    [Talk] Plugins Index
    179 Posts 70 Posters 79.3k Views 70 Watching
      tfdesign
      Excellent list Jim. Keep up the good work, and thanks too! πŸ˜„
      Tom
        Ben Ritter
        Hey Jim, thank you so very much.
        • bmikeB Offline
          bmike
          πŸ‘
          thanks. just found the list.
          • H Offline
            haynesc
            hello ...
            Im knowingly going to post this expecting some hostle response ...
            Would it be possible to have a link at the end of the plugin index to "Download All" in a zip file ?
              No hostile response at all.
              However to archive all into one ZIP file and also to maintain that archive with the latest releases would need someone to do that every day (I know no way of automating it).
              Also, by this time I don't even know how big that archive would be (could definitely not be attached here). Maybe it would be a kind of "luxury" (for the bandwidth) to allow the whole archive even though it is obvious that no-one would ever need allthe plugins listed above
              • H Offline
                haynesc
                True that the files would be large ...
                How about grouping the plugins into categories ...
                  Chris,
                  Can i ask what is it you find is the issue with this index or plugins at SCF in general? I'm on a fact finding mission here not a witch hunt to see if we can improve it. So your comments are valued.
                  Rich
                    Added Adam's Goldilock 2.0 (was missing as it did not have the [Plugin] tag in the subject - added that, too)
                      Jim
                      The list isn't manually maintained. It is generated from the Title of each post, which must use the [Plugin] notation in order to be included. Categories could be implemented, but then each title (or post) would need to be edited to include some type of category information in a consistent format.
                        arjunmax09
                        Is it possible that we connect this plugins index to Ruby Library Depot and Smustard..so SCF members get notifications here only??
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          lee_
                          thanks Jimmy
                            lapx
                            These should be index alphabetical order!You will see the authors name when you get there. It's harder to find them this way.
                            I'm sure a poll would agree maybe?
                              They arein alphabetical order (listed under the authors' names which are again in alphabetical order).
                              The "recent" ones are in date/time order.
                                lapx
                                Thanks Gaeius, I'm going Blind. there is a list in alphabetical order...
                                😳 http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
                                  No, I mean the first post of the topic we are in right now.
                                  • kaluK Offline
                                    kalu
                                    Thank you Jim great work!!!!!!!!!
                                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                      Jim
                                      You're welcome. It's good to know it's useful.
                                        d12dozr
                                        Its veryuseful...Thanks, Jim
                                        http://goo.gl/f7ooYh
                                          paddyclown
                                          Yes, Jim this is a VERY useful thing... I just noticed though that TIG's slicer script seems to be missing... is he working on an update maybe ?
                                          Anyway, thanks & keep up the great work πŸ˜„
                                            PS: Slicer v3.1 is available at http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
                                            I am working on a slicer/slotter update... but am bogged down by other things at the moment...
                                            • 2 / 9
