    [Plugin] RotaScale
    39 Posts 14 Posters 34.4k Views 14 Watching
    • Chris FullmerC
      t = Geom::Transformation.scaling point, xscale, yscale, zscale
      just use 1.0 as the zscale value and it will be good to go!
        If I do that, it works for points that are picked planar to the model X and Y. But if I pick a point in the model Z axis, things are still being scaled only in the X and Y. Maybe that's what people expect?
        IMO that not what I'd expect from this plugin. I expect that if I pick two reference lines in the Z axis, things will get scaled in that direction.
        ...I suppose that the scaling transformation would have to be transformed to be local to the reference lines?
        That's what I'm not sure how to do. Getting the plane of the two reference lines (what happens when they are co-linear) and crossing it with the scaling transformation?
          Minor update to address a problem where V-Ray for Sketchup would not render RotaScaled groups/components correctly.
            Spotted a potential bug. Corrected.
            • free agentF
              free agent
              hi 5
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                5!
                • free agentF
                  free agent
                  hey thom thom, looking at this script i see uve put standard rotate, as a extra when holding control u get standard rotate, any way we could get linear scaling when holding alt?
                    I'd think so. Just need to find a spare moment.
                      rocorona
                      Can I suggest an update to this plugin? Wouldn't be more useful to have the "Move" function too added to Scale and Rotate? This can be done with 4 clicks instead of 3. First two to pick the "source" vector, and two more to say where to put the "target".
                      One can always reproduce the current behaviour, by clicking on the same point for the first and third click.
                      And, as a final enhancement, it would make a Copy, if the Ctrl key is pressed.
                        I've had the same thoughts - will add it to my To-Do list.
                          And a random function of a selection? Rotate + Scale
                          Edit
                          In fact exist in a certain way by Chris Fullmer Scale Rotate Multiple 😎
                          • demD
                            dem
                            Thanks! 👍
                            it would be nice to have RotaStretch mode by pressing Alt)
                            • E
                              Einstein
                              Thanks for it!
                              I'd add "clone" (copy) feature to TODO list 😉 It would be even more useful.
                              • E
                                Einstein
                                Hi!
                                It would be very useful to have ESC button to undo reference point selection. For example: I picked first refpoint but I want to change it without leaving the tool, then I press ESC and I can pick it again. The same with second and third refpoint.
                                • panixiaP
                                  panixia
                                  I just discovered this gem.. It would be also nicer with a toolbar button!
                                  Edit: nevermind, I managed to do it myself, using the toolbar editor plugin. 😄
                                  • 2 / 2
