    [Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
    50 Posts 21 Posters 40.8k Views 21 Watching
    • majidM
      majid
      almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue πŸ˜„
      • KrisidiousK
        Krisidious
        Majid,
        the plugins only work if you have that particular plugin already installed. these are shortcuts to other author's plugins. so if one is not working, you should check to see that you have that plugin. there is a rtf file or readme within the zip that lists the plugins that are used by the bar.
        let's see which one's you have that are not working?
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          hmmm... so you have the plugins installed that you're trying to use in the ribbon and it's not working?
          do you have organizer.rb running?
          have you checked to see that you have the
          /caleidos4d
          Caleidos4D_Ribbon.rb
          in the plugins folder?
          By: Kristoff Rand
          • I
            iwanwidjaja
            Hi Caleidos4D,
            Its a great plug in, thanks for share it
            Just a little curiosity, will it possible to make some option to choose between portrait and landscape configuration of the ribbon? As many of us use wide screen monitor, the modeling space begin to shrink in a very wide proportion when the ribbon is active πŸ˜†
            Regards'
            Iwan
            • majidM
              majid
              thanxs mates for your kind helps πŸ˜„ .the question is that it doesn't display anything ( I mean that I have installed the plugs..etc... and also created a simple qube) ... I can't see anything...any red-green-blue axes ...etc...
              • EarthMoverE
                EarthMover
                Majid, I believe you Caleidos4D Ribbon is covering your Sketchup window. You have to minimize it and then resize both the Sketchup window and the Ribbon to fit on the screen together. You can put the Ribbon above the Sketchup window or below, or on a second monitor, but the ribbon does not dock within Sketchup. It is a floating web dialog that overlaps Sketchup, so some resizing is necessary for it to all fit in your monitor.
                Content Creator at Skapeup
                • majidM
                  majid
                  thanx again.... I was thinking that it will cover my sketchup screen , so that I get rid of all plugin toolbars... 😞 (as I saw a black screen on some screenshots above) . maybe it could be an option for next update ,plz . πŸ˜„ it workes fine in way you described. thanx again
                  • C
                    caleidos4d
                    thank to all friends for help in topic πŸ†™ my english is very bad....
                    this is a .gif for usage and preview features in next release
                    http://www.caleidos4d.it
                    • troyhomeT
                      troyhome
                      [attachment=0:8asf8rxq]<!-- ia0 -->Usage_and_Preview.gif<!-- ia0 -->[/attachment:8asf8rxq]
                      can't wait to try this out- in English πŸ˜„
                      IOviz.com
                      SU Pro 2024 PC
                        Jim
                        For translate:
                        in the next version, I will translate the tooltips in English but I also accept suggestions πŸ˜„
                        Well, I appreciate this because I only know English; but I was also trying to come up with a language translation strategy in order to provide translations to any language.
                        I think JavaScript can be used to iterate over the tooltips, and set the Text according to the tooltip id (for example.)
                        • Bob JamesB
                          Bob James
                          @troyhome said:
                          @khai said:
                          all I'm getting at the link is
                          "alterVista
                          La risorsa richiesta Γ¨ accessibile qui
                          you have to click "qui"
                          I'm afraid I can't even find "La risorsa richiesta è accessibile qui so I can click on "qui" 😞 😳
                          Update
                          I got it by pasting in "http://caleidos.altervista.org/Download/caleidos4d_Ribbon.zip" and it automatically downloaded.
                          • C
                            caleidos4d
                            Update: 1.1 πŸ˜‰
                            • EarthMoverE
                              EarthMover
                              Nice update. English tooltips are perfect! Any plans to add FredoScale?
                              • C
                                caleidos4d
                                I wanted insert SfedoScale and BezierSpline, already in this release, but I can not find the call for the plugins in various fredo's libraries ...
                                • T
                                  tony bombata
                                  renderplus rpedits copy selection tool bug splatted EVERY time i ran the command - so i started removing my most recent plugins - and caledios was the culprit 😞
                                  • K
                                    kyyu
                                    Caleidos4D,
                                    Thanks for the plugin. Looks interesting. Got a question. When you select the major frames on the left side (Costruction[oops,btw spelling error], Projection, 2D, Modelurs,..etc), they change to a highlighted orange color. But when you select another, any previous ones are still hightlighted orange. Wondering if this is a bug?
                                    Oh, and an off topic question. Is there a easy html editor for laying out buttons, like this, on a webpage? Or wondering what editor, you used? I mean, if a beginner wanted to make the html portion of a web UI, like this. I can make a simple one by hand, like a column of buttons, but not like this.
                                    -Kwok
                                    • C
                                      caleidos4d
                                      EDIT 23-Sep-2011 New Download URL:
                                      DOWNLOAD Caleidos4D Ribbon Pubblic Beta 1.1
                                      ( http://caleidos4d.blogspot.com/2011/08/caleidos4d-ribbon-pubblic-beta-11.html )
                                      • guanjinG
                                        guanjin
                                        This fun, I can be free to load the new plug-in, strong
                                        • majidM
                                          majid
                                          dear mate, I like your plugin , and here saw a request, that seems to be combined in your plugin:
                                          http://forums.sketchucation.com/viewtopic.php?f=10&t=46094
                                          do you mind to play with your interface please? I guess it'd be a great step forward . πŸ‘ thank you again
                                          • H
                                            heglisonmarques
                                            Como faΓ§o para instalar o Caleidos4d
                                            • 2 / 3
