    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 63.4k Views 26 Watching
    • Didier BurD Offline
      Didier Bur
      I've installed it on SU6 and also got the bug.
      The "UI.savepanel" method doesn't work the same way in SU7 API than in SU6 😢
      So version 3.5 is for SU7 or higher...
      Regards,
      DB
      • V Offline
        vidy
        thanks for your confirmation didier. 😉
        best regards,
        still so much to learn..
          solodown
          Loading File su2pov35Toolbar.rb
          private method `split' called for nil:NilClass
          • pugz1983P Offline
            pugz1983
            Hi Didier,
            I realy like your plugins, but please excuse me for asking but what is the reason behind SU2POV? I mean, aren't there enough render app to render a SU scene/model. Or am I missing something. Is there a special reason for developing this app? Can SU2POW do something the others can't?
            Greetz Twan
              Khai
              @pugz1983 said:
              Hi Didier,
              Greetz Twan
              POVRay is free, widely respected and hugely powerful.
              and because you can never have enough render engines.
                Didier Bur
                su2pov is old, first version was published in 2005 and was one of the first exporter to a render app. There was not lots of them at that time (I mean free, and ascii format). Tomasz developed su2kt a year later, based on su2pov, and since then I've written su2sf among others. Su2pov was like a test program for me and made me learn lots of things about Ruby and SketchUp.
                Yes there are plenty of render apps around, I'm not blind you know 😉 but for high quality renderings, you need a payware (Maxwell, Vray, Podium, etc). Su2pov is just for fun, although you can achieve decent results with it, IMHO.
                Best regards,
                DB
                • V Offline
                  vidy
                  dear didier,
                  i have one request for the new plugin SU2POV 3.5, is it possible with the material preset, we still have the "old like" material editor? i mean, i feel much easier with slider bar to all parameter.. 😛
                  or it is still there, but i don't how to access it 😳
                  thanks
                  regards,
                    solodown
                    Y a-t-il une solution à mon problème ?
                      Didier Bur
                      @vidy: sorry, but the old material editor has been deleted... (it was windows-only).
                      @solodown: il me faudrait le message d'erreur en entier (avec le numéro de ligne où ça plante). merci.
                      DB
                        solodown
                        C'est la seule information qu'il me donne à l'ouverture de sketchup dans la fenêtre load error :
                        Error Loading File su2pov35Toolbar.rb
                        private method `split' called for nil;NilClass
                        • V Offline
                          vidy
                          Hi didier,
                          with this new plug-in 3.5, is there a way i can attach bump image on the texture?
                          thanks,
                          vd
                            Didier Bur
                            If you mean attach another image (than the one of the texture) for the bump effect, the answer is no, but you can do this editing the pov-ray material manually.
                            regards
                            DB
                              Didier Bur
                              @solodown:
                              Je suppose que tu es sur Mac ?
                              essaies avec le fichier attaché ci-dessous (à dezipper dans le dossier Plugins):
                              Su2pov35.zip
                              DB
                              • V Offline
                                vidy
                                regards
                                actually i want to add the same image, but with normal map or black and white version..
                                any tips about edit it manually as you describe above? thanks
                                regards,
                                  Didier Bur
                                  Look at here:http://www.povray.org/documentation/view/3.6.0/341/
                                  or here: http://www.f-lohmueller.de/pov_tut/tex/tex_840e.htm
                                  or here: http://www.absoluteastronomy.com/topics/Bump_mapping
                                  DB
                                  • V Offline
                                    vidy
                                    thanks for your response didier, but that technique kind of make me nervous, since im not good at programming.. 😳
                                    what i want to confirm from you, is there any possibility to add an external image texture in your material "surface effect" dialog box? (something that we can browse it independently) 😄
                                    thanks,
                                      Didier Bur
                                      Not in this version, maybe in a next release...
                                      DB
                                        solodown
                                        @didier bur said:
                                        @solodown:
                                        Merci ^^
                                        Mais ça n'a pas l'air de fonctionner, je mets Render !, save puis rien ne se passe
                                        • V Offline
                                          vidy
                                          Woow.. it will be awesome feature mr. bur, thanks.. 😍
                                            lichinho
                                            @solodown said:
                                            @didier bur said:
                                            @solodown:
                                            Merci ^^
                                            Merci pour cette version pour mac.
                                            Elle tourne en effet sur mac. Le fichier pov est creé. POV n'est pas lancé automatiquement, mais pour moi tant mieux, car je peux lancer MegaPOV manuellement.
                                            Pour moi, c'est suffisant. Cependant, le plugin essaye de créer des fichiers dans un sous-directoire mais en utilisant le séparateur "" comme en windows, et pas "/". Le résult est que "" vient à faire part du nom du fichier.
                                            Si, par exemple, le nom du sketch est "sketch",
                                            en lieu de créer un fichier "sketch.pov" dans une directoire "sketch", un fichier avec le nom "sketch\sketch.pov" est créé et le directoire "sketch" reste vide. C'est pas grave, mais quelque chose à rectifier peut-être dans une nouvelle version.
                                            Merci beaucoup!
                                            • 1 / 4
