    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 63.7k Views 26 Watching
      Khai
      @pugz1983 said:
      Hi Didier,
      I realy like your plugins, but please excuse me for asking but what is the reason behind SU2POV? I mean, aren't there enough render app to render a SU scene/model. Or am I missing something. Is there a special reason for developing this app? Can SU2POW do something the others can't?
      Greetz Twan
      POVRay is free, widely respected and hugely powerful.
      and because you can never have enough render engines.
      • Didier BurD Offline
        Didier Bur
        su2pov is old, first version was published in 2005 and was one of the first exporter to a render app. There was not lots of them at that time (I mean free, and ascii format). Tomasz developed su2kt a year later, based on su2pov, and since then I've written su2sf among others. Su2pov was like a test program for me and made me learn lots of things about Ruby and SketchUp.
        Yes there are plenty of render apps around, I'm not blind you know 😉 but for high quality renderings, you need a payware (Maxwell, Vray, Podium, etc). Su2pov is just for fun, although you can achieve decent results with it, IMHO.
        Best regards,
        DB
        • V Offline
          vidy
          dear didier,
          i have one request for the new plugin SU2POV 3.5, is it possible with the material preset, we still have the "old like" material editor? i mean, i feel much easier with slider bar to all parameter.. 😛
          or it is still there, but i don't how to access it 😳
          thanks
          regards,
          still so much to learn..
            solodown
            @solodown said:
            Loading File su2pov35Toolbar.rb
            private method `split' called for nil:NilClass
            Y a-t-il une solution à mon problème ?
              Didier Bur
              @vidy: sorry, but the old material editor has been deleted... (it was windows-only).
              @solodown: il me faudrait le message d'erreur en entier (avec le numéro de ligne où ça plante). merci.
              DB
                solodown
                C'est la seule information qu'il me donne à l'ouverture de sketchup dans la fenêtre load error :
                Error Loading File su2pov35Toolbar.rb
                private method `split' called for nil;NilClass
                • V Offline
                  vidy
                  Hi didier,
                  with this new plug-in 3.5, is there a way i can attach bump image on the texture?
                  thanks,
                  vd
                    Didier Bur
                    If you mean attach another image (than the one of the texture) for the bump effect, the answer is no, but you can do this editing the pov-ray material manually.
                    regards
                    DB
                      Didier Bur
                      @solodown:
                      Je suppose que tu es sur Mac ?
                      essaies avec le fichier attaché ci-dessous (à dezipper dans le dossier Plugins):
                      Su2pov35.zip
                      DB
                      • V Offline
                        vidy
                        regards
                        actually i want to add the same image, but with normal map or black and white version..
                        any tips about edit it manually as you describe above? thanks
                        regards,
                          Didier Bur
                          Look at here:http://www.povray.org/documentation/view/3.6.0/341/
                          or here: http://www.f-lohmueller.de/pov_tut/tex/tex_840e.htm
                          or here: http://www.absoluteastronomy.com/topics/Bump_mapping
                          DB
                          • V Offline
                            vidy
                            thanks for your response didier, but that technique kind of make me nervous, since im not good at programming.. 😳
                            what i want to confirm from you, is there any possibility to add an external image texture in your material "surface effect" dialog box? (something that we can browse it independently) 😄
                            thanks,
                              Didier Bur
                              Not in this version, maybe in a next release...
                              DB
                                solodown
                                @didier bur said:
                                @solodown:
                                Merci ^^
                                Mais ça n'a pas l'air de fonctionner, je mets Render !, save puis rien ne se passe
                                • V Offline
                                  vidy
                                  Woow.. it will be awesome feature mr. bur, thanks.. 😍
                                    lichinho
                                    @solodown said:
                                    @didier bur said:
                                    @solodown:
                                    Merci ^^
                                    Merci pour cette version pour mac.
                                    Elle tourne en effet sur mac. Le fichier pov est creé. POV n'est pas lancé automatiquement, mais pour moi tant mieux, car je peux lancer MegaPOV manuellement.
                                    Pour moi, c'est suffisant. Cependant, le plugin essaye de créer des fichiers dans un sous-directoire mais en utilisant le séparateur "" comme en windows, et pas "/". Le résult est que "" vient à faire part du nom du fichier.
                                    Si, par exemple, le nom du sketch est "sketch",
                                    en lieu de créer un fichier "sketch.pov" dans une directoire "sketch", un fichier avec le nom "sketch\sketch.pov" est créé et le directoire "sketch" reste vide. C'est pas grave, mais quelque chose à rectifier peut-être dans une nouvelle version.
                                    Merci beaucoup!
                                    • X Offline
                                      xWarcox
                                      gracias ... en español por que mi ingles no es tan bueno ...
                                      los mejores renders los he optenido con Pov-Ray .. gracias al Su2Pov
                                        juniormiranda
                                        @didier bur said:
                                        @solodown:
                                        Please, the file doesn't work for me. I had the same problem:
                                        skp 8.0.3161
                                          cm architects
                                          Didier,
                                          I installed Su2POV3.5: no problem. However when I start rendering I get the message: "POV file created in C:\users..\desktop\untitled but unable to launche POV-Ray......"
                                          What's going wrong?
                                          Cees
                                            Didier Bur
                                            This message appears in these cases:
                                            • SketchUp model has never been saved,
                                            • Pov-Ray is not installed on your system,
                                            • .pov extension isn't associated with the Pov-Ray program.
                                            Please double-click on the file that has been created and see what happens, and let me know.
                                            Regards,
                                            DB
                                            • 2 / 4
