    [Plugin] SU2POV 3.5
    77 Posts 26 Posters 65.7k Views 26 Watching
    • Didier BurD
      Didier Bur
      @vidy: sorry, but the old material editor has been deleted... (it was windows-only).
      @solodown: il me faudrait le message d'erreur en entier (avec le numéro de ligne où ça plante). merci.
      DB
        solodown
        C'est la seule information qu'il me donne à l'ouverture de sketchup dans la fenêtre load error :
        Error Loading File su2pov35Toolbar.rb
        private method `split' called for nil;NilClass
        • V
          vidy
          Hi didier,
          with this new plug-in 3.5, is there a way i can attach bump image on the texture?
          thanks,
          vd
          still so much to learn..
          • Didier BurD
            Didier Bur
            If you mean attach another image (than the one of the texture) for the bump effect, the answer is no, but you can do this editing the pov-ray material manually.
            regards
            DB
            • Didier BurD
              Didier Bur
              @solodown:
              Je suppose que tu es sur Mac ?
              essaies avec le fichier attaché ci-dessous (à dezipper dans le dossier Plugins):
              Su2pov35.zip
              DB
              • V
                vidy
                regards
                actually i want to add the same image, but with normal map or black and white version..
                any tips about edit it manually as you describe above? thanks
                regards,
                • Didier BurD
                  Didier Bur
                  Look at here:http://www.povray.org/documentation/view/3.6.0/341/
                  or here: http://www.f-lohmueller.de/pov_tut/tex/tex_840e.htm
                  or here: http://www.absoluteastronomy.com/topics/Bump_mapping
                  DB
                  • V
                    vidy
                    thanks for your response didier, but that technique kind of make me nervous, since im not good at programming.. 😳
                    what i want to confirm from you, is there any possibility to add an external image texture in your material "surface effect" dialog box? (something that we can browse it independently) 😄
                    thanks,
                    • Didier BurD
                      Didier Bur
                      Not in this version, maybe in a next release...
                      DB
                        solodown
                        @didier bur said:
                        @solodown:
                        Merci ^^
                        Mais ça n'a pas l'air de fonctionner, je mets Render !, save puis rien ne se passe
                        • V
                          vidy
                          Woow.. it will be awesome feature mr. bur, thanks.. 😍
                          • L
                            lichinho
                            @solodown said:
                            @didier bur said:
                            @solodown:
                            Merci ^^
                            Merci pour cette version pour mac.
                            Elle tourne en effet sur mac. Le fichier pov est creé. POV n'est pas lancé automatiquement, mais pour moi tant mieux, car je peux lancer MegaPOV manuellement.
                            Pour moi, c'est suffisant. Cependant, le plugin essaye de créer des fichiers dans un sous-directoire mais en utilisant le séparateur "" comme en windows, et pas "/". Le résult est que "" vient à faire part du nom du fichier.
                            Si, par exemple, le nom du sketch est "sketch",
                            en lieu de créer un fichier "sketch.pov" dans une directoire "sketch", un fichier avec le nom "sketch\sketch.pov" est créé et le directoire "sketch" reste vide. C'est pas grave, mais quelque chose à rectifier peut-être dans une nouvelle version.
                            Merci beaucoup!
                            • X
                              xWarcox
                              gracias ... en español por que mi ingles no es tan bueno ...
                              los mejores renders los he optenido con Pov-Ray .. gracias al Su2Pov
                                juniormiranda
                                @didier bur said:
                                @solodown:
                                Please, the file doesn't work for me. I had the same problem:
                                private method `split' called for nil:NilClass
                                skp 8.0.3161
                                • C
                                  cm architects
                                  Didier,
                                  I installed Su2POV3.5: no problem. However when I start rendering I get the message: "POV file created in C:\users..\desktop\untitled but unable to launche POV-Ray......"
                                  What's going wrong?
                                  Cees
                                  • Didier BurD
                                    Didier Bur
                                    This message appears in these cases:
                                    • SketchUp model has never been saved,
                                    • Pov-Ray is not installed on your system,
                                    • .pov extension isn't associated with the Pov-Ray program.
                                    Please double-click on the file that has been created and see what happens, and let me know.
                                    Regards,
                                    DB
                                    • grusgrusG
                                      grusgrus
                                      Hi.
                                      I have discovered a rather obscure but very inconvenient bug in su2pov.
                                      While trying to render an architectural model using POV-ray and su2pov i found that parts of my model were in the wrong place (far far out of place).
                                      The common factor for all the missing or dislocated parts is that they have all been scaled as a part of an operation using other addons.
                                      Components that have been scaled while using Chris Fulmer's ComponentStringer or Scale and rotate multiple are moved out of place.
                                      If a component has been scaled manually it behaves as normal. However this problem is reproducible when using the aforementioned plugins.
                                      One of the components i am using is dynamic and the other is set to face camera. i have not tried with basic components.
                                      I have tried removing all my other plugins and just using su2pov but the problem does persist even so.
                                      I am using SU8 pro, su2pov 3.5 and the latest versions available of ComponentStringer and Scale and rotate mulitiple.
                                      Seeing as all these plugins are very useful tools, I hope it is possible to make them work together.
                                      regards
                                      Grusgrus
                                      • C
                                        CopperFr
                                        Bonjour,
                                        Ce plugin est très intéressant...
                                        Malheureusement, il semble y avoir quelques problèmes de génération des uv_vectors pour les textures dans le fichier .pov
                                        Par exemple, lorsque l'on fait un rectangle sans épaisseur les uv_vectors "ressemblent" aux vertex_vectors...
                                        vertex_vectors {
                                        4,
                                        <208.246285635031,0.0,265.826360174799>,
                                        <-396.253714364969,0.0,-140.798639825201>,
                                        <-396.253714364969,0.0,265.826360174799>,
                                        <208.246285635031,0.0,-140.798639825201>,
                                        uv_vectors {
                                        4,
                                        <-208.246285635031,265.826360174799>,
                                        <396.253714364969,-140.798639825201>,
                                        <396.253714364969,265.826360174799>,
                                        <-208.246285635031,-140.798639825201>,
                                        alors que l'on devrait avoir
                                        uv_vectors {
                                        4,
                                        <-3.25384821304735,4.15353687773123>,
                                        <6.19146428695265,-2.19997874726877>,
                                        <6.19146428695265,4.15353687773123>,
                                        <-3.25384821304735,-2.19997874726877>,
                                        Ca serait cool si une correction était possible...
                                        Test su2pov
                                        • Didier BurD
                                          Didier Bur
                                          Bonjour,
                                          Oui effectivement il y a un problème, mais qui n'arrive que sur des faces non extrudées, je ne sais pas pourquoi.
                                          Fait un cube avec cette face et tu verras ça marche 😳
                                          DB
                                          • C
                                            CopperFr
                                            Bonjour,
                                            Arf dommage...
                                            En fait, j'avais vu que ça fonctionnait quand on extrudait la face (ca m'a d'ailleurs permis de voir que les uv_vectors étaient en cause)
                                            A noter par ailleurs que le plugin SU2Kerkythea fonctionne correctement dans ce cas de figure... (Bon par contre Kerkytheas est vraiment trop lent chez moi sur des images en 1920x1200)
                                            Je crois qu'il y a d'autres cas ou cela fonctionne pas (mais c'est peut-être un problème d'alignement de texture)
                                            Question subsidiaire : le code source est-il disponible pour que je puisse éventuellement y jeter un coup d'oeil ?
                                            • 2 / 4
