    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      cupko
      In rollout menu Make by Component select No instead fur_instance.
      • fuzzionF Offline
        fuzzion
        I tried that on both SU8 and 7.1 but it still does not work. I can click the 'make fur' button
        a million times but nothing happens 😞
        "Only the dead have seen the end of war" - Plato
          tak2hata
          Hi fuzzion.
          now ,I couldn't find the solution for this problem.
          I want to see the dialog of the "fur" on your computer.
          and show "ruby console" before clicking the "make fur" button.
          (showing "ruby console" is in "windows" in the menubar)
          if it shows some error message when clicking make fur button,
          I want to see it.
          Thanks.
          by TAK2HATA
            gr8fzy1
            I had an older version that was working for me in SketchUp 7, can't remember what version it was, but I recently downloaded the newest version for my SketchUp 8 Pro (fur_en_15, I think it was called) and it's not functioning right. I get green dots instead of grass or fur. I'll post some screenshots for you.
            Older fur maker in SKUP 7:
            http://i44.photobucket.com/albums/f42/gr8fzy1/FurInSKUP7.png
            Fur_en_15 in SKUP 8 Pro:
            http://i44.photobucket.com/albums/f42/gr8fzy1/FurProblemsSKUP8.png
            In the meantime, I've copy/pasted the older furmaker into SKUP 8 and THAT is working, it's just growing the grass upside down.
            • romboutR Offline
              rombout
              whatever i try icant seem to make anything....
              im trying to make simple grass like the example on page one, but im using a component. the mesh only gets rotated just a bit.
              Also when i try it with plain geometry nothing really happens.
              im using su6 on mac osx 10.5.6
              • fuzzionF Offline
                fuzzion
                Hi fuzzion.
                I want to see it.
                Thanks.
                First I want to say thank you for making this plugin πŸ˜„
                Regarding Ruby console, nothing shows up at all.
                Only green dots appear on the selected plane.
                Should I install an older version of Fur?
                I have tried re-installing plugin into folders, but
                that did not help. Should i re-install
                Sketchup? Do you think another plugin is causing the problem?
                PS. Is it possible for future releases to include make Hair with gravity ? Like create cylinderical shape with taper at the end. β˜€
                Below is the screenshot .
                Su7.1
                • kaluK Offline
                  kalu
                  I have the same results in Sketchup 8 Pro, they make some kind of dots that's it...
                  The old version works but I wish the new version works in S8. Thank you for your hard work.
                  the Plugins is awesome...
                  THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                  • kaluK Offline
                    kalu
                    Hi:
                    Can you fix the problem with Sketchu 8 and works with other plugins or we need to keepp using the older version?.... πŸ‘Ž
                      Jim
                      After you see the green dots, press the ENTER key.
                      • fuzzionF Offline
                        fuzzion
                        That works ...You are a legend mate πŸ‘
                          lapx
                          Can the settings be saved to the harddrive in a file to be shared with others?
                            tak2hata
                            Hi fuzzion,gr8fzy1,kalu and Jim.
                            I'm sorry about not visitting here recently.
                            Thank you very much for this solution.
                            In Webdialog,
                            "Preview fur" makes only green points for examining density.
                            "Make fur" makes furs.
                            In Inputbox,
                            "OK" button makes preview points everytime.
                            after that ,press Enter key to make fur.
                            or press ESC key to return Inputbox.
                            Hi,rombout.
                            Perhaps this is not solution,I think now.
                            The First Idea:
                            Make fur is only makes on faces.(and mesh)
                            When the mesh is in group or component and selecting group,MakeFur doesn't work.
                            Open the group and select faces or meshes.
                            The Second Idea:
                            That is bug.
                            I didn't solve the problem about webdialog in mac os ,yet.
                            If it does not make fur by using inputbox too,this problem is bug in recent version.
                            So I will upload older versions.
                            Thanks.
                            by TAK2HATA
                            • JClementsJ Offline
                              JClements
                              ? Wondering if anyone familiar with the various settings could produce a PDF (or some other document type) that would explain and diagram each of the parameters. ?
                              • F Offline
                                Fletch
                                JC,
                                Does THIS help at all?
                                http://twilightrender.com/phpBB3/download/file.php?id=3803
                                Fletch
                                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                  JClements
                                  Hi Fletch:
                                  Yes it does. What a nice Christmas present.
                                  Regards,
                                  John
                                    rsalgadojf
                                    ItΒ΄s very good but the file came from 27mb to 100mb!
                                    So difficulty
                                    • RichardR Offline
                                      Richard
                                      Hey Fletch thanks mate for posting that reference, will help most people a BUNDLE! πŸ‘
                                      BUILTBRAND.COM.AU
                                        keanuar
                                        this plug-in is SICK!!! save me tones of time when rendering in vray. no need to constantly tweaking the bump & displacement again. good job buddy!
                                          JavaKom09088
                                          @xrok1 said:
                                          8-) this is greaaaat!
                                          hi, may i know what is ur setting for this? i just cant create such natural look of the grass distribute on the ground... thank you
                                          • plot-parisP Offline
                                            plot-paris
                                            hey Fletch, really great reference card. if plugin creators were able to add information to the instructor window in SketchUp, it should be this reference card...
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 32
                                            • 33
                                            • 24 / 33
