    Model This: Sofas
    57 Posts 23 Posters 13.4k Views 23 Watching
      jchau2007
      WOW that's impressive to see the SDS tool comes alive. I love how Pete (Solo) use the SDS to model his version. I've learned so much about SDS just with this exercise. great job guys.
        Scostumatu
        WHOA this is unbelievable!!!!
        Any tutorials on this guys? So is that just 1 plug in that does all this??
        LOVE IT!
        • brodieB Offline
          brodie
          When do you run the lines2cylinder ruby? Do you have to do this after SDS by selecting a path of really short lines? And what is lines2cylinder? is that the same thing as Pipe Along Path?
          -Brodie
          • soloS Offline
            Yes, after I subdivided the mesh I made it a group then using TOS (tools on surface) I created the path for piping.
            • shuraS Offline
              shura
              To get the border right I even decided to model in three pieces (kind of like the upholsterer would handle the cloth).
              This made it really easy to find the contour lines for the "border tubes" (sorry, dunno the right term for these).
              Nice to see your old avatar again Pete - very familiar πŸ˜„
              • jo-keJ Offline
                jo-ke
                Very very intertessting thread. I have to practise and to learn my lessons. I'm still not good enouhg in modelling. As soon as I have more time I'm trying to make my modell of this theme...
                http://www.zz7.de
                • RichardR Offline
                  Richard
                  Just for your info mate - "piping" - I know sounds more like a plumbing term! πŸ˜•
                  BUILTBRAND.COM.AU
                  • shuraS Offline
                    shura
                    Thank you Richard! yes, piping sounds a bit weird... well, I am still very unexperienced with technical terms in english.
                    (I guess that the textile industry has a mind bending nomenclature in every language πŸ˜† )
                    for piping I also found:
                    • cording
                    • pin-tuck
                    • piping cord
                    • tuck
                    • tucking
                    πŸŽ‰
                    • I Offline
                      imabzeous
                      Can any one help me, whats thi SDS2
                        SDS2 would be Subdivide and Smooth 2 but it has not been released yet.
                        • jo-keJ Offline
                          jo-ke
                          What technic do you use to do the piping? I still have problems to do that.
                          http://www.zz7.de
                          • ely862meE Offline
                            ely862me
                            When subdividing usually the geometry has itself the line for piping detail,u just have to select it,but sometimes u must make the path for the piping with some tools on surface or intersection methods.
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • jo-keJ Offline
                              jo-ke
                              OK, I've subdivided the group but I've got no glue how to work on...
                              http://www.zz7.de
                              • shuraS Offline
                                shura
                                I was really happy with the method to separate my proxy before subdividing.
                                Then the path selection is nothing to worry about.
                                • boofredlayB Offline
                                  boofredlay
                                  That is a great technique shura.
                                    Ands43
                                    Wow! Some of the people on this forum are crazy good! I'm reasonably experienced 3 years, but well WOW!
                                    What is/are SDS2, FFD and lines2cylinder? Where can I find them.
                                    Are the images rendered in a separate renderer?
                                      SDS2 is a soon to be released plugin by Whaat, but you can get SDS v1 here
                                      FFD is Free Form Divide which is available here
                                      Lines 2cyclinder is here
                                      Don't forget to thank the Authors πŸ˜‰
                                        Ands43
                                        Thanks rclub24, I'll have a look!
                                        • jo-keJ Offline
                                          jo-ke
                                          are you subdividing each piece seperatly or do you make one group?
                                          I'm still in touble with the piping...
                                          my result looks like this:
                                          http://www.zz7.de
                                          • shuraS Offline
                                            shura
                                            Sorry Jo-ke, I missed your question πŸ˜’
                                            Subdivision is done on each part of the shell separately. After that they match as if they have been processed in one piece.
                                            Then you will find it easy to select the border of one of the parts to make the piping with L2C.
                                            From your picture it looks like you need to add the piping for the backrest, too. And maybe you could try to change the bevel on the bottom sides left and right, to reduce the bulging.
                                            Eric, thank you! getting good critiques from you really means a lot.
                                            cheers
                                            alex
                                            • 2 / 3
