    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 33.7k Views 13 Watching
    • Z Offline
      Zacchia
      Hi honoluludesktop
      Thanks for this plugin, it works fine πŸ˜„
      I just miss a icon on the button
      • honoluludesktopH Offline
        honoluludesktop
        Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
          honoluludesktop
          Oops. Post deleted, see below.
          • Z Offline
            Zacchia
            Now it is fine!! Thanks again.
            • KrisidiousK Offline
              Krisidious
              installed... thank you.
              By: Kristoff Rand
                honoluludesktop
                Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                • Z Offline
                  Zacchia
                    maxosmedia
                    Error Loading File reverse_back_face_v1.9.rb
                    can't convert nil into String
                    SU8, Mac OS X 10.6
                      honoluludesktop
                      The app. won't even load? Let me download my own file and try to load it.
                        honoluludesktop
                        Shoots, it down loads, installs, and runs OK on my PC. I will have to get help before I can find out what the problem is with running the code on a Mac. Just to make sure, can you verify that the plugin will not even load? If it loads then fails to run, can you open the Ruby Console, run the app, and post any error message? If message too long, the top 5-6 lines should be enough.
                          honoluludesktop
                          OK, fixed here, thanks to jim.
                            darkbass
                            thanks
                            • pbacotP Offline
                              SU8, Mac OS X 10.6
                              Sorry, I just downloaded and still get the error message on Mac OSX 10.6 SU8 Pro.
                              I have been trying to sort faces on welded follow me elements. Half the faces are backwards. Orient faces always flips some wrong ones forward. Front face tool is slow and still doesn't catch them all. These are welded surfaces but each face in the softened shape has to be changed separately. Fortunately most of the rendering so far hasn't mattered for some reason.
                                driven
                                @pbacot,
                                does orient faces work properly if you turn on hidden geometry first?
                                it did in v7 on a mac...
                                • pbacotP Offline
                                  Yes it does work better, but I still have other nearby faces flipping backwards for no apparent reason. I think there is just a lot of geometry on this molding (yep, more than necessary but it looks nice in the detail renderings, which was my main goal). I think in this case I need to separate more of the geometry, then these routines should work better.
                                  Peter
                                    honoluludesktop
                                    1. Do you have the folder "hdt_folder" in the "plugins" folder?
                                    2. Did you select the appropriate scanning accuracy? If you have small faces, you may need to select "high".
                                    3. Are your faces too small? Sometimes this is a sketchup problem. The workaround is to scale the part up, reverse, then back down.
                                    At times, the plugin is not 100% accurate. Sometimes there are one or two faces that must be manually reversed. Can you pose a screen capture of the reversed model with problem faces?
                                    • pbacotP Offline
                                      Honolulu,
                                      No, it doesn't load. Just gives the error message above. The Hdt folder is there.
                                      Peter
                                        honoluludesktop
                                        placot, Please verify that you have installed v1.9. I will post a special version of Reverse_back_face to step through the plugin to see where it crashes.
                                        Others, If you can get the plugin to run by turning on "hidden geometry", first open the ruby console, then run the plugin. If you get a error message in the ruby console, post a screen print of it here.
                                        Thanks, hdt
                                        • pbacotP Offline
                                          Yes, sir. It is v. 1.9. and hdt folder is in the plugins folder. Thanks, Peter
                                            a5864791
                                            I like it!good!
                                            • 2 / 2
