    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
      Ah. Yes. Put the original shape directly above the straight line. The plugin draws the bent shape with the same offset from the arc as you have between the original shape and the straight line.
      • charly2008C
        charly2008
        thanks Dave,
        If you place the line exactly at the origin z-axis below the shape you will not have an offset.
        Charly
        • Chris FullmerC
          Its a game of percentages. Think of the arc as being 100%. Then your straight line, however long or short it is is also 100%. And it comes down to how the component matches up to the straight line. If the straight line is drawn precisely from end to end along the component (on the red axis of course), then you could say the component sits along 100% of the straight line. Therefore when it bends, it will become 100% the lengt of the arc.
          arc = 1m
          line = 1m
          component sits on 100% of line (therefore is 1m long)
          final shape will remain 1m
          arc = 1m
          line = 200m
          component sits on 100% of line (200m long)
          final bent shape will squish down to 1m
          arc = 1m
          line = .5m (50% of arc length)
          component sits on 100% of line (0.5m long)
          final bent shape will be 1m long
            @charly2008 said:
            thanks Dave,
            Charly
            Exactly.
            • L
              LeoZ
              Hai Chris
              First I must say I am impressed with your work on Sketchup. I was very enthusiastic about your Shapebender. But I stumbled on some problems with it. I tried to make a “real” metric bold; a M10. That’s a 10mm bold with a thread of 1.5 mm /turn. I wanted to use the method of “fret2424” (http://www.youtube.com/watch?v=MKrWDNDd62c )
              So I started with half a circle with a radius of 5 mm and I lifted one end 0.75 mm. That is not exactly right, but it was just to try.
              I got some very strange results you might like to investigate.
              Perhaps I am doing something wrong, but then I would like to know what.
              The result looks like this
              • Chris FullmerC
                My guess is that the faces are too small. You might try scaling everything up by 10 or 100, then scale it down afterwards. Can you upload the model here?
                • charly2008C
                  charly2008
                  this is a wonderful tool. Here is a test with a wood carving model.
                  Charly
                  • Chris FullmerC
                    That is precisely the kind of stuff I wrote this for - intricate models that need to be bent to match an actual surface. Bending detailed woodwork to match a curved piece of wood, adding signange/letters to a curving wall, etc. It is definitely a quirky plugin, but once you really get it down solid in your head the process it goes through and how to get what you want, it works pretty well. Thanks for lookig at it,
                    • charly2008C
                      charly2008
                      It can also be misused for other things
                      • L
                        LeoZ
                        You are so right!! I drew a bolt of 10 meters 😎 and it worked fine.
                        The only hitch was sketchup itself. It crashed while scaling it down.
                        But it has a nice autosave, so ...
                        This was my result.
                        It's cool!!! 😍
                        From a 10m bolt to a 10mm
                        This is too small to start
                        • Chris FullmerC
                          You seriously made that with shape bender? Cool!
                          • charly2008C
                            charly2008
                            Hi Glenn,
                            it doesn't work for me!.
                            Charly
                            • Chris FullmerC
                              What scale are you worjing at there Charlie? Is that life size - so a few mm? If so, it needs to be sacled up because SketchUp does not handle small faces well.
                              • charly2008C
                                charly2008
                                Hi Chris,
                                it was in mm's. I scaled it up, than it worked.
                                Charly
                                • gullfoG
                                  gullfo
                                  you see the madness you have unleashed upon us?
                                  added my version: just create the helix and extend a triangle equal to one segment and use shape bender. follow-me doesn't give as nearly a reliable result... then scale down.
                                  Glenn
                                  http://www.runnel.com
                                    azarkesh
                                    I am a mac user and a newbie to SU. I really want to use your bending script on mac. Is that possible. I have SU version 8 running on mac.
                                    MANY THANKS
                                    • GaieusG
                                      Certainly it's possible. Are you having any issues when installing/using it?
                                      • gillesG
                                        gilles
                                        a very easy way to screw any face:
                                        http://forums.sketchucation.com/viewtopic.php?f=15&t=15784#p122571
                                        • david_hD
                                          david_h
                                          do ya think you might wanna rephrase that?
                                          • G
                                            GMellow
                                            Hi. I'm trying to bend a helix into following a 3 dimensional path...
                                            1. I built the helix with the helix plugin
                                            2. I created the set up for Shape bender; Select shape (helix). select line, and select 3D path.
                                            Seems to hang up...???? I get a progress bar: 1%. Expected End Time:?(1 of 1) 1200 test points.
                                            Do I need to keep my paths to two dimensions?
                                            Any assist appreciated.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 63
                                            • 64
                                            • 31 / 64
