    Drop tool (forgotten)
    27 Posts 8 Posters 3.2k Views 8 Watching
      Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
        d12dozr
        @tfdesign said:
        So, is 'drop15' the same one?
        edit; v1.5
        The one on Smustard is version 1.52...so tiny bit newer
        http://goo.gl/f7ooYh
        • soloS Offline
          One issue...
          It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
            tfdesign
            even if they're all one component?
            • soloS Offline
              If they are all one component then they do not follow the terrain, they need to be seperate components for the drop to work.
                d12dozr
                Maybe someone could PM TBD to request a fix?
                • utilerU Offline
                  utiler
                  @d12dozr said:
                  edit; v1.5
                  d12dozer, the one on smustard is version 1.500 it seems unless I'm looking in the wrong area...
                  can you post the like?
                  Just Curious...
                  • EarthMoverE Offline
                    EarthMover
                    Pete,
                    Check Thom's Raytracer tools as well. Should do what you need with a one step undo. http://forums.sketchucation.com/viewtopic.php?t=30509
                    Content Creator at Skapeup
                      d12dozr
                      I thought I got this from Smustard πŸ˜•
                      drop.rb
                      • Chris FullmerC Offline
                        It is a very old script that could use to be updated. Makig it undo everything in one ctrl-z would be really easy to do.
                        • 2 / 2
