    With any plugin to make this model
    19 Posts 7 Posters 2.4k Views 7 Watching
      robert111
      with any plugin to make this model,
      i try the plugin latticeMaker
      but i dont have this modeling
        Sorry for the off-topic (and least helpful) post but I could not resist when I had this on my screen.
        More seriously however; what went wrong with the lattice maker? Have you got something?
          See these tutorials : how to make a strutural curvy roof πŸ˜‰ (browse the 2pages ! )
            Here's a newer example quickly made using EEbyRailsToLattice for the glazed area and EEbyFace for the tubular side beamsLatticeRoofExample.PNG
              robert111
              thanks , but i dont know how to make two forms circular and rectangular beams with EEbyFace
                Since I don't know...
                It appears there's a valley in the corner. How do you draw that? Do you split the form into smaller sections, maybe quarters and create the lattices on each before assembling them?
                  robert111
                  pilou can you make tuto for this exemple plz
                  tuto with pictures thanks pilou
                    See attached for structure and profiles/rails to run TIG's tools.
                    Structure.skp
                      Is that more clear?
                      I can't be more explicite πŸ˜„
                      Of course you can take four different curves (Profil, rail,rail, profil)
                      Click image if scrollbar
                      If you want only circular tubes
                      for the perimeter use
                      Extrude Edges by Face always by Tig
                      Of course in your case you must make
                      the 2 passes with the rectangle
                      Then perimeter with circle πŸ˜‰
                        look this one πŸ˜‰ my example ant the tut image by Tig πŸ˜‰
                        Extrude Edges By Rail, by Face
                        You must have "sections" of your propagaded module πŸ˜‰
                        That are very powerful plugs! 😎 (here only with a circle)
                        (here click one profil, rail, rail again, profil again πŸ˜‰
                        Click image if scroolbar)
                        So a little circle and a little rectangle in your case in 2 passes!
                        http://forums.sketchucation.com/download/file.php?id=42810&mode=view
                          Actually I used 'ExtrudeEdgesByRailsToLattice' and four curves - profile/rail1/rail2/melding_profile - to make the glazed panels with rectangular glazing bars and glass... and then used the same four curves selected with a selected flat circular face in 'ExtrudeEdgesByFace' to make the tubular edge beams...
                          As Rich seems to have done [thanks by the way - much more relevant example than mine...] πŸ˜„
                            robert111
                            i make model skp , i make form with EEbyRailsToLattice , but i havnt rond beamsolone et rectangular beams with EEbyface
                            fffffff01.skp
                              You have a small form, rescale it so that it's a more realistic size.
                              A facet size is ~250mm but 2500mm would be more realistic.
                              The EEbyRailsToLattice will make a framed set of glazed panels.
                              Make the segments a realistic size ~1m to ~3m and then you specify the glazing bar dimension in the dialog after picking 3D [you don't need to 'draw' a rectangle ??].
                              You can also set the pane parameters and the frame/pane materials.
                              After that group is made, move the grouped glazing to one side by a known amount, and then use EEbyFace - select all of the 4 curves and a flat face - a circle of a realistic radius - say 150mm - and a tubular circular cross-section beam will be added around the perimeter. Move the glazing group back into place...
                                Here are examples using EEbyRailsToLattice to make regtangular-section framed panes and then EEbyFace to make the perimeter...
                                AND the alternative of EEbyRails to make panes as a mesh only, then EEbyRailsToLattice [Profiles+Rails, Lines Rails+Profiles+Diagonals] to make an edges only set and then EEbyFace on those edges and a small circular face to make the circular frames too. Some intersecting later you have this...fffffff01.PNGfffffff01.zip
                                  robert111
                                  thanks mr TIG
                                    lapx
                                    Tig,
                                    Is there a way to land a predefined component at each connector location as in the original photo?
                                    lapx
                                      @lapx said:
                                      Tig,
                                      lapx
                                      Like a 'connector' shaped like a 'cylinder' ?
                                      No! πŸ˜‰
                                      Not easily... but Chris Fullmer has a tool to add components onto a seelcted object... so it's no a million miles to have a 'connector' component with a correctly place origin that is dropped onto every node of a mesh made with EEbyRails so if you did the mesh that way you have one already [you might need to erase edge instances] ?
                                      If you used EEbyRailsToLattice, although you simply make a EEbyRails mesh separately add the 'connectors' and erase that mesh-group on completion... πŸ€“
                                        robert111
                                        TIG , this picture is the render with vray max but the modeling is with sketchup
                                        very nice renderong is from free agent ,
                                        do you use mr TIG your rendering vith vray max or vray sketchup ?
                                          lapx
                                          Tig,
                                          I was thinking along the lines of Chris's script which locates a component on every face. I take it would be very difficult to align the connector or component "radial" to the joint.
                                          Thanks,
