    [Plugin] Bezier Patch v1.1
    22 Posts 14 Posters 28.1k Views 14 Watching
      darkhelmet
      I downloaded the bezier.rb file from http://sketchup.google.com/download/rubyscripts.html, copied the file to \program files\sketchup\plugins\ but I never see a new icon on the Draw menu.
      What am I doing wrong?
      SU v6.4.112
        remus
        have you restarted sketchup since you installed the plugin? if not you need to.
        • ely862meE Offline
          ely862me
          for me isn t working..unzipped in plugins folder..should i do something else?
          after typeing that in ruby console appeared this
          load 'bez-patch/bez-patch.rb'
          Error: #<SyntaxError: (eval):149: compile error
          (eval):149: syntax error
          (eval):149
          Elisei (sketchupper)
          Come and See EliseiDesign
            Julius
            yes, you should copy the file "bez-patch.rb" from the "bez-patch" folder to the "plugins" folder.
            then you should see the control in Draw -> Bezier Patch
            @ngon said:
            To use:
            If you always want it available on startup, move the file bez-patch/bez-patch.rb up one folder so that it is in the base plugins/ directory.) After selecting Draw > Bezier Patch...
            • ely862meE Offline
              ely862me
              thx a lot julius,it s finally working,and not at last thx Victor
                darkhelmet
                It was probably installed all along - I was looking for a tool icon within the Draw toolbar. Operates kinda weird compared to Illustrator's bezier tools.
                Thanks.
                  Julius
                  there is also another toll for making bezier curves called Bezier spline. you can find it here: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
                    Interesting. I wasn't aware of this plugin. I just begun work on my own Bezier Patch tool.
                    Is this being developed any more?
                      I don't think so. The original author posted it in the old @Last forums saying (something like) "he needed it for a certain task and sharing it but won't be interested in developing it nor any further support..."
                        bojanav
                        hi, guys! pls help... i did everything as u said, and it IS working, ie, it loads etc, and u can draw the patch no problem, but when i go into the edit patch mode, all the controlled points are grayed out... u can't move or do anything with them...
                        tried around 5 more things to try to make it work (copied all files direct into main plugin folder, even tried deleting 'lock axes' script in utilities.... nothing!
                        any idea why this is not working?
                        p.s. have bezier splines plug in also - hope its not interfering with it someway...
                        THANKS!! bojana
                          Could be due to a bug in SU8... I'm not sure. But the Bezier curve plugin from Google also didn't work when you tried to edit in SU8.
                            bojanav
                            well, bezier curve plugin works fine, although only when you rightclick%select 'BZ-edit classic bezier curve' (when you just select 'edit bezier curve' control points stay frozen also....
                            but which bug?? can i fix it somehow?
                            if not, is there anywhere to download the working version? (it is just strange, since comments posted under the current plugin were pretty positive ones... so seem that overall, it should work....'
                            thank you for your reply! bojana
                              It's a bug in SketchUp. Google needs to fix that. However, with Google's Bezier tool I make a patch to work around it: http://forums.sketchucation.com/viewtopic.php?f=323&t=30973
                              As for this Bezier Patch plugin - I don't know. I've not looked at the code.
                                arkarthikn
                                It says "Error Loading File bez-patch.rb
                                no such file to load -- bez-patch/BezPatch.rb
                                Kindly Help
                                • pbacotP Offline
                                  I could not get it to work with console so, as suggested, I put bez-patch.rb into the plugin folder (from out of the bez-patch folder) and it worked.
                                  Perhaps you put the wrong file into the plugin folder. It is the hyphenated bez-patch.rb.
                                    It looks to me as if this plugin is incorrectly packaged to just run. I made RBZ version of it that loads correctly with Install Extension in SU8M2 and later. It works in SU2014, too.
                                    bez-patch-1.1.rbz
                                    • pbacotP Offline
                                      Yes, I just went to look at this again and, loading the new version from SCF Store, it writes inside an extra folder in the Plugins folder, and won't run. Try Dave's file.
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        A SketchupExtension registrar script for the outer "Plugins" folder.
                                        ngon_bezier_patch.rb
                                        I'm not here much anymore.
