    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 67.1k Views 27 Watching
    • EarthMoverE Offline
      EarthMover
      Must be other issues. It's really frustrating that there is no parsing progress bar. Or, the ability to have it only have to parse once. Seems like since it is just storing UV data, that as long as you don't move the camera, you should be able to reuse the same data. Nothing is more frustrating than having to wait for every test render.
      On another note, I tried to open SS's Snowberry model (which took about 5 minutes to open) and render with VfSU (with no materials)......after 30 minutes of parsing, i just gave up.
      Content Creator at Skapeup
        But you need to parse the whole lot again anyway to check if anything has changed.
        The next version should see some improvements though.
        That model is up in the millions in face count isn't it?
          Matt666
          Hi all.
          Sorry for the delay, I will see what I can do.
          Frenglish at its best !
          My scripts
            m48
            holy shit, it really works!!! ๐Ÿ˜ฎ you s-a-v-e my a-s-s.
            I need to give something in return men, i owe you one,you are my new hero.
              chango70
              Do you still need to do this with the new Vray? (v1.488) I seem to encouter problems when with Vray 1.488 after running this script (not 100% this was the culprit)
              Cheers
                No - Only with 1.05.30 and older. The new one might actually be faster if you use group/component materials.
                  dragonbizcut
                  I can not run the remove CG materials plugin, is the link broken or corrupted?
                    You have problem downloading or using the plugin?
                      chango70
                      Hey cheers, thats why...
                        AliMG
                        Thank-you Matt, Your plugin has saved me!
                          lukdoberder
                          nice plugin!definitely speed things up!thanks matt!
                          • dereiD Offline
                            derei
                            [FEATURE REQUEST]
                            It's a useful plugin, until I found it, I had to remove all materials from selection using This Plugin, then reassign materials only to geometry inside group/component -often I have different materials on faces.
                            I would like some features to this plugin: Now, with so many plugins, the Plugins Menu gets really crowded, so submenus are welcomed. So, I was thinking if you could add a feature to this plugin to remove all materials, something like this:
                            REMOVE MATERIALS
                            >Remove CG Materials
                            >Remove ALL Materials
                            In this way, instead of having two entries for those two plugins, I would have one single menu with two child options.
                            Also, if the inputbox could be disabled, to speed-up the usage. I never replaced CG material using the inputbox, so for me is just a unnecessary mouse click ๐Ÿ˜„ Actually, I'm curious if anyone uses that feature.
                            Thank you.
                            • ToboboT Offline
                              Tobobo
                              The link to the rapid share download doesn't work, can some post the script?
                              Toby
                              Philippians 4:13
                                It's attached straight to the post here:
                                http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                                • ToboboT Offline
                                  Tobobo
                                  Thanks Gai
                                  Toby
                                  Philippians 4:13
                                    Panga
                                    Thanks a lot for this plugin ! ๐Ÿ‘
                                      Myhand
                                      [FEATURE REQUEST]
                                      REMOVE MATERIALS
                                      >Remove CG Materials
                                      Thank you.
                                      This plugin should do what you want: http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                                      • srxS Offline
                                        srx
                                        Thank you MyHand. Very useful plugin which I haven't seen it before. ๐Ÿ‘
                                        www.saurus.rs
                                          blenditall
                                          Just wanted to add my thanks -- this plugin works perfectly!
                                          • 4 / 5
