    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 71.2k Views 27 Watching
      AliMG
      Thank-you Matt, Your plugin has saved me!
      • L
        lukdoberder
        nice plugin!definitely speed things up!thanks matt!
        • dereiD
          derei
          [FEATURE REQUEST]
          It's a useful plugin, until I found it, I had to remove all materials from selection using This Plugin, then reassign materials only to geometry inside group/component -often I have different materials on faces.
          I would like some features to this plugin: Now, with so many plugins, the Plugins Menu gets really crowded, so submenus are welcomed. So, I was thinking if you could add a feature to this plugin to remove all materials, something like this:
          REMOVE MATERIALS
          >Remove CG Materials
          >Remove ALL Materials
          In this way, instead of having two entries for those two plugins, I would have one single menu with two child options.
          Also, if the inputbox could be disabled, to speed-up the usage. I never replaced CG material using the inputbox, so for me is just a unnecessary mouse click πŸ˜„ Actually, I'm curious if anyone uses that feature.
          Thank you.
          DESIGNER AND ARTIST DEREI.UK
          • ToboboT
            Tobobo
            The link to the rapid share download doesn't work, can some post the script?
            Toby
            Philippians 4:13
            • GaieusG
              It's attached straight to the post here:
              http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
              • ToboboT
                Tobobo
                Thanks Gai
                Toby
                Philippians 4:13
                • P
                  Panga
                  Thanks a lot for this plugin ! πŸ‘
                    Myhand
                    [FEATURE REQUEST]
                    REMOVE MATERIALS
                    >Remove CG Materials
                    Thank you.
                    This plugin should do what you want: http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                    • srxS
                      srx
                      Thank you MyHand. Very useful plugin which I haven't seen it before. πŸ‘
                      www.saurus.rs
                      • B
                        blenditall
                        Just wanted to add my thanks -- this plugin works perfectly!
                        • 5 / 5
