    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • GaieusG
      Hi Salma,
      Please, go back to page 1 in this topic and there is Progressbar.rb linked somewhere at the top. You also need to download/install that plugin so that this can work.
        SahmElshamal
        Hi Gaieus
        thanx 4 ur reply
        i will try what u said
          SahmElshamal
          No such file to load -- clf_shape_bender/clf_shape_bender.rbError Loading File clf_shape_bender_loader.rb
          that message came after i downloaded the Progressbar.rb[
          i have already downloaded the plugin and the Progressbar.rb , i work with SU 6
          plz tell me the steps of installing a plugin
          i cant find set up icon
          so i copy - past it to the plugins of SU
          is it right ???
          thanx
            SahmElshamal
            it finally worked
            thank u ,moderator
            thank u chris
            great plugin
            • charly2008C
              charly2008
              what I still don't understand is how do I control the length of the curved object?
              Charly
                You have to make the arc the desired length. In your example, the arc needs to be 2.80 metres long. You can get the length from the Entity Info box after you've drawn it but that doesn't make it easy. How you arrive at that arc length will be the challenge. I wonder if someone could write a plugin that would take a given radius and arc length and draw the arc.
                Generally I draw the arc first, measure its length and draw the straight line and the straight shape to match.
                • charly2008C
                  charly2008
                  Hi Dave,
                  thanks for your reply. I've done it with your method, but can still get a different length in the curved object.
                  Charly
                    Ah. Yes. Put the original shape directly above the straight line. The plugin draws the bent shape with the same offset from the arc as you have between the original shape and the straight line.
                    • charly2008C
                      charly2008
                      thanks Dave,
                      If you place the line exactly at the origin z-axis below the shape you will not have an offset.
                      Charly
                      • Chris FullmerC
                        Its a game of percentages. Think of the arc as being 100%. Then your straight line, however long or short it is is also 100%. And it comes down to how the component matches up to the straight line. If the straight line is drawn precisely from end to end along the component (on the red axis of course), then you could say the component sits along 100% of the straight line. Therefore when it bends, it will become 100% the lengt of the arc.
                        arc = 1m
                        line = 1m
                        component sits on 100% of line (therefore is 1m long)
                        final shape will remain 1m
                        arc = 1m
                        line = 200m
                        component sits on 100% of line (200m long)
                        final bent shape will squish down to 1m
                        arc = 1m
                        line = .5m (50% of arc length)
                        component sits on 100% of line (0.5m long)
                        final bent shape will be 1m long
                          @charly2008 said:
                          thanks Dave,
                          Charly
                          Exactly.
                          • L
                            LeoZ
                            Hai Chris
                            First I must say I am impressed with your work on Sketchup. I was very enthusiastic about your Shapebender. But I stumbled on some problems with it. I tried to make a “real” metric bold; a M10. That’s a 10mm bold with a thread of 1.5 mm /turn. I wanted to use the method of “fret2424” (http://www.youtube.com/watch?v=MKrWDNDd62c )
                            So I started with half a circle with a radius of 5 mm and I lifted one end 0.75 mm. That is not exactly right, but it was just to try.
                            I got some very strange results you might like to investigate.
                            Perhaps I am doing something wrong, but then I would like to know what.
                            The result looks like this
                            • Chris FullmerC
                              My guess is that the faces are too small. You might try scaling everything up by 10 or 100, then scale it down afterwards. Can you upload the model here?
                              • charly2008C
                                charly2008
                                this is a wonderful tool. Here is a test with a wood carving model.
                                Charly
                                • Chris FullmerC
                                  That is precisely the kind of stuff I wrote this for - intricate models that need to be bent to match an actual surface. Bending detailed woodwork to match a curved piece of wood, adding signange/letters to a curving wall, etc. It is definitely a quirky plugin, but once you really get it down solid in your head the process it goes through and how to get what you want, it works pretty well. Thanks for lookig at it,
                                  • charly2008C
                                    charly2008
                                    It can also be misused for other things
                                    • L
                                      LeoZ
                                      You are so right!! I drew a bolt of 10 meters 😎 and it worked fine.
                                      The only hitch was sketchup itself. It crashed while scaling it down.
                                      But it has a nice autosave, so ...
                                      This was my result.
                                      It's cool!!! 😍
                                      From a 10m bolt to a 10mm
                                      This is too small to start
                                      • Chris FullmerC
                                        You seriously made that with shape bender? Cool!
                                        • charly2008C
                                          charly2008
                                          Hi Glenn,
                                          it doesn't work for me!.
                                          Charly
                                          • Chris FullmerC
                                            What scale are you worjing at there Charlie? Is that life size - so a few mm? If so, it needs to be sacled up because SketchUp does not handle small faces well.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 63
                                            • 64
                                            • 31 / 64
