    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 69.3k Views 27 Watching
      @dragonbizcut said:
      I can not run the remove CG materials plugin, is the link broken or corrupted?
      You have problem downloading or using the plugin?
        chango70
        @thomthom said:
        @chango70 said:
        Do you still need to do this with the new Vray? (v1.488)
        No - Only with 1.05.30 and older. The new one might actually be faster if you use group/component materials.
        Hey cheers, thats why...
          AliMG
          Thank-you Matt, Your plugin has saved me!
            lukdoberder
            nice plugin!definitely speed things up!thanks matt!
            • dereiD Offline
              derei
              [FEATURE REQUEST]
              It's a useful plugin, until I found it, I had to remove all materials from selection using This Plugin, then reassign materials only to geometry inside group/component -often I have different materials on faces.
              I would like some features to this plugin: Now, with so many plugins, the Plugins Menu gets really crowded, so submenus are welcomed. So, I was thinking if you could add a feature to this plugin to remove all materials, something like this:
              REMOVE MATERIALS
              >Remove CG Materials
              >Remove ALL Materials
              In this way, instead of having two entries for those two plugins, I would have one single menu with two child options.
              Also, if the inputbox could be disabled, to speed-up the usage. I never replaced CG material using the inputbox, so for me is just a unnecessary mouse click πŸ˜„ Actually, I'm curious if anyone uses that feature.
              Thank you.
              DESIGNER AND ARTIST DEREI.UK
              • ToboboT Offline
                Tobobo
                The link to the rapid share download doesn't work, can some post the script?
                Toby
                Philippians 4:13
                  It's attached straight to the post here:
                  http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                  • ToboboT Offline
                    Tobobo
                    Thanks Gai
                    Toby
                    Philippians 4:13
                      Panga
                      Thanks a lot for this plugin ! πŸ‘
                        Myhand
                        [FEATURE REQUEST]
                        REMOVE MATERIALS
                        >Remove CG Materials
                        Thank you.
                        This plugin should do what you want: http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                        • srxS Offline
                          srx
                          Thank you MyHand. Very useful plugin which I haven't seen it before. πŸ‘
                          www.saurus.rs
                            blenditall
                            Just wanted to add my thanks -- this plugin works perfectly!
                            • 5 / 5
