    Model This: Sofas
    57 Posts 23 Posters 14.1k Views 23 Watching
    • shuraS Offline
      shura
      To get the border right I even decided to model in three pieces (kind of like the upholsterer would handle the cloth).
      This made it really easy to find the contour lines for the "border tubes" (sorry, dunno the right term for these).
      Nice to see your old avatar again Pete - very familiar πŸ˜„
      • jo-keJ Offline
        jo-ke
        Very very intertessting thread. I have to practise and to learn my lessons. I'm still not good enouhg in modelling. As soon as I have more time I'm trying to make my modell of this theme...
        http://www.zz7.de
        • RichardR Offline
          Richard
          Just for your info mate - "piping" - I know sounds more like a plumbing term! πŸ˜•
          BUILTBRAND.COM.AU
          • shuraS Offline
            shura
            Thank you Richard! yes, piping sounds a bit weird... well, I am still very unexperienced with technical terms in english.
            (I guess that the textile industry has a mind bending nomenclature in every language πŸ˜† )
            for piping I also found:
            • cording
            • pin-tuck
            • piping cord
            • tuck
            • tucking
            πŸŽ‰
            • I Offline
              imabzeous
              Can any one help me, whats thi SDS2
                SDS2 would be Subdivide and Smooth 2 but it has not been released yet.
                • jo-keJ Offline
                  jo-ke
                  What technic do you use to do the piping? I still have problems to do that.
                  http://www.zz7.de
                  • ely862meE Offline
                    ely862me
                    When subdividing usually the geometry has itself the line for piping detail,u just have to select it,but sometimes u must make the path for the piping with some tools on surface or intersection methods.
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • jo-keJ Offline
                      jo-ke
                      OK, I've subdivided the group but I've got no glue how to work on...
                      http://www.zz7.de
                      • shuraS Offline
                        shura
                        I was really happy with the method to separate my proxy before subdividing.
                        Then the path selection is nothing to worry about.
                        • boofredlayB Offline
                          boofredlay
                          That is a great technique shura.
                            Ands43
                            Wow! Some of the people on this forum are crazy good! I'm reasonably experienced 3 years, but well WOW!
                            What is/are SDS2, FFD and lines2cylinder? Where can I find them.
                            Are the images rendered in a separate renderer?
                              SDS2 is a soon to be released plugin by Whaat, but you can get SDS v1 here
                              FFD is Free Form Divide which is available here
                              Lines 2cyclinder is here
                              Don't forget to thank the Authors πŸ˜‰
                                Ands43
                                Thanks rclub24, I'll have a look!
                                • jo-keJ Offline
                                  jo-ke
                                  are you subdividing each piece seperatly or do you make one group?
                                  I'm still in touble with the piping...
                                  my result looks like this:
                                  http://www.zz7.de
                                  • shuraS Offline
                                    shura
                                    Sorry Jo-ke, I missed your question πŸ˜’
                                    Subdivision is done on each part of the shell separately. After that they match as if they have been processed in one piece.
                                    Then you will find it easy to select the border of one of the parts to make the piping with L2C.
                                    From your picture it looks like you need to add the piping for the backrest, too. And maybe you could try to change the bevel on the bottom sides left and right, to reduce the bulging.
                                    Eric, thank you! getting good critiques from you really means a lot.
                                    cheers
                                    alex
                                    • olisheaO Offline
                                      olishea
                                      nice work guys....and good challenge. hats off solo.
                                      jo-ke...you know you don't need to subdivide a group? Just triple click anything and subdivide so you can make transformations directly to mesh without having the purple proxy .
                                      oli
                                      • jo-keJ Offline
                                        jo-ke
                                        Ah, thank you! I will try that.
                                        http://www.zz7.de
                                        • jarynzlesaJ Offline
                                          jarynzlesa
                                          super. just mark.
                                          http://www.vizualizaceschodiste.mypage.cz/
                                          • jo-keJ Offline
                                            jo-ke
                                            I'll wait for SDS2 and try that again
                                            http://www.zz7.de
                                            • 2 / 3
