    Model This: Sofas
    57 Posts 23 Posters 15.9k Views 23 Watching
    • shuraS
      shura
      I was really happy with the method to separate my proxy before subdividing.
      Then the path selection is nothing to worry about.
      • boofredlayB
        boofredlay
        That is a great technique shura.
          Ands43
          Wow! Some of the people on this forum are crazy good! I'm reasonably experienced 3 years, but well WOW!
          What is/are SDS2, FFD and lines2cylinder? Where can I find them.
          Are the images rendered in a separate renderer?
            SDS2 is a soon to be released plugin by Whaat, but you can get SDS v1 here
            FFD is Free Form Divide which is available here
            Lines 2cyclinder is here
            Don't forget to thank the Authors 😉
              Ands43
              Thanks rclub24, I'll have a look!
              • jo-keJ
                jo-ke
                are you subdividing each piece seperatly or do you make one group?
                I'm still in touble with the piping...
                my result looks like this:
                http://www.zz7.de
                • shuraS
                  shura
                  Sorry Jo-ke, I missed your question 😒
                  Subdivision is done on each part of the shell separately. After that they match as if they have been processed in one piece.
                  Then you will find it easy to select the border of one of the parts to make the piping with L2C.
                  From your picture it looks like you need to add the piping for the backrest, too. And maybe you could try to change the bevel on the bottom sides left and right, to reduce the bulging.
                  Eric, thank you! getting good critiques from you really means a lot.
                  cheers
                  alex
                  • olisheaO
                    olishea
                    nice work guys....and good challenge. hats off solo.
                    jo-ke...you know you don't need to subdivide a group? Just triple click anything and subdivide so you can make transformations directly to mesh without having the purple proxy .
                    oli
                    • jo-keJ
                      jo-ke
                      Ah, thank you! I will try that.
                      http://www.zz7.de
                      • jarynzlesaJ
                        jarynzlesa
                        super. just mark.
                        http://www.vizualizaceschodiste.mypage.cz/
                        • jo-keJ
                          jo-ke
                          I'll wait for SDS2 and try that again
                          http://www.zz7.de
                          • K
                            krash88
                            I was just wondering how Solo got his proxy to smooth so nicely... I just bought a copy of Artisan and hoped that the algorithm had improved, but I'm stuck with the same results as the original SD&S.
                            http://i109.photobucket.com/albums/n65/krash88/001.jpg
                            http://i109.photobucket.com/albums/n65/krash88/002.jpg
                            http://i109.photobucket.com/albums/n65/krash88/003.jpg
                            I have tried to smooth this same model using a proxy similar to what Solo has a few posts above with the same results. Am I doing something wrong?
                            • ely862meE
                              ely862me
                              U need to make corners like this.
                              Elisei (sketchupper)
                              Come and See EliseiDesign
                              • K
                                krash88
                                Thanks, I'll need to wait until I get back to work tomorrow to try that out. However, I have used Fredo's RoundCorner plug to bevel the same model into something a little more similar to Solo's proxy in post #6 in this thread. Still, I get something close to the same result that I posted earlier. I'm just looking for a more efficient work-flow and I'm wondering if that is indeed the final proxy or if more edges or any creases were added to obtain the final smoothed result. Thanks again!
                                  Scostumatu
                                  hi guys
                                  can anyone do a small newbie tutorial on this?
                                  Have just purchased artisan and would love to get my head around subd modelling in sketchup
                                  Would be much appreciated
                                  • FrederikF
                                    Frederik
                                    Please take a look in the Organic Modelling section, where some tutorials already have been posted...
                                    Cheers
                                    Kim Frederik
                                      Scostumatu
                                      Thanks. saw that earlier but there isnt much there. I suppose I will wait until some of the gurus release some tuts 😄
                                      cant wait!
                                        mwm5053
                                        Just been reading this and wondered how to do those corner. I tried Fredo6 bevel to now avail
                                        2011 iMac
                                        SU 2015 Pro, 2017 Make
                                        V2 Twilight
                                        macOS Sierra 10.12.5
                                        • ely862meE
                                          ely862me
                                          Hi Walt !
                                          I mentioned the plugin I used in the message I sent to you the other day . I said it is Round corner plugin which can be found here http://sketchucation.com/forums/viewtopic.php?t=20485 . I used the bevel function .
                                          See attached for ideas !
                                          Artisan example by EliseiDesign.skp
                                          Also please visit this page http://sketchucation.com/forums/viewtopic.php?t=42938 .
                                          Have a nice day !
                                            mwm5053
                                            Thanks Elisei, that helped very much
                                            2011 iMac
                                            V2 Twilight
                                            • 3 / 3
