    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • mitcorbM
      mitcorb
      If I may suggest: (probably not the problem)
      Try scaling the geometry up x10, x100, or some other factor temporarily for the operation, then scaling down by the inverse factor. As you may already know, if the edge distances are sufficiently small, Sketchup/OpenGL cannot close faces, especially when it has to generate new logical edges on a distorted boundary.
      Like I said, this may not be the problem, just something to rule out.
      • hellnbakH
        hellnbak
        I've use Box Tapering before and it's performed wonderfully (as do all of your amazing plugins), but I'm having a problem now. I'm trying to taper an object, just move the face in a bit. Well, when I move the cursor in the direction I want, nothing happens, and then it snaps to .95. After that I can keep moving it in just as smoothly as you please, but I cannot get it to go anywhere between .95 and 1.00, if I try it just snaps back to 1.00. I've tried typing in the taper I want (somewhere around .98, although I can't be sure yet because I havent' been able to test it), but when I hit enter nothing happens. If I hit enter again it snaps back to 1.00. I've tried many, many times, no luck. Any help would be appreciated.
        • mitcorbM
          mitcorb
          In my recent experience at least with the Fredoscale tool, you can actually type in the specific desired factor eg after you come to rest on 0.95, let up on the mouse button and type in the specific size factor for example 0.98 and hit Enter. Be sure you type in the zero before the .98. Apparently the tool requires this literal input.
          There may be some discussion in Fredo's pdf manual on this. I did not check.
          Try the above and yell back if it works, so others can see.
          • hellnbakH
            hellnbak
            That did it!!!!! 😍 I've been going nuts for almost 2 days trying to get it to work, and all I had to do was type in 0.98 instead of just .98 Such a small thing, such a big difference! I really appreciate you taking the time to reply, I had just about given up on hearing from anybody about this. Again, thanks!
            • mitcorbM
              mitcorb
              Glad to be of service.
              So many have helped me, or gifted me with amazing tools in this forum, I feel it is necessary for me to pay it forward.
              • hellnbakH
                hellnbak
                Your tip came just in the nick of time - I had a gun in one hand, a rusty razor blade in another hand and a samuri sword in the third (yeah, I spent some time around Chernobyl 😉 ). I owe you a Big Mac. Or a Porsche. Whichever you prefer (although the Big Mac does require less maintenance, gets better mileage and costs a lot less to insure) 😆 .
                • mitcorbM
                  mitcorb
                  Yeah, but the investment all turns to poo.
                  Edit: And if you gave me a Porsche, I'd just sell it. Either my kids would destroy it, or the maintenance, insurance and worry about dings would destroy me. 💚
                  • hellnbakH
                    hellnbak
                    Well, I could give you a Porsche that's already had the crap beat out of it. Or, I could just toast you at your next wedding 😆
                    • fredo6F
                      Mitcorb,
                      Thanks very much.
                      I fixed the issue and FredoScale (like other plugins) will now accept notation ".98" as equivalent to "0.98". This will also work in formulas (like ".98 + .97")
                      This will go in a next version of LibFredo6
                      Fred
                      • mitcorbM
                        mitcorb
                        @Fredo: As I said to hellnbak: "Glad to be of service" (in gratitude for your noble gifts to this community).
                          Jim57
                          I'm turn in in a project to a CAD shop for fine tuning of model and prototype machining. In the course of revising some turnings, pieces were pulled way out of round— it's so easy to do with the Scale tool, in fact, so hard to keep circular. Not only can you type the percentages into the VCB, but it's incredibly easy to select Option (Command for PC) to scale around center, then hit Control to get the contextual menu that allows you to type in final dimensions by axis, and to understand which axis is which (an arcane SU skill I am nowhere near approaching— first red, last red, it's all so contextual!)
                          Fredo, thanks so much and so much again! I could have passed it off as is, but now I don't have to look like a dweeb to the CAD designer.
                          Jim
                            drfabinex
                            I'm not sure if this has been discussed before, I apologize if it has.
                            I use fredoscale mostly for it's stretching capability. I notice that after stretching an object (usually multiple times) a bit of unwanted "shearing" happens. This happens to me on ANY project, sketchup 7 and 8, windows and mac. As I say, it usually shows after multiple stretching operations (5+) so I'm not sure if this is a small amount of error that compounds, or something else.
                            Has anyone else come across it? Anything to be done? I'm used to working around this problem already.
                            Thanks for your help, I love this plugin so much!
                            This is a group of other grouped objects that were stretched multiple times and now have some unwanted shearing.
                              Can you place a guide line to follow when stretching the component? I use the Move tool instead for stretching and don't run into that problem.
                              • hellnbakH
                                hellnbak
                                Have used this fantastic plugin many times, but tonight I'm having a bit of a problem. I'm trying to use box tapering on a component, but it won't give me the option of tapering the entire object, only either side of it. I want to taper the component in the red axis, as shown in photo #2, but I can't seem to be able to click anywhere that let's me do that, only either side of the component. It did let me taper it in the green axis, but now it seems to be getting grumpy. I can't get rid of the feeling that I'm doing something very basically wrong here, I am very tired and I'm running on only two brain cells 😢 , if that's the case I apologize for wasting your time. Thanks in advance.
                                • fredo6F
                                  If you wish to taper symetrically, you need to press CTRL to perform the transformation about the center.
                                  • hellnbakH
                                    hellnbak
                                    If you wish to taper symetrically, you need to press CTRL to perform the transformation about the center.Fredo
                                    Possibly I didn't explain myself very well. I want to lean the entire object to the right. Like in the second photo, but with the entire model leaning like that.
                                    • mitcorbM
                                      mitcorb
                                      I think you want to FredoBend the component, then, if needed, FredoTaper. Maybe not.
                                      • hellnbakH
                                        hellnbak
                                        No, I don't want to bend it, I just want to lean it to the right. I know it can be done using Box Tapering, I actually did it before on an earlier version of this object, I just can't seem to get it to do it again.
                                          Is it possible you want to use Plane Shearing instead? That worked for me.
                                          • hellnbakH
                                            hellnbak
                                            You are the master! 😍 Why ain't I smart like you is? Thanks.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 58
                                            • 59
                                            • 27 / 59
