    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 63.4k Views 26 Watching
    • V Offline
      vidy
      ow.. thanks didier.. will try and give a report on it. thank you for your hard work 🎉
      oh please dont said sorry, it is us that always give you trouble for this and that haha.. 😒
      regards,
      still so much to learn..
      • V Offline
        vidy
        ok i've been try it, no problem when its loading now, but when i hit render, i got this message on ruby console:
        Error: #<LocalJumpError: unexpected break>
        (eval):3795:in ocr_query_exportas' (eval):3860:in ocr_pov'
        C:/Program Files/Google/Google SketchUp 6/Plugins/su2pov35Toolbar.rb:50
        C:/Program Files/Google/Google SketchUp 6/Plugins/su2pov35Toolbar.rb:50:in `call'
        FYI: im using SU 6 here, is it have to be installed on SU 7 and above? thanks didier
        regards,
        • Didier BurD Offline
          Didier Bur
          Hi vidy,
          The "unexpected break" occurs theorically when you hit the cancel button of the "Save as" dialog that should pop up when hitting "Render!". Did you see this dialog ? It asks for a pov file name to export. Thus you can save as many version of you model as you want.
          Thanks for reporting bugs...
          DB
          • V Offline
            vidy
            dear didier,
            actually i didn't see any dialog box popped up, its just seems like there is nothing happen, until i check on ruby console dialog, and I've got those messages, that's why i'm asked about the version problem, since it running well at SU 7.
            regards,
              Didier Bur
              I've installed it on SU6 and also got the bug.
              The "UI.savepanel" method doesn't work the same way in SU7 API than in SU6 😢
              So version 3.5 is for SU7 or higher...
              Regards,
              DB
              • V Offline
                vidy
                thanks for your confirmation didier. 😉
                best regards,
                  solodown
                  Loading File su2pov35Toolbar.rb
                  private method `split' called for nil:NilClass
                  • pugz1983P Offline
                    pugz1983
                    Hi Didier,
                    I realy like your plugins, but please excuse me for asking but what is the reason behind SU2POV? I mean, aren't there enough render app to render a SU scene/model. Or am I missing something. Is there a special reason for developing this app? Can SU2POW do something the others can't?
                    Greetz Twan
                      Khai
                      @pugz1983 said:
                      Hi Didier,
                      Greetz Twan
                      POVRay is free, widely respected and hugely powerful.
                      and because you can never have enough render engines.
                        Didier Bur
                        su2pov is old, first version was published in 2005 and was one of the first exporter to a render app. There was not lots of them at that time (I mean free, and ascii format). Tomasz developed su2kt a year later, based on su2pov, and since then I've written su2sf among others. Su2pov was like a test program for me and made me learn lots of things about Ruby and SketchUp.
                        Yes there are plenty of render apps around, I'm not blind you know 😉 but for high quality renderings, you need a payware (Maxwell, Vray, Podium, etc). Su2pov is just for fun, although you can achieve decent results with it, IMHO.
                        Best regards,
                        DB
                        • V Offline
                          vidy
                          dear didier,
                          i have one request for the new plugin SU2POV 3.5, is it possible with the material preset, we still have the "old like" material editor? i mean, i feel much easier with slider bar to all parameter.. 😛
                          or it is still there, but i don't how to access it 😳
                          thanks
                          regards,
                            solodown
                            Y a-t-il une solution à mon problème ?
                              Didier Bur
                              @vidy: sorry, but the old material editor has been deleted... (it was windows-only).
                              @solodown: il me faudrait le message d'erreur en entier (avec le numéro de ligne où ça plante). merci.
                              DB
                                solodown
                                C'est la seule information qu'il me donne à l'ouverture de sketchup dans la fenêtre load error :
                                Error Loading File su2pov35Toolbar.rb
                                private method `split' called for nil;NilClass
                                • V Offline
                                  vidy
                                  Hi didier,
                                  with this new plug-in 3.5, is there a way i can attach bump image on the texture?
                                  thanks,
                                  vd
                                    Didier Bur
                                    If you mean attach another image (than the one of the texture) for the bump effect, the answer is no, but you can do this editing the pov-ray material manually.
                                    regards
                                    DB
                                      Didier Bur
                                      @solodown:
                                      Je suppose que tu es sur Mac ?
                                      essaies avec le fichier attaché ci-dessous (à dezipper dans le dossier Plugins):
                                      Su2pov35.zip
                                      DB
                                      • V Offline
                                        vidy
                                        regards
                                        actually i want to add the same image, but with normal map or black and white version..
                                        any tips about edit it manually as you describe above? thanks
                                        regards,
                                          Didier Bur
                                          Look at here:http://www.povray.org/documentation/view/3.6.0/341/
                                          or here: http://www.f-lohmueller.de/pov_tut/tex/tex_840e.htm
                                          or here: http://www.absoluteastronomy.com/topics/Bump_mapping
                                          DB
                                          • V Offline
                                            vidy
                                            thanks for your response didier, but that technique kind of make me nervous, since im not good at programming.. 😳
                                            what i want to confirm from you, is there any possibility to add an external image texture in your material "surface effect" dialog box? (something that we can browse it independently) 😄
                                            thanks,
                                            • 1 / 4
