    Problem with follow me
    8 Posts 4 Posters 356 Views 4 Watching
    • deaneauD Offline
      deaneau
      Hi at all,
      ill try to use the follow me tool with an elypsoid and a spline.
      the orientation of the elypsoid at the start is ok, however at the end this will be rotated ๐Ÿ˜•
      what can i do to solve this problem?
      stair.skp
      • numbthumbN Offline
        numbthumb
        Maybe this? http://forums.sketchucation.com/viewtopic.php?t=16465
        Comfortably numb...
        • jeff hammondJ Offline
          this isn't the typical twisting problem inherent with SU follow-me..
          i'd say this is more about unpractical design.. if it were a circle you were trying to extrude, it would work out ok. the ellipse shape though needs to be more thought out as to what happens at the joints..
          if this were actually being built, it might be best to do something like this (which can be done with normal follow-me)
          stairs__.skp
          • deaneauD Offline
            deaneau
            hi jeff, i have now solved this in my model with your help. what the minimum for the bend "extension"?
            thank you for your help.
            dean
            [attachment=1:vz3dri1n]<!-- ia1 -->stairs__.skp<!-- ia1 -->[/attachment:vz3dri1n]
            [attachment=0:vz3dri1n]<!-- ia0 -->screen 3.jpg<!-- ia0 -->[/attachment:vz3dri1n]
              dean
              if i understand your question correctly (as in what's the min. length for this to extrude properly... and not - what's the min length as required by some building code)
              ...then the min.length would need to be 1/2 the width of the ellipse.
              but be aware, in the drawing you posted, the ellipse was a little wacky and not symmetrical (the segment defining the right side is not vertical).. either copy/paste the ellipse in my drawing, redo yours, or just make sure you're measuring to total actual width)
              • deaneauD Offline
                deaneau
                good morning.
                wow, you have good eyes.
                yes you understand right. i have not find the right words.
                dean
                dean
                  Also remember that Sketchup/OpenGL doesn't like to make tiny faces <0.1mm or so, so FollowMe and similar tools can fail at these sizes. If you Scale up by 10 do the 'small faces' and Scale down by 0.1 it should make and remain OK afterwards - it's the 'making' not the 'existing' that's the bottom size limit.
                  • deaneauD Offline
                    deaneau
                    thank you TIG for your info.
                    dean
