    [Talk] Plugins Index
    179 Posts 70 Posters 102.7k Views 70 Watching
    • L
      lee_
      thanks Jimmy
      • L
        lapx
        These should be index alphabetical order!You will see the authors name when you get there. It's harder to find them this way.
        I'm sure a poll would agree maybe?
        • GaieusG
          They arein alphabetical order (listed under the authors' names which are again in alphabetical order).
          The "recent" ones are in date/time order.
          • L
            lapx
            Thanks Gaeius, I'm going Blind. there is a list in alphabetical order...
            ๐Ÿ˜ณ http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
            • GaieusG
              No, I mean the first post of the topic we are in right now.
              • kaluK
                kalu
                Thank you Jim great work!!!!!!!!!
                THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                  Jim
                  You're welcome. It's good to know it's useful.
                    d12dozr
                    Its veryuseful...Thanks, Jim
                    http://goo.gl/f7ooYh
                    • P
                      paddyclown
                      Yes, Jim this is a VERY useful thing... I just noticed though that TIG's slicer script seems to be missing... is he working on an update maybe ?
                      Anyway, thanks & keep up the great work ๐Ÿ˜„
                        PS: Slicer v3.1 is available at http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
                        I am working on a slicer/slotter update... but am bogged down by other things at the moment...
                        • P
                          paddyclown
                          Thanks TIG, that's the version i have, & sadly on SU 7.1 it refuses to create the flattened on groundplane sections... & in SU8 it sometimes doesnt work either, but that is on very complex models !
                          I wonder if you know anything about why some plugins work & others not in a vista environment (french language)? Vista seems to create duplicates, but not of all plugins, in a virtual store "C:\Users"xx"\AppData\Local\VirtualStore\Program Files\Google\Google SketchUp 7" very odd, dunno if that has any influence of ruby scripts, anyway some days I feel like going back to XP where pretty much everything works fine...
                          Thanks for all your hard work & good luck
                          best
                          Paddy
                            Vista can be really flaky if you don't have 'full' access rights to the ../Plugins folder and its sub-folders - as an admin you could try to reset them under Preferences > Security... Otherwise you think they are installed and they are really in some 'Compatibility Files' folder !
                            • P
                              paddyclown
                              TIG, thanks, yes I have checked on that... I had already attributed full rights as I'd seen similar comments, but have redone it to be sure ๐Ÿ˜„ Strangely, I have never seen this compatibility folder, but heh, windows vista is such a soup, who knows...
                              I'll see if everything is better now & let you know ๐Ÿ˜„
                              • P
                                pankaj_tamore
                                Hello to every one who is online & offline from sketchup community
                                i want to thank to each that plugin developer whose plug in i dowmloded great job guys keep it up while using these plugins i have only one question swinging in my mind how you people did this? it is magical ๐Ÿ˜
                                • RomBR
                                  RomB
                                  can i find a plug-in for SketchUp like BodyPaint 3D? i have need in painting with textures on models...is it real?
                                  • E
                                    Eloise Lee
                                    Thanks Jim!!
                                    the list is very useful.
                                    it help me a lot when i'm searching with keyword.
                                    • sumasterS
                                      sumaster
                                      Hello jim,
                                      its too good all in one ......
                                      Thank you very much ......
                                      Good luck ...
                                      Thank you,
                                      SUmaster
                                      • I
                                        igooo
                                        hi, thank you
                                        this is very great,..
                                        • Al HartA
                                          Al Hart
                                          I presume you know about this trick:
                                          Search for:
                                          site:http://forums.sketchucation.com pdf
                                          to find all Forum entries containing the work PDF (for example)
                                          Al Hart
                                          IRender nXt from Render Plus
                                          • B
                                            Builder Boy
                                            I am "Builder Boy", not "mcjohnston"
                                            All my plugins
                                            • 3 / 9
