    With any plugin to make this model
    19 Posts 7 Posters 2.4k Views 7 Watching
      robert111
      pilou can you make tuto for this exemple plz
      tuto with pictures thanks pilou
        See attached for structure and profiles/rails to run TIG's tools.
        Structure.skp
          Is that more clear?
          I can't be more explicite πŸ˜„
          Of course you can take four different curves (Profil, rail,rail, profil)
          Click image if scrollbar
          If you want only circular tubes
          for the perimeter use
          Extrude Edges by Face always by Tig
          Of course in your case you must make
          the 2 passes with the rectangle
          Then perimeter with circle πŸ˜‰
            look this one πŸ˜‰ my example ant the tut image by Tig πŸ˜‰
            Extrude Edges By Rail, by Face
            You must have "sections" of your propagaded module πŸ˜‰
            That are very powerful plugs! 😎 (here only with a circle)
            (here click one profil, rail, rail again, profil again πŸ˜‰
            Click image if scroolbar)
            So a little circle and a little rectangle in your case in 2 passes!
            http://forums.sketchucation.com/download/file.php?id=42810&mode=view
              Actually I used 'ExtrudeEdgesByRailsToLattice' and four curves - profile/rail1/rail2/melding_profile - to make the glazed panels with rectangular glazing bars and glass... and then used the same four curves selected with a selected flat circular face in 'ExtrudeEdgesByFace' to make the tubular edge beams...
              As Rich seems to have done [thanks by the way - much more relevant example than mine...] πŸ˜„
                robert111
                i make model skp , i make form with EEbyRailsToLattice , but i havnt rond beamsolone et rectangular beams with EEbyface
                fffffff01.skp
                  You have a small form, rescale it so that it's a more realistic size.
                  A facet size is ~250mm but 2500mm would be more realistic.
                  The EEbyRailsToLattice will make a framed set of glazed panels.
                  Make the segments a realistic size ~1m to ~3m and then you specify the glazing bar dimension in the dialog after picking 3D [you don't need to 'draw' a rectangle ??].
                  You can also set the pane parameters and the frame/pane materials.
                  After that group is made, move the grouped glazing to one side by a known amount, and then use EEbyFace - select all of the 4 curves and a flat face - a circle of a realistic radius - say 150mm - and a tubular circular cross-section beam will be added around the perimeter. Move the glazing group back into place...
                    Here are examples using EEbyRailsToLattice to make regtangular-section framed panes and then EEbyFace to make the perimeter...
                    AND the alternative of EEbyRails to make panes as a mesh only, then EEbyRailsToLattice [Profiles+Rails, Lines Rails+Profiles+Diagonals] to make an edges only set and then EEbyFace on those edges and a small circular face to make the circular frames too. Some intersecting later you have this...fffffff01.PNGfffffff01.zip
                      robert111
                      thanks mr TIG
                        lapx
                        Tig,
                        Is there a way to land a predefined component at each connector location as in the original photo?
                        lapx
                          @lapx said:
                          Tig,
                          lapx
                          Like a 'connector' shaped like a 'cylinder' ?
                          No! πŸ˜‰
                          Not easily... but Chris Fullmer has a tool to add components onto a seelcted object... so it's no a million miles to have a 'connector' component with a correctly place origin that is dropped onto every node of a mesh made with EEbyRails so if you did the mesh that way you have one already [you might need to erase edge instances] ?
                          If you used EEbyRailsToLattice, although you simply make a EEbyRails mesh separately add the 'connectors' and erase that mesh-group on completion... πŸ€“
                            robert111
                            TIG , this picture is the render with vray max but the modeling is with sketchup
                            very nice renderong is from free agent ,
                            do you use mr TIG your rendering vith vray max or vray sketchup ?
                              lapx
                              Tig,
                              I was thinking along the lines of Chris's script which locates a component on every face. I take it would be very difficult to align the connector or component "radial" to the joint.
                              Thanks,
