Problem with follow me
8 Posts 4 Posters 286 Views 4 Watching
    deaneau
    Hi at all,
    ill try to use the follow me tool with an elypsoid and a spline.
    the orientation of the elypsoid at the start is ok, however at the end this will be rotated 😕
    what can i do to solve this problem?
    stair.skp
    • N Offline
      numbthumb
      Maybe this? http://forums.sketchucation.com/viewtopic.php?t=16465
      Comfortably numb...
        this isn't the typical twisting problem inherent with SU follow-me..
        i'd say this is more about unpractical design.. if it were a circle you were trying to extrude, it would work out ok. the ellipse shape though needs to be more thought out as to what happens at the joints..
        if this were actually being built, it might be best to do something like this (which can be done with normal follow-me)
        stairs__.skp
          deaneau
          hi jeff, i have now solved this in my model with your help. what the minimum for the bend "extension"?
          thank you for your help.
          dean
          [attachment=1:vz3dri1n]<!-- ia1 -->stairs__.skp<!-- ia1 -->[/attachment:vz3dri1n]
          [attachment=0:vz3dri1n]<!-- ia0 -->screen 3.jpg<!-- ia0 -->[/attachment:vz3dri1n]
            dean
            if i understand your question correctly (as in what's the min. length for this to extrude properly... and not - what's the min length as required by some building code)
            ...then the min.length would need to be 1/2 the width of the ellipse.
            but be aware, in the drawing you posted, the ellipse was a little wacky and not symmetrical (the segment defining the right side is not vertical).. either copy/paste the ellipse in my drawing, redo yours, or just make sure you're measuring to total actual width)
              deaneau
              good morning.
              wow, you have good eyes.
              yes you understand right. i have not find the right words.
              dean
              dean
                Also remember that Sketchup/OpenGL doesn't like to make tiny faces <0.1mm or so, so FollowMe and similar tools can fail at these sizes. If you Scale up by 10 do the 'small faces' and Scale down by 0.1 it should make and remain OK afterwards - it's the 'making' not the 'existing' that's the bottom size limit.
                  deaneau
                  thank you TIG for your info.
                  dean
