    Model This: Sofas
    57 Posts 23 Posters 15.9k Views 23 Watching
    • jo-keJ
      jo-ke
      What technic do you use to do the piping? I still have problems to do that.
      http://www.zz7.de
      • ely862meE
        ely862me
        When subdividing usually the geometry has itself the line for piping detail,u just have to select it,but sometimes u must make the path for the piping with some tools on surface or intersection methods.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • jo-keJ
          jo-ke
          OK, I've subdivided the group but I've got no glue how to work on...
          http://www.zz7.de
          • shuraS
            shura
            I was really happy with the method to separate my proxy before subdividing.
            Then the path selection is nothing to worry about.
            • boofredlayB
              boofredlay
              That is a great technique shura.
                Ands43
                Wow! Some of the people on this forum are crazy good! I'm reasonably experienced 3 years, but well WOW!
                What is/are SDS2, FFD and lines2cylinder? Where can I find them.
                Are the images rendered in a separate renderer?
                  SDS2 is a soon to be released plugin by Whaat, but you can get SDS v1 here
                  FFD is Free Form Divide which is available here
                  Lines 2cyclinder is here
                  Don't forget to thank the Authors πŸ˜‰
                    Ands43
                    Thanks rclub24, I'll have a look!
                    • jo-keJ
                      jo-ke
                      are you subdividing each piece seperatly or do you make one group?
                      I'm still in touble with the piping...
                      my result looks like this:
                      http://www.zz7.de
                      • shuraS
                        shura
                        Sorry Jo-ke, I missed your question πŸ˜’
                        Subdivision is done on each part of the shell separately. After that they match as if they have been processed in one piece.
                        Then you will find it easy to select the border of one of the parts to make the piping with L2C.
                        From your picture it looks like you need to add the piping for the backrest, too. And maybe you could try to change the bevel on the bottom sides left and right, to reduce the bulging.
                        Eric, thank you! getting good critiques from you really means a lot.
                        cheers
                        alex
                        • olisheaO
                          olishea
                          nice work guys....and good challenge. hats off solo.
                          jo-ke...you know you don't need to subdivide a group? Just triple click anything and subdivide so you can make transformations directly to mesh without having the purple proxy .
                          oli
                          • jo-keJ
                            jo-ke
                            Ah, thank you! I will try that.
                            http://www.zz7.de
                            • jarynzlesaJ
                              jarynzlesa
                              super. just mark.
                              http://www.vizualizaceschodiste.mypage.cz/
                              • jo-keJ
                                jo-ke
                                I'll wait for SDS2 and try that again
                                http://www.zz7.de
                                • K
                                  krash88
                                  I was just wondering how Solo got his proxy to smooth so nicely... I just bought a copy of Artisan and hoped that the algorithm had improved, but I'm stuck with the same results as the original SD&S.
                                  http://i109.photobucket.com/albums/n65/krash88/001.jpg
                                  http://i109.photobucket.com/albums/n65/krash88/002.jpg
                                  http://i109.photobucket.com/albums/n65/krash88/003.jpg
                                  I have tried to smooth this same model using a proxy similar to what Solo has a few posts above with the same results. Am I doing something wrong?
                                  • ely862meE
                                    ely862me
                                    U need to make corners like this.
                                    • K
                                      krash88
                                      Thanks, I'll need to wait until I get back to work tomorrow to try that out. However, I have used Fredo's RoundCorner plug to bevel the same model into something a little more similar to Solo's proxy in post #6 in this thread. Still, I get something close to the same result that I posted earlier. I'm just looking for a more efficient work-flow and I'm wondering if that is indeed the final proxy or if more edges or any creases were added to obtain the final smoothed result. Thanks again!
                                        Scostumatu
                                        hi guys
                                        can anyone do a small newbie tutorial on this?
                                        Have just purchased artisan and would love to get my head around subd modelling in sketchup
                                        Would be much appreciated
                                        • FrederikF
                                          Frederik
                                          Please take a look in the Organic Modelling section, where some tutorials already have been posted...
                                          Cheers
                                          Kim Frederik
                                            Scostumatu
                                            Thanks. saw that earlier but there isnt much there. I suppose I will wait until some of the gurus release some tuts πŸ˜„
                                            cant wait!
                                            • 3 / 3
