    [Talk] Plugins Index
    179 Posts 70 Posters 102.7k Views 70 Watching
      Jim
      @haynesc said:
      True that the files would be large ...
      How about grouping the plugins into categories ...
      The list isn't manually maintained. It is generated from the Title of each post, which must use the [Plugin] notation in order to be included. Categories could be implemented, but then each title (or post) would need to be edited to include some type of category information in a consistent format.
        arjunmax09
        Is it possible that we connect this plugins index to Ruby Library Depot and Smustard..so SCF members get notifications here only??
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
        • L
          lee_
          thanks Jimmy
          • L
            lapx
            These should be index alphabetical order!You will see the authors name when you get there. It's harder to find them this way.
            I'm sure a poll would agree maybe?
            • GaieusG
              They arein alphabetical order (listed under the authors' names which are again in alphabetical order).
              The "recent" ones are in date/time order.
              • L
                lapx
                Thanks Gaeius, I'm going Blind. there is a list in alphabetical order...
                😳 http://forums.sketchucation.com/viewtopic.php?f=323&t=23989
                • GaieusG
                  No, I mean the first post of the topic we are in right now.
                  • kaluK
                    kalu
                    Thank you Jim great work!!!!!!!!!
                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                      Jim
                      You're welcome. It's good to know it's useful.
                        d12dozr
                        Its veryuseful...Thanks, Jim
                        http://goo.gl/f7ooYh
                        • P
                          paddyclown
                          Yes, Jim this is a VERY useful thing... I just noticed though that TIG's slicer script seems to be missing... is he working on an update maybe ?
                          Anyway, thanks & keep up the great work πŸ˜„
                            PS: Slicer v3.1 is available at http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
                            I am working on a slicer/slotter update... but am bogged down by other things at the moment...
                            • P
                              paddyclown
                              Thanks TIG, that's the version i have, & sadly on SU 7.1 it refuses to create the flattened on groundplane sections... & in SU8 it sometimes doesnt work either, but that is on very complex models !
                              I wonder if you know anything about why some plugins work & others not in a vista environment (french language)? Vista seems to create duplicates, but not of all plugins, in a virtual store "C:\Users"xx"\AppData\Local\VirtualStore\Program Files\Google\Google SketchUp 7" very odd, dunno if that has any influence of ruby scripts, anyway some days I feel like going back to XP where pretty much everything works fine...
                              Thanks for all your hard work & good luck
                              best
                              Paddy
                                Vista can be really flaky if you don't have 'full' access rights to the ../Plugins folder and its sub-folders - as an admin you could try to reset them under Preferences > Security... Otherwise you think they are installed and they are really in some 'Compatibility Files' folder !
                                • P
                                  paddyclown
                                  TIG, thanks, yes I have checked on that... I had already attributed full rights as I'd seen similar comments, but have redone it to be sure πŸ˜„ Strangely, I have never seen this compatibility folder, but heh, windows vista is such a soup, who knows...
                                  I'll see if everything is better now & let you know πŸ˜„
                                  • P
                                    pankaj_tamore
                                    Hello to every one who is online & offline from sketchup community
                                    i want to thank to each that plugin developer whose plug in i dowmloded great job guys keep it up while using these plugins i have only one question swinging in my mind how you people did this? it is magical 😍
                                    • RomBR
                                      RomB
                                      can i find a plug-in for SketchUp like BodyPaint 3D? i have need in painting with textures on models...is it real?
                                      • E
                                        Eloise Lee
                                        Thanks Jim!!
                                        the list is very useful.
                                        it help me a lot when i'm searching with keyword.
                                        • sumasterS
                                          sumaster
                                          Hello jim,
                                          its too good all in one ......
                                          Thank you very much ......
                                          Good luck ...
                                          Thank you,
                                          SUmaster
                                          • I
                                            igooo
                                            hi, thank you
                                            this is very great,..
                                            • 3 / 9
