    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 71.2k Views 27 Watching
    • C
      chango70
      @thomthom said:
      @chango70 said:
      Do you still need to do this with the new Vray? (v1.488)
      No - Only with 1.05.30 and older. The new one might actually be faster if you use group/component materials.
      Hey cheers, thats why...
        AliMG
        Thank-you Matt, Your plugin has saved me!
        • L
          lukdoberder
          nice plugin!definitely speed things up!thanks matt!
          • dereiD
            derei
            [FEATURE REQUEST]
            It's a useful plugin, until I found it, I had to remove all materials from selection using This Plugin, then reassign materials only to geometry inside group/component -often I have different materials on faces.
            I would like some features to this plugin: Now, with so many plugins, the Plugins Menu gets really crowded, so submenus are welcomed. So, I was thinking if you could add a feature to this plugin to remove all materials, something like this:
            REMOVE MATERIALS
            >Remove CG Materials
            >Remove ALL Materials
            In this way, instead of having two entries for those two plugins, I would have one single menu with two child options.
            Also, if the inputbox could be disabled, to speed-up the usage. I never replaced CG material using the inputbox, so for me is just a unnecessary mouse click πŸ˜„ Actually, I'm curious if anyone uses that feature.
            Thank you.
            DESIGNER AND ARTIST DEREI.UK
            • ToboboT
              Tobobo
              The link to the rapid share download doesn't work, can some post the script?
              Toby
              Philippians 4:13
              • GaieusG
                It's attached straight to the post here:
                http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
                • ToboboT
                  Tobobo
                  Thanks Gai
                  Toby
                  Philippians 4:13
                  • P
                    Panga
                    Thanks a lot for this plugin ! πŸ‘
                      Myhand
                      [FEATURE REQUEST]
                      REMOVE MATERIALS
                      >Remove CG Materials
                      Thank you.
                      This plugin should do what you want: http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                      • srxS
                        srx
                        Thank you MyHand. Very useful plugin which I haven't seen it before. πŸ‘
                        www.saurus.rs
                        • B
                          blenditall
                          Just wanted to add my thanks -- this plugin works perfectly!
                          • 5 / 5
