    [Plugin] Bezier Patch v1.1
    22 Posts 14 Posters 28.1k Views 14 Watching
      remus
      have you restarted sketchup since you installed the plugin? if not you need to.
      • ely862meE Offline
        ely862me
        for me isn t working..unzipped in plugins folder..should i do something else?
        after typeing that in ruby console appeared this
        load 'bez-patch/bez-patch.rb'
        Error: #<SyntaxError: (eval):149: compile error
        (eval):149: syntax error
        (eval):149
        Elisei (sketchupper)
        Come and See EliseiDesign
          Julius
          yes, you should copy the file "bez-patch.rb" from the "bez-patch" folder to the "plugins" folder.
          then you should see the control in Draw -> Bezier Patch
          @ngon said:
          To use:
          If you always want it available on startup, move the file bez-patch/bez-patch.rb up one folder so that it is in the base plugins/ directory.) After selecting Draw > Bezier Patch...
          • ely862meE Offline
            ely862me
            thx a lot julius,it s finally working,and not at last thx Victor
              darkhelmet
              It was probably installed all along - I was looking for a tool icon within the Draw toolbar. Operates kinda weird compared to Illustrator's bezier tools.
              Thanks.
                Julius
                there is also another toll for making bezier curves called Bezier spline. you can find it here: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
                  Interesting. I wasn't aware of this plugin. I just begun work on my own Bezier Patch tool.
                  Is this being developed any more?
                    I don't think so. The original author posted it in the old @Last forums saying (something like) "he needed it for a certain task and sharing it but won't be interested in developing it nor any further support..."
                      bojanav
                      hi, guys! pls help... i did everything as u said, and it IS working, ie, it loads etc, and u can draw the patch no problem, but when i go into the edit patch mode, all the controlled points are grayed out... u can't move or do anything with them...
                      tried around 5 more things to try to make it work (copied all files direct into main plugin folder, even tried deleting 'lock axes' script in utilities.... nothing!
                      any idea why this is not working?
                      p.s. have bezier splines plug in also - hope its not interfering with it someway...
                      THANKS!! bojana
                        Could be due to a bug in SU8... I'm not sure. But the Bezier curve plugin from Google also didn't work when you tried to edit in SU8.
                          bojanav
                          well, bezier curve plugin works fine, although only when you rightclick%select 'BZ-edit classic bezier curve' (when you just select 'edit bezier curve' control points stay frozen also....
                          but which bug?? can i fix it somehow?
                          if not, is there anywhere to download the working version? (it is just strange, since comments posted under the current plugin were pretty positive ones... so seem that overall, it should work....'
                          thank you for your reply! bojana
                            It's a bug in SketchUp. Google needs to fix that. However, with Google's Bezier tool I make a patch to work around it: http://forums.sketchucation.com/viewtopic.php?f=323&t=30973
                            As for this Bezier Patch plugin - I don't know. I've not looked at the code.
                              arkarthikn
                              It says "Error Loading File bez-patch.rb
                              no such file to load -- bez-patch/BezPatch.rb
                              Kindly Help
                              • pbacotP Offline
                                I could not get it to work with console so, as suggested, I put bez-patch.rb into the plugin folder (from out of the bez-patch folder) and it worked.
                                Perhaps you put the wrong file into the plugin folder. It is the hyphenated bez-patch.rb.
                                  It looks to me as if this plugin is incorrectly packaged to just run. I made RBZ version of it that loads correctly with Install Extension in SU8M2 and later. It works in SU2014, too.
                                  bez-patch-1.1.rbz
                                  • pbacotP Offline
                                    Yes, I just went to look at this again and, loading the new version from SCF Store, it writes inside an extra folder in the Plugins folder, and won't run. Try Dave's file.
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      A SketchupExtension registrar script for the outer "Plugins" folder.
                                      ngon_bezier_patch.rb
                                      I'm not here much anymore.
