units.
      • Previous values are saved between each use.
      It is meant to replace the drawhelix13.rb file, but both can be installed without conflict.
      Download (right-click, select Save As)
      drawhelix14.rb
        dedmin
        ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
        Works fine - thanks, Jim!
          Thanks Jim!
          • shuraS Offline
            shura
            Thank you Jim, useful improvement!
            • Bob JamesB Offline
              Bob James
              Thanks for the improvement!
              • utilerU Offline
                utiler
                +1 Jim... simple is best!!!!!!
                Just Curious...
                  Jim
                  You're welcome. The small things can make all the difference.
                    True. Thanks Jim! ๐Ÿ‘
                      Small is beautiful ๐Ÿ˜‰
                        PeterCharles
                        drawhelix14.rb
                        There must be life in my old dog yet if someone thought to improve it. ๐Ÿ˜„
                          Jim
                          Hi Peter,
                          Sure, it has plenty of life - I just made it a bit more friendly. Hope you don't mind the update.
                          • mitcorbM Offline
                            mitcorb
                            Thanks, Jim.
                              PeterCharles
                              @jim said:
                              Hi Peter,
                              You have my blessing to improve it in what ever way you can. ๐Ÿ˜„
                              • simon le bonS Offline
                                simon le bon
                                Excellent!
                                Thank you Jim (and also for your revisited Didier's Double Line ๐Ÿ‘ )
                                ๐Ÿ‘ simon
                                  ATYRAUTONY
                                  Hi nice tool but is it possible to draw a helix that is not a whole number of turns for example 1.5 I have tried and nothing is drawn.
                                    Yes you must enter an "Integer" number ๐Ÿ˜„
                                    So cut your volume at the end of the process ๐Ÿ˜‰
                                    Make 3 turns and cut at the middle ๐Ÿ˜‰
                                    • TIGT Online
                                      It's easily fixed by adjusting the code in the .rb file... on line #23 [edit with Notepad.exe or equivalent plain-text editor - NOT a wrodprocessor]
                                      change
                                      values = [300.mm, 300.mm, 100.mm, 5, 24]
                                      into
                                      values = [300.mm, 300.mm, 100.mm, 5.0, 24]
                                      then save.
                                      Now you can enter decimal values like 1.5 ...
                                      The original code froze it as an 'integer' [default=5] and therefore prevented 'partial turn' values being entered... BUT since the rest of the code doesn't rely on it being an 'integer' there's no problems with making it a 'float'...
                                      I already had that tweaked in the previous version in my installation...
                                        Better and more generalist indeed ๐Ÿ˜Ž
                                        And always amazing as just 2 signs can change something! โ˜€
                                        We are few things in the univers, all is inside decimals ๐Ÿ’š
                                        By Francesco de Comitรฉ ๐Ÿ‘
                                          @ TIG
                                          I am in V6
                                          Curious
                                          I have an old version Draw Helix 13
                                          make your 5.0 changment inside : works fine ๐Ÿ˜Ž
                                          I load the new DrawHelix14
                                          nothing is drawing ๐Ÿ˜ฎ (same result with your changment) ๐Ÿ˜ฎ
                                          I have this in the Ruby console
                                          Error; #<ArgumentError; wrong number of arguments(2 for 1)>
                                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
                                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
                                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
                                          C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
                                            simon le bon
                                            change
                                            into
                                            then save.
                                            I'm very proud to annouce that this
                                            .0
                                            added, is my very first rubby scripting ๐Ÿ˜† (and may be also the last ๐Ÿ˜Ž )
                                            And then Oh! the problems begin ๐Ÿคฃ
                                            1)With or without this new code, I discover that DrawHelix14 doesn't work with my Su6
                                            2)DrawHelix14 works fine with my Su7 but the new code (
                                            .0
                                            ) doesn't work! (if a decimal value is entered, no helix is drawn_ if an Integer value is entered: works fine)
                                            3)If I come back in Su6 to DawHelix13_fr and add the (
                                            .0
                                            )code, this time the helix is drawn.
                                            4.5 rotations
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DrawHelix001.jpg
                                            Ouf! Hard time for new developper ๐Ÿ˜Ž
                                            simon
                                            • 1 / 3
