    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.9m Views 329 Watching
      SahmElshamal
      it finally worked
      thank u ,moderator
      thank u chris
      great plugin
      • charly2008C Offline
        charly2008
        what I still don't understand is how do I control the length of the curved object?
        Charly
          You have to make the arc the desired length. In your example, the arc needs to be 2.80 metres long. You can get the length from the Entity Info box after you've drawn it but that doesn't make it easy. How you arrive at that arc length will be the challenge. I wonder if someone could write a plugin that would take a given radius and arc length and draw the arc.
          Generally I draw the arc first, measure its length and draw the straight line and the straight shape to match.
            charly2008
            Hi Dave,
            thanks for your reply. I've done it with your method, but can still get a different length in the curved object.
            Charly
              Ah. Yes. Put the original shape directly above the straight line. The plugin draws the bent shape with the same offset from the arc as you have between the original shape and the straight line.
                charly2008
                thanks Dave,
                If you place the line exactly at the origin z-axis below the shape you will not have an offset.
                Charly
                • Chris FullmerC Offline
                  Its a game of percentages. Think of the arc as being 100%. Then your straight line, however long or short it is is also 100%. And it comes down to how the component matches up to the straight line. If the straight line is drawn precisely from end to end along the component (on the red axis of course), then you could say the component sits along 100% of the straight line. Therefore when it bends, it will become 100% the lengt of the arc.
                  arc = 1m
                  line = 1m
                  component sits on 100% of line (therefore is 1m long)
                  final shape will remain 1m
                  arc = 1m
                  line = 200m
                  component sits on 100% of line (200m long)
                  final bent shape will squish down to 1m
                  arc = 1m
                  line = .5m (50% of arc length)
                  component sits on 100% of line (0.5m long)
                  final bent shape will be 1m long
                    @charly2008 said:
                    thanks Dave,
                    Charly
                    Exactly.
                      LeoZ
                      Hai Chris
                      First I must say I am impressed with your work on Sketchup. I was very enthusiastic about your Shapebender. But I stumbled on some problems with it. I tried to make a “real” metric bold; a M10. That’s a 10mm bold with a thread of 1.5 mm /turn. I wanted to use the method of “fret2424” (http://www.youtube.com/watch?v=MKrWDNDd62c )
                      So I started with half a circle with a radius of 5 mm and I lifted one end 0.75 mm. That is not exactly right, but it was just to try.
                      I got some very strange results you might like to investigate.
                      Perhaps I am doing something wrong, but then I would like to know what.
                      The result looks like this
                        My guess is that the faces are too small. You might try scaling everything up by 10 or 100, then scale it down afterwards. Can you upload the model here?
                          charly2008
                          this is a wonderful tool. Here is a test with a wood carving model.
                          Charly
                            That is precisely the kind of stuff I wrote this for - intricate models that need to be bent to match an actual surface. Bending detailed woodwork to match a curved piece of wood, adding signange/letters to a curving wall, etc. It is definitely a quirky plugin, but once you really get it down solid in your head the process it goes through and how to get what you want, it works pretty well. Thanks for lookig at it,
                              charly2008
                              It can also be misused for other things
                                LeoZ
                                You are so right!! I drew a bolt of 10 meters 😎 and it worked fine.
                                The only hitch was sketchup itself. It crashed while scaling it down.
                                But it has a nice autosave, so ...
                                This was my result.
                                It's cool!!! 😍
                                From a 10m bolt to a 10mm
                                This is too small to start
                                  You seriously made that with shape bender? Cool!
                                    charly2008
                                    Hi Glenn,
                                    it doesn't work for me!.
                                    Charly
                                      What scale are you worjing at there Charlie? Is that life size - so a few mm? If so, it needs to be sacled up because SketchUp does not handle small faces well.
                                        charly2008
                                        Hi Chris,
                                        it was in mm's. I scaled it up, than it worked.
                                        Charly
                                        • gullfoG Offline
                                          gullfo
                                          you see the madness you have unleashed upon us?
                                          added my version: just create the helix and extend a triangle equal to one segment and use shape bender. follow-me doesn't give as nearly a reliable result... then scale down.
                                          Glenn
                                          http://www.runnel.com
                                            azarkesh
                                            I am a mac user and a newbie to SU. I really want to use your bending script on mac. Is that possible. I have SU version 8 running on mac.
                                            MANY THANKS
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 63
                                            • 64
                                            • 31 / 64
